Question about Radio Communications
My bluetooth headset wont charge and the light did not blink red when i pluged the wire. What do I do?
Vivitar Bluetooth Headset 2016 Sakar International
  • Anonymous May 16, 2017
    i just found the solution to the problem. Just charge the headphones till it blinks red. It works, just need to be patient
SOURCE: Not sure if Jabra bluetooth headset or charger that not working
I had the same problem, called support, they told me battery is defective or too old and doesn't accept the charge. Battery in a headset is hardwired and can't be replaced, so the whole thing is trash :(
Posted on Jul 10, 2007
MonsterG
  • 52 Answers
SOURCE: pairing Jabra BT135 with motorola L2
okay, try this, turn off the jabra headset, and then, hold the power button but hold it down until the lights flash in a different way, and make ur phone search for devices and if it finds it then its all good, just use the 0000 password to pair it.if this works give me a fix rate. thank U
Posted on Feb 11, 2008
danfrater
  • 69 Answers
SOURCE: Connect trueblue bluetooth headset to Samsung Eternity cell phone
hold your finger on the call button on your blutooth device for around 6-10 seconds, this should make a couple of lights flash, when it does this it is active and ready to pair uo, then search, it will ask you for a code, usually they are generic and are prob the following 1234-12345-1111-11111-0000-00000-5555-55555 eiter one of these should work
Posted on Jan 01, 2009
SOURCE: My nokia E63 wont find bluetooth headset
I had a similar problem with my headset.. but found the solution.. I am using Jabra 2010.. ok.. so just switch "off" the headset...go to the pair menu on e63.. then switch on the headset.. and then look for new pair devices option.. voila it came up. hv been trying for almost 3 weeks before i got the sequence right.. somehow if u had switched the headset on beforehand.. it wouldnt recognise it only.. the solution is here at jabra website .. although.. they dont hv e63 listed .. but the same procedure for e71 worked fine for my handset..
Posted on Aug 05, 2009
issken
  • 1472 Answers
SOURCE: bluetooth passweord for datel headset please.....
dan_4ley
I do not know if you need the PS3 manual so I included the link below. How the code is "0000".
http://www.datelcustomerservice.com/product_pdf/PS3%20-%20Bluetooth%20Wireless%20Headset.pdf
Let me know if you have any more problems or questions.
Issken
Posted on Jan 23, 2010
Blutooth codes for kyocera
Step 1 Charge the Bluetooth headset battery. The headset is fully charged when the indicator light turns off. Step 2 Unplug the charger and check the indicator light to ensure that the headset is turned off. If the indicator light is on, the headset is on. Turn off the headset by holding the multifunction button (the button in the middle of the headset) until the indicator light blinks red and shuts off. Step 3 Press and hold the multifunction button until the indicator light blinks red and blue to place the headset in pairing mode. Step 4 Turn on Bluetooth on your phone to start searching for available devices. When the search is complete, a list of available devices appears on the screen. On many phones, the Bluetooth options may be found in Settings. Step 5 Select the Kyocera Bluetooth headset name from the list. The phone prompts you to enter a passcode. Step 6 Enter "0000" using the phone's keypad to finish connecting the headset to your phone.
Aug 11, 2014 | Kyocera Cell Phones
How to pair a ROMAN R6250 Mini Wireless Bluetooth Headset Earphone Headphone to an iPhone 5S
1. Charge the headset:Headset is charged via USB cable, the light will be red when charging. When the battery is fully charged (about 2-3 hours), the red light of the headset will turn off automatically or the red light turns blue.
2. Turn on the headset:Press the on / talk button on the headset for about 5 seconds until the blue and red flashes alternately (or blue flashes or the blue lights all the time ), now the headset is ready to be connected to the iPhone.
3. Go to Settings, and tap Bluetooth. Turn on Bluetooth.
iPhone will automatically start searching for Bluetooth devices. Tap the device in the Devices list, then follow the onscreen instructions to connect to it. After matching successfully, the blue light on the headset will flash twice per time.
4. Call: when you finish all the above steps, you are going to talk via the Bluetooth headset. When there is incoming call, press the on / talk button, you can talk with Bluetooth headset, when you want to end the call, press the on / talk button, you can end the call.
5. Turn off the headset: Press the on / talk button for 5 seconds until the red light of the headset flashes quickly for twice, then release the button, the headset will be turned off.
Mar 25, 2014 | Apple iPhone Cell Phones
MY LG TONE HBS-730 WILL NOT CHARGE
It is charged when the red light goes out. Press and hold the VOLUME DOWN button for one second and an audible will give you the battery charge level - high - medium - low.
Apr 20, 2013 | LG Tone HBS-730 Bluetooth Stereo Headset -...
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
My motorola n136 headset will not charge. This is my second headset with both doing the same thing. When pluged in to wall charger the blue light comes on but it is not charging. What am i doing wrong?
I dropped my 4-5 month old Motorola N136 bluetooth under my couch while activated. Took me a week to get it out, and now it will not take a charge. All I get is the red light blinking over and over when plugged into my charger. Any ideas? lotsofstufflv@gmail.com
Jan 03, 2011 | Motorola Mobility H270 Bluetooth Headset
Mine wont turn on
Hello, did you check the battery? Tu get the full charge, the headset red light must stay steady on. If you get it charged you can pair it: hold power button till the two leds blinks, now scan for bluetooth from PS3 and choose your mic setting. Other than that I'd call madcatz technical support. Good luck, Peter_Rei
Aug 04, 2010 | Mad Catz Bluetooth Headset for PS3
How to pair with iphone
Hello
1.From the main home screen of the iphone open "SETTINGS".
2.From the setting menu go to "GENERAL".
3.From General go to "BLUETOOTH".
4.In the Bluetooth menu you will see an on/off switch. Make sure you turn the switch to "ON".
5.From here you want to go to your bluetooth headset. Hold the on button for about 5-10 seconds until the light starts blinking. Once light is blinking go back to iphone.
6.In the Bluetooth menu (same as step 4) your iphone should have discovered your bluetooth headset. However if it is not paired yet. Open the headset menu.
7.In the headset menu you are required to enter the appropriate PIN number (which should be given inside your bluetooth headset instruction manual).
8.After you have entered the correct PIN number press connect.
9.From here your Bluetooth Headset should be connected and ready to use.
NOTE:Fully charge your bluetooth headset before syncing it to your iphone
Goodluck
Apr 16, 2010 | Samsung WEP410 Bluetooth Headset Wireless...
I cant get my plantronics ex 233 bluetooth to connect to my ps3
when i charge my bluetooth, the light is red for a few minutes but it goes out and its not charging anymore. Please help
Mar 04, 2009 | Plantronics Stereo Earbud Headset for Use...
Radio Communications Logo
44 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
