Question about Vehicle Parts & Accessories
93sc400 timing set up,i ,replace the timing belt,water pump sarter,stll no start my plugs all are full of gas
What are your expertises
  • 917 Answers
-check all the timing marks are properly
-check the two ignition coils connection
-check the crankshaft pos sensor connection
-check behind two cam sprocket sensor connection
Posted on Jul 13, 2017
michigan man
  • 3533 Answers
SOURCE: Do I change water pump when having timing belt changed
I would go to auto zone and get a diagram and the timing belt and do it yourself and the water pump (no it does not have to be changed everytime the timing belt is changed but if the car has over 60,000miles then it is best to change them both) it is not that hard especially if the car is not out of time just make sure you disconnect the negative side of the battery
Posted on Jan 21, 2009
  • 2920 Answers
SOURCE: timing belt and water pump
every 50000 miles
Posted on Feb 24, 2009
  • 477 Answers
SOURCE: engine cranks car won't start
Sorry..... 1 notch off is just not good enough. It has to be exact , then if it doesn't run start looking at other posibilities.
Remember that the camshaft turns twice eash time the crank turns once. The distributor rotor works off a gear on the cam.
Your rotor could be off a bit , or it could look exactly perfect the way it was when tou took it out , and still be 180 degrees off.
You have to get your engine to "top dead center" and make sure everything is the way it should be.
A timing chain ( or belt ) can cause permanent and fatal damage to the valve train and pistons in motors that are "interference engines" Find out weather yours is. In a non-interference engine , the clearance between the valves and the pistons is large enough to alow them to move out of time without crashing into each other. An interference engine is not so forgiving.
The fact that your engine cranks makes me hopefull that it is a non interference engine , and that damage has not been done.
Try to find a haynes manual for you vehicle , it will walk you through the steps for most repairs.
Posted on May 10, 2009
  • 7 Answers
SOURCE: Timing Belt Problem-6 cylinder Saturn wont' start
If your timing belt broke, then it is possible that the valves in your engine got bent, which won't allow the cylinders to pressurize the fuel/air mixture, and it will let all of the mix to flow freely into the intake/exhaust manifold. This can be checked with a pressure tester that is threaded into the spark plug opening. A mechanic should have one, or you can probably find one at an auto parts store.
Posted on May 21, 2009
SOURCE: Car all of a sudden started overheating. Already
The thermostat is the most likely problem and also the easiest/cheapest to replace. You could also start by checking the fuse for the electric engine fan, if it is good you could try to disconnect the fan and run 12v ( + and -) to it directly from the battery. It should turn on.
Posted on Jun 27, 2009
1999 Corsa B 1.6i my timing jumped and since then
Since you have replaced most of the engine parts I would check you are getting a spark at plugs first and then fuel from pump! I think these are the most probable reasons for not starting!
Oct 18, 2014 | Cars & Trucks
I have a ford escort Zx2 2000 and my water pump is leaking bad I have lost pressure when I hit my gas pedal inorder to replace my gas pump do I have to replace my timing belt as well?
If the water pump is leaking, it needs replacement. Timing belt is replaced at certain mileage intervals . You can have the belt inspected by a garage. The timing belt does not have to be changed to replace the water pump. If a timing belt is changed, then it is standard procedure to change the water pump, since the water pump is removed when replacing the timing belt.
Mar 22, 2014 | Cars & Trucks
Time to replace timing belt, should i go ahead and replace water pump and all other seals gaskets
Not only Timing belt, water pump and seals, but Belt Tensioner and any other pulley that holds belt in path. Full replacement kits include every thing that MUST be changed. Proper belt tension needs to be set, unless tensioner is based on spring, but adjustable tensioners need to be set correctly. Amclaussen.
Nov 14, 2013 | OEM 2003 Kia Optima Shock, Rear wmt27218...
Trailblazer won't start after water pump relacement
Many a times the problem occurs due to timing not adjusted,in many cases the timing belt also needs to be replaced while water pump replacing.
Or its also possible that water pump not replaced properly or timing got mistimed.
I suggest you to check few help links.-----------
For water pump replacement i suggest you to check the help link provided below.
click the link below :----
Water pump replacing procedure for all vehicles?
How to route Water Pump Belt for 1992 Oldsmobile ?
How to replace Water Pump on Car ?
How to Remove Water Pump?
Where is Water Pump located ?
Below is the master help link provided to go through belt routing diagram:---Timing belt, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
Click the link below: ----
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
This will help.
Jan 26, 2012 | 2004 Chevrolet Blazer
I have a 99 chrysler 300m that does not start, it sounds like it's out of gas but there is gas in there.. The diagnostic says the cam & the crankshaft sensors are bad but they have been replaced 2...
I am not saying that this is your problem for sure, but have you had your water pump and timing belt replaced lately?? I had the same car and it would crank and crank but would not start. I replaced both my cam and crank sensors also. Eventually I tore into it and found out that my timing belt had broke.
What happened to mine is the water pump (inside the timing cover powered by the timing belt) leaked and the coolant messed up my timing belt and the timing belt finally snapped.
I replaced water pump and timing belt and luckly the car did not have any bent valves. Just to help out I would not try and crank the car anymore until you know for sure that your timing belt is intact. If it is bad and you go in to replace it I would do the water pump while you are in there. It will save you trouble and is a really easy job.
Good luck and I hope the best for you!!
Mar 08, 2011 | 1999 Chrysler 300M
How do you replace a water pump in a 2.5L V-6? Step by step.
2.5L Engine
  1. Disconnect the negative battery cable.
  2. Place a large drain pan under the radiator drain plug. Drain and properly
    contain the engine coolant.
    NOTE: This procedure requires removing the engine timing belt
    and the auto tensioner. To help assure proper alignment at assembly, it may be
    helpful to set the engine at TDC on No. 1 compression stroke. This should align
    all timing marks on the crankshaft sprocket and both camshaft sprockets.
  3. Remove the accessory drive belts and crankshaft damper.
  4. Remove the right engine mount. This requires safely supporting the engine
    with a floor jack and wood block so the mount can be removed.
  5. Remove the timing belt covers.
  6. Remove the timing belt and tensioner.
    Fig. 3: Remove the water pump mounting bolts
    Fig. 4: Pull the water pump assembly off of the engine and
    inlet pipe
    Fig. 5: Open the water pump housing and examine for cracks or
    Fig. 6: Replace the water pump housing gasket using a scraper
    Fig. 7: Always keep the water pump's mounting bolts lined up
    with their correct mounting holes
  7. Remove the water pump mounting bolts.
  8. Separate the water pump from the water inlet pipe and remove the pump.
    To install:
  9. Thoroughly clean all sealing surfaces. Inspect the pump for damage or
    cracks, signs of coolant leakage at the vent, and excessive looseness or rough
    turning bearings. Any problems require a new pump.
  10. Install a new O-ring on the water inlet pipe. Wet the O-ring with water to
    make installation easier. DO NOT use oil or grease on the O-ring.
  11. Install a new gasket on the water pump and fit the pump inlet opening over
    the water pipe. Press the assembly together to force the pipe into the water
  12. Install the water pump-to-engine bolts and tighten to 20 ft. lbs. (27 Nm).
  13. Install the timing belt and timing belt tensioner. Set the timing belt
  14. Install the timing belt covers. Install the right engine mount. Remove the
    floor jack and engine block from underneath the engine.
  15. Install the crankshaft damper.
  16. Install the accessory drive belts and set to the proper tension.
  17. Connect the negative battery cable.
  18. Fill and bleed the engine cooling system.
  19. Start the engine and verify proper operation, with no leaks.
Oct 29, 2010 | 1996 Dodge Avenger
How do you replace the timing belt?
Not going to like my answer here, but without any expertise in auto mechanics, I would caution you to let someone else do it. In most cases, (don't know this specific car), involves removal of water pump, pretty extensive work. And often should do other work at same time.
(as an example, in 1990s Honda Accords, it was advised to change the water pump when replacing the timing belt. All of the labor was already there, just a "relatively" small charge for the water pump itself.)
Instructions to change a timing belt would be to difficult to post here. If you have a strong desire to do it yourself, get a manual like Chiltons or Hayes with instructions and pictures.
Jul 30, 2009 | 2001 Hyundai XG300
Car wants to start but can't get gas
does the water pump run off the timing belt or auxillary (fan) belt? maybe timing belt has slipped some teeth?
Jul 27, 2009 | 1984 Mazda B-Series
Vehicle Parts & Accessories Logo
115 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
