Question about Coby Televison & Video
Coby tv volume on 4 is so loud remote does not control it. Turn volume to 3 no sound
SOURCE: TV ILO 26HD
Hi, We are a tv shop in cin ohio. A client of ours had same problem with his set. The part number they gave us for ILO-26HD is e22556. It is board and must be replaced and is reasonably priced. Call this number 909-392-5583 x130 they were really helpful.
Posted on Sep 06, 2007
cezirkle
  • 27 Answers
SOURCE: sony tv codes
Greetings...
What is the number for the TW remote you are using? 8400, U62R, 2000? Which TW cable service in NY... NYC, NY & NJ, Albany, etc...?
Ed
Posted on Apr 03, 2008
gurutim
  • 68 Answers
SOURCE: Loud hum with static when speakers turned on
There is def. a loose connection somewhere in your system. This is a grounding problem within the system if nothing else. Def. a "lazy" connection somewhere.
gurutim
Posted on Mar 21, 2009
andy4254
  • 226 Answers
SOURCE: Remote control has stopped working.
your remote needs to be put back in TV mode. press the tv button or slide the switch to tv
Posted on Apr 28, 2009
  • 53 Answers
SOURCE: LG LHB953 Theatre system volume control with comcast dvr 3
Try the help menu in the comcast remote. I believe you have to program it again for the LG to work the sound.
Posted on Jan 02, 2010
Code for my coby TV with an rca remote
Did the television come with a code?
Jun 27, 2017 | RCA Televison & Video
My COby tv wont turn on.
I unplugged my TV for 5 minutes after 5 minutes I pressed the Power button on the side of the TV not the power button on remote for a full minute. Plugged the TV back in, pressed the power button and it turned on. Doing this essentially does a reset.
Dec 26, 2016 | Coby Televison & Video
My coby tv won't turn on or control the volume with ether cable remote or original remote
Hi, we had that problem the first two days we purchased our set. Fortunately they replaced it with no problem. I hope you purchased an extended warranty, Coby is out of business but warranties are still being honored...I don't know of a fix for this..Basically the Coby is a dud..I wish you the best! let us know how it turns out..
Herb
Jul 27, 2014 | Coby 40 TFTV4028 LCD TV
Volume for my COBY 32" Television is out to whack.
Your volume control/circuits are fubar. Coby is outta business so getting parts for it might prove next to impossible.
Jul 20, 2017 | Coby Televison & Video
Coby 32" Television, Volume is messed up.
Coby is apparently out of business.
Feb 12, 2014 | Televison & Video
I need the TV remote code for a coby tv
Here are the codes for your Coby TV: 500, 503, or 00.
I have provided instructions on how you can program the remote to your TV:
  • Remotes: Basic (Television Only)
    1. Turn the Television On.
    2. Press and hold the clear TV button for three seconds until the LED flashes.
    3. Enter the three-digit code using the buttons on the number pad.
    4. Press #. Note: The LED will flash three times.
    5. Test functionality with the TV.
    6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Aug 17, 2011 | DISH Network 721 DVR Remote Control
I just bought a Coby home theater system 5.1 surround sound dvd/cd/ player model#765. I've got it all hooked up but I have one problem, when I want to listen to my tv stations through the home theater...
Hi - Your Home Theater System and your TV should have separate volume controls. You should be able to control each individually. Start by checking the volume level on your TV with your HTS shut-off. Turn the volume on your TV all the way down to 0.
Next, turn your HTS on and check the volume level there. Is it still loud? If so, try turning the volume down on your HTS. That should do the trick. If its not loud then you know you can control the volume on either the HTS or the TV. If this answer does not help, then please write us back with a little more detail. Thanks.
Feb 28, 2011 | Audio Players & Recorders
I just bought the coby csp96 surround sound package and am having trouble hooking everything up. It came with the dvd player to hook all the input cords to, which i did. Everything is working accept when i...
there is a nobb on the subwoofer, one is to dial down or up the sub (noob1) , and the other is to dial up or down the 5.1 speark (noob 2). turn noob 2 to the left to dial down the sound, first time i got my setup it was totally down, btw the 5.1 works wonderous if you use a home theater system. Iam using a 1,000watt sony home theater system. 100/200watt RMS per channel at 5 channel those little speakers really can handle well, I never experiance any blow outs :) Coby outdid themselfs with this system
Sep 05, 2010 | Coby CSP-94 Speaker
Very little volume, not very loud at highest
On the TV-use your finger to adjust the volume level, about midway, then use the remote to shut off the tv, then turn on tv with remote. Volume level should be better! If still not loud enough...using your finger on the tv...turn up volume & repeat remote steps.
Jan 19, 2010 | Universal Remote Control DIRECTV Universal...
POLAROID 37" TV - VOLUME STUCK ON LOUD - CAN'T TURN UP OR DOWN
sound like the volume is locked out you can access this in the main menu to unlock it
May 29, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Televison & Video Logo
24 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
