How do I remove the interior panel on a LG lfx28978 (frozen drain)? There are no screws in it and no visible release tabs.
SOURCE: Front panel removal instructions for
You have to remove the back bottom skirt from television in order to get to the screws for the front bottom panel. When the front bottom panel is removed there will be more screws visible, for front screen. After an afternoon of trying to get it apart, just to clean the mirror on ours, we finally got it.
Posted on Nov 23, 2007
  • 57 Answers
SOURCE: Trying to remove door panel. Seems stuck behind door handle.
Under armrest are two large philips screws. remove these and the panel will fall off.
Alternatively, one screw may be acccessed from the top down on the arm rest, remove small access circle, or tray insert.
Posted on Dec 15, 2008
cadman000
  • 607 Answers
SOURCE: Removing manual window handle at door panel
Uses a "c" clip to secure window handle. Requires a special clip removal tool, that can be purchased at the parts store. Hope this helps
Posted on May 23, 2009
  • 12 Answers
SOURCE: How to remove drivers door panel from 1997 Cadillac Deville.
try to look at stress point on door by handle normally two screws and under neath panel to screws also disconnect side panel for side mirror door of using panel popper
  • 169 Answers
SOURCE: Latch on the liftgate of 1997 Jeep Grand Cherokee will not open.
clips, unless its not meant to come off in which case Jeep uses rivets. Play safe!
Posted on Aug 22, 2009
How to remove the heater core on 94 mercury cougar
Removing the Old Core
  • Disconnect the Mercury Cougar's negative battery cable. Remove the center console from the interior. Disarm the car's air bag system and remove the bag's diagnostic monitor and bracket.
  • Take the heater outlet floor duct out of the car. Remove the screw holding the air transfer duct and push it into the outlet duct. Unscrew the screws retaining the outlet duct to the heater core cover and release the retaining tabs on each side to remove the duct.
  • Raise and support the Mercury Cougar, using multiple jackstands. Drain the engine coolant by removing the drain plug on the bottom of the radiator. Replace the drain plug after all the liquid flows into a clean container and disconnect the heater hoses from the core
  • Withdraw the black vacuum supply hose from the vacuum source (you can now lower the vehicle). Disconnect the same hose from the air conditioner's vacuum reservoir tank.
  • Detach the heater core cover that holds the core by releasing the retaining tabs and removing the clips. Remove the dash panel seal, vacuum hose and heater core bracket from the cover.
  • Remove the heater core from the cover and the case seal from the core
Dec 20, 2016 | Mercury Cars & Trucks
Removal of rear door lift hatch interior plastic panel on a 2005 Dodge Grand Caravan to push out dent in metal door from the inside.
The rear door panel is secured to the door using screws and clips. The screws will be in the handle used to close the door and there may be plastic plugs in the handle hiding the screws. Once these screws are removed, the handle will come off. Look for any more screws along the panel. If there are more, they will be visible. Once the screws are removed, pull on the panel to release the clips that secure it to the door. These clips will require some force to release them and will make a snap/pop sound once released. You may have to put a screwdriver/wedge between the panel and door to start the process of releasing the clips
Jan 20, 2016 | 2005 Dodge Grand Caravan
How to install samsung Part Number DC31-00054A (AP4202690)
1. Unplug the washer. 2. Unscrew the 2 screws at the top back of the washer that secures the top of washer pane, slide it back and lift off, remove and set aside. 3. Pull out the dispenser tray and depress the tab at the back to full remove. 4. Remove the dispenser mounting screws, slide the dispenser back. 5. Carefully pull the control panel off from the top, disconnect the two wire harnesses and set the control panel aside. 6. Use needle nose pliers to remove the retaining wire and spring from the door boot seal, pull the seal away from the lip of the front panel. 7. Remove the 3 door mounting screws to release door latch assembly from the front panel. 8. Open and detach the filter access door and release the drain tube from the retaining tab. 9. Remove the screws inside the filter housing securing the front panel. 10. Carefully lift the front of the washer up and support it. 11. You can now remove the screws at the bottom securing the front panel(if your has these, mine were missing). 12. Now is also a good time to detach the pump assembly wire retainer from the base(small white plastic tab sticking downward). 13. Remove the support and gently lower the washer back down. 14. Remove the mounting screws on top of the front panel. 15. Now, use a flat head screw driver to depress the locking tabs to release the front panel from the frame. 16. Detach the recirculation hose from the retaining brackets on the inside of the front panel and set the panel aside. 17. Uncap the drain tube, and drain the excess water, then recap the tube. 18. Release the retaining clamps securing the hoses to the pump assembly and slide the hoses off.(be prepared for some water to spill). 19. Remove the two screws securing the pump assembly to the mounting bracket. 20. Now, push the assembly back to release it from the base. 21. Next, detach the drain pump cover(top white plastic cover) and disconnect the wires, now remove the 3 mounting screws and pull off the old pump. 21. Install the new drain pump by properly aligning it on the assembly. 22. Replace the mounting screws to secure. 23. Connect the wires to the new pump and snap on the cover. 24. Position the pump assembly into the cabinet base by inserting the mounting tab into the slots in the base, then push forward. 25. Replace the screws to secure the assembly to the mounting bracket. 26. Snap the wire retainer into the base. 27. Reattach all of the hoses to the appropriate ports on the assembly and position the retaining clamps to secure. 28. Replace the front panel, by aligning the slots in the panel with the tabs on the base. 29. Secure the recirculation hose in the retaining brackets, making sure the door latch is inside the cabinet and snap the top half the panel into position. 30. Replace the screws on top. 31. Lift and support the washer, then replace the screws on bottom. 32. Remove the support and lower the washer. 33. Replace the 2 screws in the filter housing. 34. Secure the drain tube under the retaining tab. 35. Reattach the filter access door and snap it closed. 36. Now, realign the door latch assembly in the front panel, and replace the mounting screws. 37. Align the boot seal on the front lip of the panel. 38. Replace the retaining wire and spring to secure. 39. Replace the control panel, by first reconnecting the wire harnesses. 40. Now, insert the control panel tabs into the slots into the trim and snap the top half of the panel into place. 41. Reposition the dispenser and replace the mounting screws. 42. Slide the tray into place. 43. Reposition the top panel by aligning the edge of the panel with tabs on the support bracket, then push forward.
44. Replace the screws at the back. 45. Plug the power cord back in. Your done!
Your washer should be ready to use now!!! Good Job!
You should find this video useful, even if it is for a different model washer, it is what I used as a reference. Drain Pump Replacement part DC31 00054D Samsung Washer Repair
Sep 06, 2014 | Samsung WF448AAP Front Load Washer
How to remove the drip pan
As far as I know you don't remove it. Check the drain isn't blocked and the best way to empty the water is by using a water vacuum
Jan 05, 2014 | LG LFX28978 (27.6 cu. ft.) Bottom Freezer...
Remove door panel
Expedition Trim Panel Removal
NOTE The door glass must be completely raised.
  1. Remove the window control switch plate.
  2. Remove the door handle bezel.
    WARNING To avoid damage to the door trim panel, lift the door trim panel by pulling directly upward on the armrest to disengage the panel clips.
  3. Remove the two bolts and three screws, and remove the door trim panel.
  4. Remove the finish cover to access the two center screws.
  5. Disconnect the electrical connectors.
    Fig. Expedition - Trim Panel Screws shown
  6. Remove the door handle bezel.
  7. Use service notch.
  8. Remove the two bolts and three screws, and remove the door trim panel.
  9. Disconnect the electrical connectors.
    Fig. Navigator - Trim Panel Screws shown
  10. Position the water shield aside.
  11. If equipped, disconnect the lock cylinder rod.
  12. Disconnect the exterior door handle actuating rod.
  13. Remove the bolts and position the front door latch aside.
  14. Disconnect the electrical connectors.
  15. Release the interior door handle cable and remove the front door latch.
  16. Position the cable cover aside.
  17. Release the conduit and the interior door handle cable.
  18. Release the locking tab and remove the front door lock actuator.
  19. To install, reverse the removal procedure and note the following:
    1. Tighten the door latch screws to 80 inch. lbs. (9 Nm).
This procedure is followed to check and fix door locks.
Hope helps.
Jan 12, 2011 | 2001 Ford Expedition
How do you change a pump on a Samsung WF448AAP washer? Need to get in from the back?
Dec 07, 2010 | Samsung WF448AAP Front Load Washer
My LG is a few years old, Model WM1832CW and seems to work in all modes except rinse. It just started this morning and sounds like its slipping and grinding and won't pump the water out. any suggestions....
Replace the pump motor. On your model, it can be done without removing the front panel. Open access door at bottom left of front panel. drain water out small hose. remove screw from plastic recess and use putty knife at side of recess to remove plastic recess. remove screw holding pump. pull machine out 2 feet from wall and tilt it back to rest back edge against wall. depress plastic tab in base to release pump. remove hoses and unplug electrical connection to pump. remove 3 screws holding pump motor to pump housing. install new pump motor and re-assemble.
Nov 27, 2010 | LG WM-1832C Front Load Washer
Cant remove door pannel on driver side 04 gmc seirra
1. Remove the door handle bezel.
2. Insert a flat-bladed tool between the door handle bezel and the trim panel in order to release the handle bezel tab retainers.
3. Remove the door trim panel upper extension.
4. Release the upper extension by pulling outward on the front edge in order to release the upper retainer clips.
5. Remove the upper extension from the trim panel by lifting up and out.
6. Using a suitable flat bladed tool, gently pry the manual lock lever from the door trim panel. Remove the trim panel screw.
*Remove the screw (2) from within the opening where the manual door lock lever resides.
*Remove the screw (3) from the opening in front of the armrest.
*Remove the screw located beneath the map pocket, if equipped.
7. Carefully slide the trim panel up in order to release the retainers from the door. Disconnect the electrical connectors.
Note: the top part of the door panel is not separate from the bottom. The "upper extension" is just the small triangle piece directly behind the mirror on the interior.
Simplified instructions
Remove the bezel around the door handle.
Pry out the manual lock.
Remove the 3 or 4 screws depending on options
Slide the door panel up off of the engagement tabs.
Good luck and thank you for using Fixya.
Mar 16, 2010 | 2004 GMC Sierra 2500
On an LG 2277 washer. I try to start a load. I get error message: "de"- door not closed. It looks to me that there must a switch to sense if the door is closed. Where is this switch located and how do you...
The switch is behind the front panel - to remove it, unplug the machine and:
1. Open the panel where the drain filter is (lower left side of the front panel)
2. Remove screw visible inside this area and remove the white molded plastic - also remove the screw behind that plastic.
3. Open the washer door and remove the spring loaded wire around the door gasket. Carefully pull the door gasket away from the panel push inside and then reclose the door.
4. Remove the detergent drawer and the two screws visible behind it.
5. Pull the top of the electronics panel away from the machine and lift up - place on top of machine or hook it out of the way
6 Remove the 4 screws that are visible holding the front panel to the machine. Left the entire front panel up about 2 inches and swing to the right
The wire connecting the panel to the machine on the right leads to the switch and door lock mechanism
Apr 25, 2009 | LG WM-2277HW Front Load Washer
Lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
  1. Unplug the machine.
  2. Drain whatever water you can from the machine using the stoppered hose behind the bottom left panel
  3. Unscrew the visible screw holding the plastic in place near the drain hose and filter
  4. If you can pull the plastic recessed piece out, there is one screw visible behind it - unswcrew this. If you cannot pull it out now, you should be able to get it after you remove the screws in step 10
  5. Pull out the detergent drawer (push in the middle back "botton" to release the drawer to pull out fully)
  6. Unscrew two screws in the drawer area.
  7. Pull the top of the electronics assembly away from the machine and lift the assembly out (place on top of the machine or hook it out of the way)
  8. Open the door and remove the spring loaded wire around the door seal (be careful as the seal can be torn)
  9. Pull the seal away from the metal front panel, then close the door
  10. Remove four screws at the top of the front panel (that were behind the eletronics assembly) - If you already have removed the screw from step 4, proceed, otherwise lean the top of front panel out and pop the plastic out, hold panel in place and remove that bottom screw from step 4.
  11. Lift front panel about two inches, swing the entire front panel to the right and set against something - You should now be able to see inside the machine.
  12. There is a black hose right in the middle - when I squeezed mine a little, I could see where the water was dripping out from the bottom.
  13. There are three clamps - two that can be squeezed with pliers and removed, one that has to be unscrewed (phillips head screw - it is a bit blind as the screw faces the back of the machine) - Once I got mine off - I could see the hole.
  14. Order replacement and reassmble in the opposite order
Apr 05, 2009 | LG WM-2277HW Front Load Washer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
