Question about Brother Sewing Machines
How to remove casing on Brother NX400 sewing machine
SOURCE: Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Posted on Jun 23, 2008
SOURCE: My Disney Brother SE-27OD Embroidery Sewing Machine/trouble
Can you buy embroider memory cards with out down loading on your PC?
Posted on Jan 15, 2009
  • 128 Answers
SOURCE: bobbin case on brother sewing machine
Well, from the picture I see that your bobbin is a front load as opposed to a top load.. if you tilt the front panel down, you will see where the bobbin and casing goes. Put the bobbin in the casing with the thread pulling from the right hand side of the casing making sure the thread in guided into the small **** on the top edge of the casing.. On the back of the casing the will be a small tab. Pull that away from the casing and enter the casing in to the opening for the bobbin. It should snap into place when you release the little tab.
Posted on May 29, 2009
SOURCE: manual from brother listed sewing machine
I believe these are the UL code and serial number. If there is a display band of decorative stitches on the front of your machine look on the bottom right of that panel. If the number there is a VX-920 there is no manual available for it BUT you can use the manual from the VX 970 which IS available. Do a search for that model manual in Spanish and you should find one.
Posted on Aug 03, 2009
  • 980 Answers
SOURCE: brother sewing machine circuit board is out need new one
If you have any problems with sewing machines with electronic boards or if the machine is computerised it is wise to take it to a specialist for repair.
Posted on Nov 04, 2009
How to remove sewing bed where fabric lays when sewing to get to bobbin area of Brother LS - 2020 sewing machine
Lower bobbin threading Brother
  1. Turn the power switch to "o".
  2. Raise the needle to its highest position by turning the balance wheel towards you (anti-clockwise) and raise the presser foot lever.
  3. Open the shuttle cover behind the extension table on the the front of the machine and remove the bobbin case by pulling its latch towards you and pulling it out of the shuttle race. (fig A).
  4. Unwind about 10cm (4") of the thread from a full bobbin and insert it into the bobbin case. (see fig B-1). Pull the trailing thread into the slot then down and to the left, as shown in fig B-2, until it enters the delivery eye under the tension spring (fig B-3).
  5. Holding the bobbin case by the latch, fully insert the bobbin case into the shuttle race and release the latch. Make sure the bobbin case finger fits into the notch at the top of the race as shown in fig C.
Sep 13, 2016 | Brother Sewing Machines
Machine locked up with needle down in the machine
If you can, try to remove the needleplate and the bobbin case from the machine. Once the bobbin case is removed, the needle should be free.
Embroidery Problems Brother Sewing Machine
Dec 05, 2015 | Brother PE-500 Embroidery Machine
How do I remove the outside case for my Brother xl 5340.
If you do that, you'll void the warranty on the machine. You may already have. If the "turning wheel" (handwheel) is stuck, then most likely either the machine has seized from lack of lubrication or thick lubricants, or you've got a heck of a thread jam going on in the bobbin case and feed dog area.
Feb 14, 2014 | Brother XL-5340 Mechanical Sewing Machine
Brother NX400 SEWING MACHINE after changeing thread top and bottom it now makes a nocking noise?
try rethreading the machine again, make sure to use every thread
make sure to not over fill the bobbin
make sure the bobbin is inserted correctly into the bobbin
case, this is very important
make sure the bobbin is turned the correct way in the bobbin case
the machine won't work right if the bobbin is not turned the right
clean under the needle plate and in the bobbin area for lint
Nov 02, 2012 | Sewing Machines
Machine is showingE6
The motor locked up because the thread is tangled. Remove the tangled thread before continuing the operation.Clean the bobbin case to remove the tangled thread. After cleaning the bobbin case, insert the bobbin case properly. If the needle is bent or broken, replace the needle.Then, thread the upper thread properly, and continue the operation.
Sep 22, 2012 | Brother CS6000i Computerized Sewing...
How to remove brother XL2230 sewing machine case
Take off the panel that conceals the lamp (see your instruction manual) and you will see another screw that needs to be removed before you can take the larger back panel off.
Jun 15, 2012 | Brother XL-2230 Mechanical Sewing Machine
No problem, go to a Brother repair shop and buy one.
Feb 11, 2010 | Brother XL3750 Mechanical Sewing Machine
Sewing Machines Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
