I have a fuzitec FW-486L W/Hd when i turn it on shows, pre-temp. i can not take it off
The oven will pre heat to set temp, then when it reaches temp the oven beeps and both oven elements turn off. At this point the control panel (clock LED) shows an F2 error.
Good afternoon.
F2 for hotpoint means oven temp sensor thinks oven exceeded 650 degrees .Did that happen?
Probably not so have your sensor checked or replaced. It should be a probe device in oven back wall.
Was this helpful?
Aug 16, 2011 | Hotpoint RB787 Electric Kitchen Range
Have 2 1tb my book hard drives that wont turn on
Have you checked the power lead. I made a mistake once of using the wrong adapter and it wasn't powerful enough.
Feb 05, 2010 | Western Digital MY BOOK HOME 1TB EXT...
FW Lacie Porsche FW ext. HD 250GB light on case blinks and
conect your harddisk to computer whch has windows xp.
Then go to start emnu then type in run 'cmd"
then you can see command propmt.
Then go to your external drive letter like f:
then type 'chkdsk /r"
then pres "y'
then it fix error on hardisk.
Aslo you can format it .
Just take backup of data which you need then right clik on drive licon and format it.then it works fine.
Jun 23, 2009 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
Hard drive detection
there must be some problem with the firmware,you need to update your fw or you can use some tool to restore your fw,such as pc3000 or HD Doctor for salvationdata
Apr 20, 2009 | Toshiba 120GB USB 2.0 Portable External...
Deference Lacie d2 Quadra1TB/Lacie big disk ?
It's all about the interfaces.
The Quadra has four interfaces: • eSATA • FW 400 • FW 800 • USB 2.0
The triple has all but the eSATA interface listed above.
For doing video work you want a big drive with a fast interface. If you have eSATA available then that's the fastest. If you don't then you're just as well off to go with the triple interface. The FW 800 would be the next fastest, then the USB 2.0, then the FW 400.
Because of the way that data is transferred I believe that when doing video work you would be best served by the FW 400 instead of the USB 2.0 even though the USB is faster I don't believe it is a full duplex communication so the FW 400 is actually better for video.
Apr 03, 2009 | LaCie Big Disk Extreme with Triple...
Samsung 32'' tv
If it never turns off, then you can upgrade the FW on it. Contact Samsung. Is there any other faults with you TV?
Aug 16, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
