Error code c2152 Copier displays malfunction detected and gives an error code c2152
2 Suggested Answers
SOURCE: Error code c2152
good to
Imax Konica Minolta C451 Bizhub
I have a problem is the cod C2151 what to do Thanks
Posted on Apr 11, 2013
How do i Fix Error Code 2152 Konica Minolta Biz-hub
Code: C2152 Code C2152 Description Transfer belt pressure welding alienation
• During a retraction operation of the transfer belt, the transfer belt retraction sensor cannot detect the transfer belt at its retracted position within a predetermined period of time after the transfer belt retraction clutch is turned ON. • During a pressure operation of the transfer belt, the transfer belt retraction sensor cannot detect the transfer belt at its pressed position within a predetermined period of time after the transfer belt clutch is turned ON. Remedy 1 Check the M5 connector for proper connection and correct as necessary. 2 PS31 I/O check, sensor check. 3 CL7 operation check. 4 M5 operation check. 5 Change CL7. 6 Change M21. 7 Change PRCB.
Jan 29, 2015 | Konica Minolta bizhub Office Equipment &...
Can any one help m please, I have a Konica minolta bizhub C450 and i have a malfunction code C152, can any one tell me how to fix it please as soon as possibl thanks to all
i found this after a brief search
Straight from the service manual....just use the last 4 digits when doing a search, makes it easier to find the specific code as not all manuals are the same in how the code is displayed.
CC152 ROM contents error upon startup (Scanner)
• A fault is detected in a sequence of ROM contents check of the PWB-C during starting.
16.5.79 CC151: ROM contents error upon startup (MSC)
16.5.80 CC152: ROM contents error upon startup (Scanner)
16.5.81 CC153: ROM contents error upon startup (PRT)
16.5.82 CC154: ROM contents error upon startup (PH)
1 Check the ROM version. - -
2 Rewrite the firmware. - -
3 Replace the appropriate board.
TSB entry
Description
C-C152 at power up, the counters display as 0 and the operation panel display is in Japanese.
Solution
CAUSE: Main body firmware is corrupt.
SOLUTION: Flash or re-flash the firmware to the latest level.
As for the 2152 code,
16.5.6 C2152: Transfer belt pressure welding alienation
Dec 04, 2014 | Konica Minolta bizhub Office Equipment &...
Error Code C2152
Transfer belt code was it replaced properly?
Apr 17, 2014 | Konica Minolta Full Set For Bizhub C220...
Error code c2152
no such code in the service manual
Jan 31, 2014 | Konica Minolta Bizhub 362 Copier
Whats the problem if code C04 come from Minolta EP1083
The error code is displayed in 2 section on the display on the zoom dosplay and the number display.
C0400 Exposure lamp malfunction.
C0410 Exposure lamp thermistor malfunction.
Verify the exposure lamp continuity and the thermistor continuity.To reset error code open the copier and press the reset microswitch located on the rear PWB panel ,close the machine front door.
Jun 02, 2013 | Office Equipment & Supplies
Hi, oce 3165 machine is giving error 1104,kindly help me get a solution to this
Output OP paper rejection roller drive malfunction.Try to reset the malfunction code to Open/close the front door.If not reset:
Turn OFF the copier.
Press and keep pressed the Utility key and turn On the copier.
Keep pressed the Utility key and wait while Trouble reset message displayed.
Release the Utility key and touch the message.
Turn OFF the copier ,wait 1 minutes and turn ON.
Apr 19, 2013 | OCE 3140 Copier
What is it when display reads malfunction code C2654 on a Konica 351 copier?
C2654 code means Black Imaging Unit eeprom access error.
A condition of "EEPROM is not connected" or
"There is an access error" is detected in
EEPROM of the Imaging Unit.
So the issue lies within your Black Imaging Unit. I would try sliding the imaging unit out partially, then re-installing. Reset by switching off the main power.
If this does not solve the error then you will need to call your local service provider.
Good Luck and Thank You for using Fixya.
WheatlandServices
Sep 29, 2010 | Konica Minolta DiALTA Di200 Copier
Error code c2152
good to
Sep 24, 2009 | Konica Minolta bizhub C450P Laser Printer
Error code C-2152 on C351 Bizhub All in One printer
C2152: Transfer belt separation
it seems that it the you transfer belt. to be sure, take the old one into the copier, swith off th copier, with 10 seconds or more, then swith on. the error code will disappear :-)
Dec 11, 2008 | Konica Minolta bizhub C351 All-In-One...
Copier not working
Is the copier a Minolta? If so what model there are different ways to rest code.
Feb 09, 2008 | Konica Minolta DiALTA Di200 Copier
19 people viewed this question
jasbo
jasbo
