When I plug in the unit it trips the reset button every time. Its
I have the same model Haier HWF05XC7-2
When I plug in the unit it trips the reset button every time. Its only been used for 2 days. As soon as the plug is in the outlet it trips. the outlet is fine, we've tried it in other outlets and it does the same thing.
  • 744 Answers
This is only a 5,200 BTU unit - for single room use.
If you're sure the voltage ok, it sounds like the unit is new and should be under warranty.
Posted on Jul 25, 2009
I have a Haier Electric dryer RDE350AW and it needs to be reset. Where is the reset button on the unit?
no such thing.....check E/E house panel.....breaker to dryer is tripped.....
Mar 02, 2015 | Haier Dryers
Haier dehumidifier will not power on
Turn the ON/OFF Switch to OFF and unplug the unit for 15 minutes.
Once the time has elapsed, plug the unit in and turn the unit ON.
Hopefully, during that 15 minute timeout, the electronics reset and reverted back to the original factory settings. And the unit will turn ON when you press the ON/OFF Switch.
It's also a good idea to check the outlet it's plugged into. It very well could be an issue with the outlet (no power) or the circuit breaker for that outlet has tripped.
If you continue to have a problem getting it started, contact LG Customer Support 1-800-243-0000.
May 27, 2013 | Haier 65-Pint Dehumidifier
I HAVE A FEDDERS AIR CONDITIONER MODEL AED24E7F-C THIS UNIT TRIPS THE RESET BUTTON ONCE IN A GREAT WHILE IT RUNS FOR HOURS OR DAYS ON END AND THEN TRIPS. IT TAKE AWHILE AFTER THAT BEFORE I CAN RESET...
The reset button is part of the cord. The cord has built in arc detection. This is a complex circuit that monitors the unit and senses potentially dangerous sparks or arcing inside the internal components of the A/C (motors, switches, etc.) It sounds like the problem is getting worse - as they usually do. Sparking and arcing happen when dirt, corrosion, etc. accumulates and can result in pitted contacts. All of these conditions only make the sparks and arcs worse. Page 1 of the manual (left column) says this:
If the Arc Detection Device has tripped, the
reset button will pop up.
Follow these steps to reset the Arc Detection
Device:
1. Unplug unit from electrical outlet
2. Press the reset button
3. Plug the unit back into electrical outlet
4. Check to see if power has returned to the unit
Testing
You should test the Arc Detection Device
equipped power cord monthly, after every major
electrical storm, or if power to your Room Air
Conditioner has been interrupted.
Follow these steps to test the Arc Detection
Device:
4. Press test button. Unit should trip and reset
button will pop up.
5. Press reset button again for use
If above test fails, stop using the air
conditioner and contact customer service by
calling the following toll-free number:
1-800-332-6658 or email:
customerservice@fedders.com
I hope this helps & good luck!
Aug 30, 2011 | Heating & Cooling
We have a ESA406K-L Haier 6000 btu and the reset button keeps tripping are air conditioner will not turn on at all.
Is this reset on the plug? if so its likely bad, bypass and test, if it works get another end or wire to a fused disconnect which would be jn place of, unorthodox, but safe.
Aug 30, 2011 | Haier hwr10xc6 Air Conditioner
Just put air conditioner back in for the summer.. plugged it in and ran a test on it then nothing... any suggestion why it wont turn on..
Could have quite possibly tripped the circuit breaker. If it is a 230volt unit, there will be two breakers, they are usually joined together and probably 20 amp. Trip them all the way back and then all the way forward. If it is a smaller 120 volt unit there will only be one breaker, more than likely a 15 or 20 amp. Hope this works. Also, on newer models the plug may contain a reset button. It will be right on the head of the plug itself.
May 13, 2011 | Haier hwr10xc6 Air Conditioner
The power plug keeps tripping. when i press the button on the plug. it just trips.
Either there is something wrong with the unit or you have something else plugged into the same circuit. Air Conditioning units draw a lot of power and will trip a breaker if there is a moderate load on the same circuit. Try plugging it in to an outlet that you know doesn't have anything else on it. The other thing you can do is see what else turns off when the breaker trips, that will tell you what else is on the circuit.
Sep 15, 2008 | Haier Heating & Cooling
Faulty safety power cord...
You can by-pass it by simply connecting the 2 wires together. Obviously the safety it is supposed to protect you from will not work, but it can get you by instill a replacement can be found. It seems like the surge burnt the coil out on the switch. If you are conscious of the heater and what its going ,you should be safe. They made these things a long time without a trip switch on the cord. It just requires some common sense.
Mar 10, 2008 | Haier hwr10xc6 Air Conditioner
Haier window air conditioner
I suggest you check the ground of the wall socket. Many three proung sockets are not grounded.
Sep 03, 2007 | Haier hwr10xc6 Air Conditioner
Heating & Cooling Logo
320 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
