Question about Sanyo Televison & Video
I have a 43" Sanyo tv I turned it on and the sound is good the picture is black and white no color in the picture help
  • 93 Answers
SOURCE: dvd in black and white should be color
Your probably had connected with a component video without changing the video setting!If you video setting is under composite/S-Video output but you end up connect the video source with component video cable,you need to go to the setup to change it.
It could be the other way around too!
solutiondoct
Posted on Nov 12, 2008
SOURCE: my sanyo tv has no picture no sound 31"color tv
my grand son unplugged my sanyo tv 32in from wall while on no wi have no picture and no sound
Posted on Aug 05, 2009
dave1645
  • 834 Answers
SOURCE: I have a SANYO DP46848, after i turn on the TV
The ic on the T-con board is failing you could confirm this by spraying circuit cooler on the ic . The T-con board is located in the middle top on the unit has a cable from the mainboard to the t-Con
and two other going from it to the panel
You can try either Shopjimmy.com or TopsElectronics in Haverhill Ma
Posted on Dec 07, 2009
SOURCE: sanyo vizon tv black screen
Replace 12v ac adapter ( if you can find one ).
Posted on Aug 16, 2010
saryejade
SOURCE: No sound and black screen
lets get together, start a list of names and sue companies selling crappy wares at way too high prices! email saryejade@aol.com
Posted on Oct 05, 2012
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Dec 15, 2013 | Sanyo DP26648-R 26 in. LCD TV
Sirs: I have a new Sanyo 42" TV. We are on
Hello
If picture and sound is ok, and there is no colour, your push have sometimes made its system changed. I don't know from where you are, and to which country you belongs. Anyway I'll give you one solution.
Your Sanyo Tv may have multisystem compactable. There are mainly three systems in transmision of TV signals, called PAL [Phase Alternating Line], SECAM [Sequential colour and mamory] and NTSC [National Telivision System Committee]. Most of the europian countries have transmitters with SECAM and NTSC. I belongs to India, and here we have PAL BG system.
If the system has changed in the tv, the picture will not have chroma information, ie ,colour information, and black and white picture will be the result. You just do one thing. Just get into the Menu of your TV, according to its documantaion that you have, and go to the system menu, and make it "AUTO". This will solve your problem. Ok.
Nov 24, 2010 | Sanyo DS31520 31" TV
Have picture in black & white no color. audio
Hi,it definetely sounds like the color wheel.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Found your color wheel here: http://www.discount-merchant.com/MITSUBISHI-00-L3603-002-p/1162430.htm Have a bless one!
Mar 29, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Adjusting to the proper color
Tint would be the control that will control the color balance, but this sounds like it may be deeper then that. Turn your color all the way down so that you have a black and whit picture. If the picture is still yellow then you have a problem with the blue picture tube.
Feb 02, 2009 | Philips 43PP9202 43" Rear Projection...
No color only black and white picture
one of your color tube has gone out on you.
Jan 25, 2009 | Hitachi 43F300 43" Rear Projection...
TV Picture is tinted pink
depending on how much you paid for the tv , the cost of the repair may be more than the tv is worth. but if this is a large tv , then the repair would be most likely worth it
Dec 29, 2008 | Televison & Video
Bad color
Turn the color level all the way down and see if you have a good black and white picture. If your screen isnt black and white it should have a predominate tint to it. then turn the screen control for that color down to achieve the best black and white picture. then adjust your color level that should help.
Jun 13, 2008 | Mitsubishi WS-48311 48" Rear Projection...
Ps2 hookup to a sanyo 42in. flatscreen 1080p
Need to resolder the parts inside they call it CRYSTAL to make the color cameback. It happen mosthly bcoz of the old of the tv.
Apr 23, 2008 | Sanyo DS31590 31" TV
Samsung HLN617W1
this just happened to me and it was the color wheel it shattered
Oct 20, 2007 | Samsung HLN437W 43" Rear Projection HDTV
Televison & Video Logo
26 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
