How many filter does the ezi 7.5 kg washing machine have Aand where are they Thank you
  • 351 Answers
SOURCE: 7 kg intellowasher noise when in wash cycle
if its a direct drive remove the rotor and see if theres a loose magnet etc,hope this helps
Posted on Mar 04, 2008
SOURCE: I have j1045 front load
The display should say 5E, this means that it's not draining. unlucky for you as this means you have to replace the drain pump, wich aperently cost about $137NZ. this seemes to be a common fault. i'm not a teck, but I just had the same thing happen, lucky for me i had a warranty.
Other simptoms are the loud racking noise coming fromn the washing machine. home this helps.
Posted on Mar 15, 2009
  • 208 Answers
SOURCE: Simpson front loader won't power up !
that wa the first thing that came to my mind i think your on the right track call a service department give them the make model number of the washer they should be able to help you locate a reset switch if it has one . good luck
Posted on Jun 22, 2009
SOURCE: Electrolux/Simpson EZI sensor 5.5 kg machine cycles.
Well I'm an idiot. They did say there was a fast wash, but it specified that it was for extra rinses to help people with detergent allergy etc., but did not give a time for the cycle. They should have said it was the short wash for everyone. I tried it, and it was fine. Thanks anyway. If I ever have a real problem, I'll be back.
Posted on Aug 04, 2009
SOURCE: We are using our Electrolux/Simpson Ezi Sensor washing
also have the same machine - if you wash with the eco rinse the clothes will ALWAYS have the soap residue on them and if you use the deep rinse then this machine will just sit there doing the very occasional agitate for up to 6 hours - can't win - have only just hung out a load and as usual there are many many dry spots on the sheets which is a daily occurence - really hate this machine and it's so called u-beaut functions -
Posted on Mar 11, 2010
Hi,i have a Simpson EZI Sensor 6 kg top load it has PU error code, any one knows what this code reflects? Thank you in advance Mike
It means pump error. Water is slow to drain or not draining at all. May be a blockage or could be a faulty pump.
Dec 06, 2016 | Simpson Washing Machines
Hi, i have a simpson 9.5 kg ezi set and it has been going out of balance only on light loads, could you please tell me possable cause thank you
Could be the drum bearing. If it's noisy when operating that could indicate the bearing is deteriorating.
Jul 01, 2016 | Simpson Washing Machines
I have a Simpson ezi Top Loader 8 Kg what does a E20 error code mean
Lift the top by unscrewing the screws in the back or remove the back panel and there you will find a code and test sheet. Very easy to follow if you follow it to a T.
Jan 20, 2016 | Simpson Washing Machines
I have 5.5 kg front loader simpson EZI sensor washing machine,the handle to open the washine machine has gone loose and now can not open my full load of washing from the machine
you need to take the top off turn off the mains supply
and reach down to the door catch behind and manualy open it
if the handle has cracked a the pivot pehaps a flat blate screwdrive and you can carefully release it
youll find a littl preasure to the door will help you then let go and the door will open easier
Mar 02, 2015 | Simpson Washing Machines
I have a simpson 9.5 kg washing machine an ezi you put powder in and it wont fill you turn the settings to fill and it wont work any ideas i was working fine then now it wont fill up
Power off the machine. Close your wall faucet which brings water into the machine. Unscrew the nut, hold a bag or bucket to collect water coming in from the wall, gently open the water control to see if water flows - the flow should be in good pressure. If it is good, close valve; now open the other end of the pipe going into your machine. You will see a fine filter connected to your machine; clean this out if clogged with an old toothbrush; clean out your pipe too. Refit carefully both nuts, without cross-threading; open the wall faucet to check for leaks. Things should be fine.
Mar 01, 2015 | Simpson Washing Machines
Simpson ezi 950 9.5 will not empty, rinse, spin dry.
That sounds like the pump is jammed. Have you checked for hair slides or similar? Once the pump is free to operate, your Simpson should resume normal service.
Feb 20, 2014 | Washing Machines
I have a Simpson ezi set 9.5 kg washing machine.It has stopped in the middle of a wash and the LCD screen I showing EFO.Can you tell me what this means and what I need to do to get machine to finish...
i have a 9.5kg simpson washing machine just 5months old and ive had this problem E20 quite frequently that its annoying. I printed out a manual and foundout why. i do not have the patience to remove draining hose im sure there is a simplier way. Ive notice if i tap the side of machine 3 to 5 times it drains lol! seriously never had a problem with my old 7.5kg hoover machine, please help
Jun 19, 2013 | Washing Machines
Aug 03, 2009 | Electrolux Washing Machines
Jun 22, 2009 | Washing Machines
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
