Question about Canon Cameras
I have canon power shot A3000IS the screen appears dark although the flash and zoom works
  • Canon Master
  • 5,412 Answers
In the menu system there may be a control to adjust LCD brightness.
Posted on May 16, 2017
No image is captured by the screen itself (LCD screen works but completely dark).
Did you try pressing the display button several times? in both viewing mode and record mode? Cycle through all display modes, s you get used to the button, so it does not trow you off when it happens again.
Feb 16, 2015 | Canon Cameras
Canon Power Shot A3000IS new Driver
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Mar 21, 2013 | Canon PowerShot A3000 IS Digital Camera
The problem is that u know the sony hdv xr500x when u put it on the picture is very dark we have tried it under light too put but the picture is still dark
Hello
When you look at your pictures are they dark, murky and hard to see? If you took pictures at a wedding, dance recital, theater performance or any indoor event and they came out dark, read on to learn why your pictures are dark, and how to fix this common camera problem.
Many people take pictures of indoor events, only to be unsatisfied with the final outcome of their photos. Although you may have bought the top of the line film or digital camera, there are a few limitations that you need to know about.
To correctly expose your pictures, you camera needs a lot of light. The compact point and shoot varieties adjust for this when you're outside during the daytime, and usually your pictures turn out fine, right? Well, then how come when you take indoor pictures, they sometimes come out too dark? There are two culprits; your zoom function and your flash.
Most compact cameras today offer a zoom function. When I used to work in retail photography sales, the first feature that consumers would ask for is zoom. People love to get close-up pictures without using their feet. Although zoom does bring your subject matter in closer, it also decreases the amount of light that can get into your camera. Essentially, the more you zoom, the less light your camera can receive, and your pictures will be darker.
So, if your taking pictures indoors, in a dark church, gym or other window-less room it is very difficult for your camera to get enough light to properly expose your pictures.
This is when most photographers decide to turn on their flash. The flash on your camera is a great tool to illuminate dark situations that are in close proximity to the camera. Most built-in flash units are designed to allow the light to travel 8-10 feet away in poor quality light and up to 15-20 feet in brighter situations.
What most camera users fail to realize is that although your zoom function is visually bringing you closer to the action, you flash cannot reach that far to illuminate the subject, and your pictures will be dark.
Hope it helps, if so do rate the solution
Dec 21, 2010 | Sony Cameras
My daughter dropped the canon power shot a650 and now the fold-out screen does not work, although she can still take pictures using the view finder. Can the fold-out screen be replaced? It appears to...
here u go u can buy and replace it is easy to do so but u can get it fixed as well see the link and pls rate me FIXYA for help
http://www.darntoothysam.com/servlet/the-1222/Canon-PowerShot-A650-IS/Detail
Mar 27, 2009 | Canon PowerShot A650 IS Digital Camera
CANNON SURE SHOT 80U
1. With power off, press the MODE button to select the DATE mode.
2. Press the zoom out (three trees) button for more than two seconds to enter the date/time set mode.
3. Press the zoom out (three trees) button to select year, month, day, hour, or minute (selected number will flash).
4. Use the zoom in (one tree) button to advance the number.
5. Repeat steps 3. and 4. to set each value.
6. Press the zoom out (three trees) button until the colon (in the hours:minutes) is flashing. When the colon stops flashing, date and time setting is completed.
7. Press the MODE button and the power will switch off.
Jan 22, 2008 | Canon Sure Shot 80U 35mm Point and Shoot...
White Screen
  1. Upon startup lens emerges but when screen appears it is white whereas it normally displays whatever the lens sees. When the shutter button is pressed the camera will focus and take a white picture which can be deleted. The camera does not flash although flash is set to automatic and photo taken in a dark room. Camera flashes (weakly) with flash set to manual on. Lens is unobstructed and appears to be perfectly normal. Camera was not dropped. Batteries have been changed.
Jan 19, 2008 | Pentax Optio E10 Digital Camera
Canon Sure Shot 105 ZOOM ~TOTALLY LOST ~need any instructions I can get.
The flashing H means hat the camera has detected a hardware fault on starting up. It can also mean that the film has mis-loaded. Try removing the film & then the battery to reset it. Put the battery back & switch on. If it's still doing it then I'm afraid it's got the 'flashing "H" of Doom'. Although this is repairable, it's usually not economically viable.
Jan 11, 2008 | Canon Sure Shot 105 Zoom 35mm Point and...
How do you set the time on the Canon sure shot 80u
Sep 10, 2007 | Canon Sure Shot 80U 35mm Point and Shoot...
Canon sure shot 90u
Take the battery out then push some buttons - the zoom buttons or the release button - til the LCD goes blank. This sometimes resets the circuit if there is really no problem. Then reinsert the battery and try again. If the H reappears, there is a problem with your zoom. It'll have to go to a repair shop.
Nov 30, 2006 | Canon Sure Shot 90U 35mm Point and Shoot...
Cameras Logo
148 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
