Question about Sewing Machines
My decorator's choice isn't stitching. It's feeding and all but threads not coming together to form stitching. what am I missing?
  • Ruth Andrews
    Ruth Andrews May 16, 2017
    I was using my machine just fine, then stopped for a bit. When I resumed, it wouldn't form stitches. I don't recall doing anything different. I turned it off and back on, rethreaded both the upper and bobbin threads, cleaned lint out of bobbin area, etc. Nothing changed. Still not sewing. It comes on and sound fine, and feeds the material through but without actually sewing. Really would appreciate any help.
  • Sewing Machines Master
  • 12,515 Answers
Install a brand new needle. If that doesn't work, then the machine may be out of time.
Posted on May 16, 2017
Testimonial: "Thanks I did that to no avail. I resorted to customer service."
    Top Expert:
  • 51,255 Answers
Needle thread tension is not tight enough
it could be needle hook timing is out
Adjusting top and bottom stitches...
the stitch length is set by the amount the foot pulls the material through
adjusting the needle thread tension is the main adjustment to ensure that both threads meet at the center of the materials being sewn
Mar 10, 2017 | Sewing Machines
I cannot get the green decorative stitches to work. I'm insure if my Bernina 930 is broken or I'm just unfamiliar with this machine. How do I set my machine for the embroidery stitches?
There are 2 levers on the top that need to be set. One shows the green stitch selections. That needs to be set to your stitch choice. To its right, there is another lever called the "changeover lever." It needs to be pushed all the toward the back of the machine--that switches it from straight stitch to decorative stitch.
Then on the bottom front on the right is a large knob. Both the outer ring of the knob and the inner knob perform different functions. One drops the feed dogs for darning or raises to activate the feed dogs to pull the fabric through the machine. The other part switches between the red and green stitch selections. When that knob is turned the light should show green or red to coordinate with the stitch selection lever on the top of the machine.
So to make decorative stitches, there are 2 levers that need to be moved plus the red/green activator knob. In addition, you will want to adjust the stitch width dial and the stitch length lever to widen or lengthen the stitch.
If you need a manual for your machine, you can download it free here:
BERNINA Support Machine and Accessories Finders and Software Support...
Apr 07, 2016 | Bernina Sewing Machines
I am having troubles with the decorative stitches bought used
Difficult to diagnose. Try a brand new needle that is compatible with the thread and fabric.
All About Needles
If the machine is mechanical, it may need cleaning and oiling if the decorative stitch mechanism is sticking.
Feb 23, 2016 | Sewing Machines
I have decor pro99 and it is not sewing button holes properly it's missing stitches and just before the end it just gathers up
The link below features 3 different videos on YouTube for you machine. Maybe there is something there that will help.
Google
Mar 09, 2015 | Sewing Machines
All my decorative stitches are comming out straight
it sounds like something has happened to the cam gears that
do the decorative stitches, which means the sewing machine needs
to be checked..
but before you have the machine checked,, make sure all the
dial that are used for decorative stitches are at the right setting
one missed setting can cause a lot of problems
Nov 02, 2012 | Singer Sewing Machines
I want to sew two pieces of fleece together and put blanket binding on with a decorative stitch. (Making a baby blanket). Thread breaks or skipping stitches. What needle and thread combination should I...
Take a look at the chart on needle and thread I posted as a tip, but generally, you'll need to use a larger needle, something like a 14 or maybe even a 16, but you shouldn't need heavy-duty thread.
Aug 03, 2010 | Brother NX-400
What is the purpose and use for feed balancing dial?
The feed balancing dial is for adjusting some decorative stitches that do not form correctly because of the type fabric being used, for instance, the stitch seems too close together to form the design. You would turn the balance towards the plus side. It will also affect the buttonhole sides, if one side seems different in stitch density than the other then you would adjust the balance.
Jun 02, 2010 | Janome Memory Craft 4000 Sewing Machine
I need help in adjusting the feed dogs, they messed up when I adjusted the timing for the needle and bobbin.
When the sewing machine is properly timed, all the parts work together in a seamless flow of coordination. The needle moves from it highest point down toward the needle plate. The feed dogs reach the farthest point toward the back of the sewing machine. The feed dogs drop under the needle plate. This is just before the needle point reaches the needle plate. The needle continues to move down dragging the upper thread under the needle plate. It proceeds toward its lowest point.
The needle begins its rise back up. A loop of thread forms along the back of the needle. A special cut out on the back of the needle to accommodate this loop is called the scarf. The sewing machine hook slides behind the needle. The point of the hook slides into the thread loop and pulls the thread around the bobbin. The bobbin thread and upper thread wrap together. The needle and hook proceed through their actions under the needle plate. The feed dogs move under the needle plate from back to front.
The needle proceeds to rise again up out of the bobbin area exiting the needle plate. At the same time the feed dogs rise up out from under the needle plate. They begin to move from front to back as the needle continues to rise.
The thread from the bobbin flows through a bobbin tensioner providing resistance to the thread as it is drawn up by the upper thread knot. The upper thread is also under tension. This comes from the upper tension, thread guides, tension spring, and sewing machine take up lever.
The thread from top and bobbin grow increasingly tighter until they form a locked stitch in the middle of the fabric. This process is repeated for every stitch.
How do you adjust sewing machine timing?
The needle, hook, and feed dogs must move in harmony. If they fail to do so, the machine will not perform as expected. When the hook is just slightly out of time with the needle, you will notice skipped stitches. This may begin on only one side of the zig zag stitch or intermittently. If the timing is just a bit more out of sync, stitch formation will become impossible.
If the feed dog timing is out of sync, the fabric will not move through the machine as expected. Threads may bunch up or the fabric may just not move.
As you can see, timing is everything.
click on this link directly
http://www.fixsewingmachines.com/How-to-Adjust-Sewing-Machine-Timing.html
This will help. Thanks please keepupdated.please do rate the solution positively .thank you for using fixya
Jan 29, 2010 | Sewing Machines
The bobbin thread is bunching on the under side of the fabric,. Decorative designs are close together, not like the pattern and when I use the more intricate decorative designs, they just sit in a quarter...
Make sure that you use the F foot when using decorative stitches.
The stitch balance my be off. Remove the accessory bin and you will see a large plastic screw with a + and a - and an arrow. Using a coin, turn the arrow to the center and test. Turn the arrow towards the + to stretch the pattern out.
If this doesn't work, it must me calibrated internally and requires an experience hand.
Jul 07, 2009 | Janome Memory Craft 9000 Computerized...
Machine not sewing
Make sure you have threaded the machine from right to left, it sounds like the needle thread is trapped under the lower looper thread and cannot form a stitch.........start the threading over from scratch like this:
  1. Lower Looper
  2. Upper Looper
  3. Left Needle
  4. Right Needle
Is there a diagram for how to thread on the inside of the door ?
Follow that slowly and carefully to make sure you have not missed any thread guides on the way, as each one needs to be followed through to ensure correct tension and thread progression.
If you are certain that all threaded correctly, did you have a fabric jam and pulled it loose ? If so, the timing may well be affected.
Post an update and we'll get this right.
Bargain Box
Feb 01, 2008 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
