Question about Internet Computers & Internet
My desktop become very slow also internet to , i have diskspace enough ,there are no virus on it ,what can i do toget my speed back ,? thank you
Before it was fast working but now when i open something it takes to much time to open even on internet it's became slow
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Clear cache and temp files.Also try to get more free space for ram.close unnecessary opened files.
Posted on May 16, 2017
  • Internet Master
  • 10,045 Answers
Clear cache and delete unnecessary files. Cleaning the registry will help too. Go download a program called Ccleaner. It will work wonders for you.
    Top Expert:
  • Internet Master
  • 48,226 Answers
Make sure that everything is backed up on an external hard drive as it indicates a failing hard drive
check for an internet speed problem as well
  • 878 Answers
SOURCE: Ice Maker too slow
bayfishr, I'll try to give you an idea on how this thing works and let you do some checks. The cycle is controlled by temp. The harvesting process begins when the IM thermostat closes signaling the harvest temp has been reached. The closed thermostat supplies power to the IM motor and heater. Therefore the colder you keep it, the faster the production unless something has failed. I see a lot of heaters fail. You can test this. When the IM starts it cycle, test the voltage from L to H on the module,they will be marked. Should read 120V. The heater on the bottom of the mold should be getting hot. Disconnect the harnes and ohm it. Should ohm out at approx 72 ohms, same test points. If this checks good, check the center wheel on the module itself. Two clips keep the wheel in place. If one is cracked off, the IM will not fucntion properly. Other than colder temps, there is no way to adjust the speed of the cycle. Keep the flap in front of the ice-maker down so that the cold air is drawn across that IM. Catriver.
Posted on Aug 06, 2007
  • 233 Answers
SOURCE: My Dell Dimension E510 is
So what could make "whirring" sounds in a computer? Motors. What has motors? Fans, Hard Disc Drives, Floppy Drives and CD/DVD ROM Drives. I can't think of anything else. It doesn't sound like a CD/DVD/Floppy drive because you would only hear the noise when it is being used. You blew out the dust but that didn't help? So either a fan is going bad or the HDD is going bad. Listen inside the case and see if you can pinpoint where the noise is. If you can get your hands on a stethoscope use that. If it is the fan in the power supply it would probably be easiest to replace the power supply. The other fans are easy and cheap to replace. If the noise is from the HDD back up your data ASAP and go shopping for a new one. It can not be repaired. If it is the cooling fan for the processor replace that quick too because if it dies you could burn up the processor. Good thing you caught this before damage is done. I will assume this is not some sort of interference coming through the speakers but stranger things have happened. Also check to see if anything inside the case, like wires, might be brushing against the the blades on one of the fans. That is all I can think of right now.
Posted on Jan 02, 2009
  • 763 Answers
SOURCE: Slow Internet Browsing
sir better to contact your ISP provider or internet provider about this. Sometimes heavily load on their connection will slow the speed of the internet. i experienced that myself.
thank you for using fixya
Posted on Jan 19, 2009
  • 1912 Answers
SOURCE: slow download and upload speed
to speed up both download/upload delete all temp files, clear cookies after doing this try both download/upload speed tes here
Posted on Jul 06, 2009
  • 581 Answers
SOURCE: slow internet at 120 Kbps but fast connection at 54 Mbps Why
54 Mbps is the speed between your computer and your wireless router. The .8 Mbps is the speed of your connection between the router and the internet. You should call your ISP and ask what your speeds should be; there could be something wrong on their end or your modem might be malfunctioning. It's also possible that your WiFi connection itself has a weak signal. That can be corrected by moving the router and the computer closer together, or getting a signal relay and putting it between them.
Posted on Jan 22, 2010
My computer is getting really slow now. what can i do?
Actually sir there are a lot of reason why a computer becomes slow..First because of viruses, secondly your computer is very populated with files and applications and your hardware devices cannot accommodate it. But since you're connecting to the internet i know you have a good antivirus..perhaps i recommend you to try this 1. examine your files and application and choose the files you frequently used and not frequently used. 2. delete unwanted files and applications that you already didn't use so that it will free hard disk space and virtual memory of your computer. 3 go to recycle bin and empty it. freeing hard disk space and virtual memory can help your computer perform much faster...Reply to this post if your problem are not solved..Tnx for using fixya..
Jul 23, 2011 | Microsoft Windows XP Professional With...
Outside factors that affect connection speeds Unfortunately, there are events...
Outside factors that affect connection speeds <p>Unfortunately, there are events and conditions that are outside your control. Even with a fast connection, external factors, such as busy websites or spreading computer viruses, can slow the entire web. Popular websites can become overwhelmed with users. For example, when a television commercial mentions a website, many people might try to visit the site at the same time. If the website isn't prepared to handle the traffic, you might encounter delays.<br /> <p>During times of heavy computer virus outbreaks, the Internet can slow down. Many viruses spread by causing computers to send out hundreds or thousands of copies of the virus. This can slow the Internet by sheer volume. You can see what major outbreaks are currently happening by visiting your antivirus vendor's website, or the <a href="">Security at Home</a> website.<br /> <p>Local Internet congestion can also result in slower-than-normal connection speeds. These slowdowns occur when many people try to connect to the Internet at the same time, and they occur most often at peak activity times, such as after school hours when students get home and connect to the web.<br /> <p>If you're on a corporate network, general network and proxy server use can affect your Internet performance. Most network administrators monitor Internet use, and will try to keep people from doing things like downloading large files during peak hours. If you find that your Internet access is slow at times, you might discuss it with your network administrator.<br />
on Dec 03, 2010 | Computers & Internet
Usually motherboard either works or doesn't work. It won't make computer runs slow. Your computer runs slow mostly because of low memory, low diskspace available, driver issue, virus, or spyware. If you surf the web a lot, chance is your computer got spyware or malware. Install a free malware program and use it to clean up your laptop first to see if the problem is improving.
Apr 05, 2011 | ASUS Motherboard P5sd2-vm
My samsung galaxy 3 has become very slow any solution please?
There can be many reasons. One of them may be you don't have enough free space in your phone or memory card for the processor to operate. In that case deletion of some unwanted files and creating some free space will bring the speed back to normal. Secondly, it may be a virus attack which slows down your unit. In this case, you can go for a virus scan and clean up your cell so that the speed returns back to normal. Once your cell gets cleaned of viruses, it's better to delete the affected files (provided they don't include the system files) and uninstall the anti-virus software as this can also slow down your cell.
Hope this one solved your problem. If you have additional doubts, please come back to us.
P.S: If the solution is helpful, please accept the solution.
Feb 14, 2011 | Samsung Cell Phones
My nokia 2700 is very slow how can i increase its speed & how can i keep it virus free. when i use INTERNET on mobile is there any virus problem?
hello,its not possible to increase the speed on your own,it can only be done by your service provider,tis is caused simply by a poor server or poor network.
Secondly,you can download an anti-virus to make your mobile phone a virus free phone from the site below
Thanks for using fixya,
Take care.
Apr 10, 2010 | Nokia Classic 2700 Cell Phone
The lights of the internal modem, which used to be green, now just keep red/orange.... therefore no more internet... could it be a virus?
Good day sir/maam, the orange led indicates a speed of 10 mbps, which means that either the internet becomes slow or your connected to a hub with 10 mbps. better swap a new modem card, anyway its cheap. or get a DSL.hope this helps.
Oct 06, 2009 | Dell Dimension 9100 PC Desktop
My Pc Very Slow Pls Ideas
There are a number of issues might be affecting your PC's performance, some are dangerous while others not that serious. Learn why and how you can speed it up easily from:
Should help you out, regards!
May 28, 2009 | Computers & Internet
Computer slowed down considerabily.
Check whether this is not a viral slow down. If not i suggest this
1. Give enough space to the hard drive.
2. Uninstall unused application for a long time and not needed anymore.
3. Install Ccleaner, this can clean your registry, cookies, and other junk files.
4. Defragment your drive. If you have enough space already.
May 03, 2009 | Computers & Internet
Slow download speed
see the problem could be that u have either a slow internet connection.
other wise ur computer could be filled with viruses and Trojans.
do a spyware check and an anti virus check
u might find lots of them
u could also download(i know if u have a slow speed this will feel bad but.....) "tune up utilities "
do a Google search
it has functions to optimize internet browsing and downloading speed..
hope this works
Nov 02, 2008 | Computers & Internet
WD3200ME-01 Passport size diskspace problem
To format the drive to allow files larger then 4GB: Open up My Computer, Right click on the Western Digital Drive. Select Format from the list. Under file System, select NTFS. Under format options Check Quick Format. Click Start to format.
Warning! Formatting will delete all data and files on the drive. Make sure to transfer all your files to another drive before preforming a format!
Jul 03, 2008 | Western Digital 320GB MyBook External USB...
Computers & Internet Logo
24 people viewed this question
Laxman Bisht
Laxman Bisht
