Question about Microwave Ovens
Ive got a chef Norfolk Deluxe oven. The both hinges on the handle for the oven has broken. Can these be replaced and where from?
4 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Another broken handle
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 09, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: My magic chef over the
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Aug 02, 2008
beltronic205
  • 1460 Answers
SOURCE: hotpoint BD81 Multifunction Double Oven,
Try Espares.co.uk, they also advise how to fit....
Posted on Feb 22, 2011
How do you take the door off? I too have a broken handle and door...
If only the door handle is broken, it can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
The door handle on this model has two parts (items 3 and 8). Depending on what is broken, you may only need to order one or the other. Both parts, combined, is still only about $20. The part numbers are WB15X10119 and WB15X10120, respectively.
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
NOTE: If you wish to remove the door, all you need to do on most models is open the door all the way and lift straight up at the hinges.
If you have any questions, please post back and let me know. I hope this helps you.
Jul 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How do I replace door?
If the model number is correct, the door on the microwave comes off by opening it all the way and lifting straight up at the hinges. The entire door will lift off the hinge pins and come off. You may have to remove the upper grill cover above the door to accommodate removing.
If this is a simple matter of just needing to replace the door handle, or broken panels, you can save money by replacing only the parts you need. The following link explains how to access and replace the door handle:
The average cost for a replacement handle usually runs about $20 - $40. Replacements (if required) may be purchased at the websites listed in the link I provided.
The door handle, or other miscellaneous parts are usually simple repairs that can be done with the door in place, or removed. And, you do not have to uninstall the oven if this is an over the range model.
What I have provided you with is the basic information that applies to most ovens. If you have any questions, please post back and let me know. I hope this helps you.
Apr 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The door handle on my GE Spacemaker XL model JVM1330BW 003 broke off so I decided to replace the entire oven. Can you recommend a replacement that will fit into the same recess and have the exhaust vent...
If the outer door is not broken. All you have to do is replace the handle. You will need to access the door handle mounting screws and remove them to replace the door handle. To access the screws on MOST microwave ovens, you must remove the inner door panel that goes around the perimeter of the glass. This can be accomplished by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel and pry the plastic up. Work your way slowly around the perimiter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful microwaves.
With the inner panel removed, the door handle screws are visibile and can easily be accessed with a screwdriver. Simply remove the broken handle and install the new one. Re-insert the inner door panel, gradually working your way around the perimeter of the door glass to ensure it snaps back into place and seats properly.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
You can view an exploded view diagram of your microwave at pcappliancerepair.com for reference. Just type in your model number and locate the parts listing for the door. The part number for the door handle is WB15X10020. If the outer panel is damaged, you may have to replace the entire door. The part number is WB55X991. The cheapest web source I have found the handle listed is appliancepartspros.com for $47. The entire door, however, sells for $110 at pcappliancerepair.com.
The RF inside the cavity of a microwave oven is actually controlled by the RF shield in the glass. As long as the glass is intact and the inner door facing is not bowed, warped or cracked, you will not have to worry about RF leakage (even with the handle broken off).
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Nov 03, 2009 | Microwave Ovens
Broken handle on Spacemaker microwave
The handle can be replaced without replacing the entire door, or oven. The part number is WB15X1309 and can be purchased at pcappliancerepair.com for about $45. Due to the age of your oven, I could only find it at a couple of web sites, and this was the cheapest price I could find for you.
The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a small hinge pin that has to be removed in order to remove the door.
Sep 08, 2009 | KitchenAid KHMS147 Microwave Oven
The door handle is broken on model khms 105ebl0 kitchenaid
Sep 04, 2009 | KitchenAid KHMS147 Microwave Oven
To remove inner door cover
The door handle can easily be replaced on most microwave ovens without the assistance of a repairman. This is a common problem with some microwave oven doors.
NOTE: Some ovens have a small hinge pin that will have to be removed in order to remove the door.
Aug 29, 2009 | GE Advantium 120 Convection/Microwave Oven
My magic chef over the range microwave oven handle is broken, i ordered the part online and have received the same. However I do no know how to remove the old broken handle and replace it with the new...
Aug 01, 2008 | Magic Chef Microwave Ovens
Need to replace GE Spacemaker XL1400 door
On most microwavre ovens all you have to do is open the door all the way and lift straight up at the hinges. The door comes right off the hinge pins. In some cases you may have to remove the top louver panel (right above the door). You should NOT have to unmount the oven to complete this. In fact...I would not recommend it.
Is this a simple matter of replacing a door handle? If you need to only replace the door handle, you just lift slightly on the INNER door plastic around the glass and you will be able to access the door handle screws. There are a series of small grooves in the panel that you can use a small screwdriver to gently pry. You should not have to remove the entire panel. Just open it enough directly behind the door handle. Be careful when prying on the plastic. It can break if you're not careful. I hope this helps you.
Feb 27, 2008 | Microwave Ovens
Fixing Microwave door handle
pop the plastic off inside door you will see 2 screws that hold handle on or if your trying to get the door hinges off unscrew bottom panel to access bottom hinge screw and vent at top to access screws for top hinge
Aug 30, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Loose door handle
DON'T remove the cover yourself unless you fully undertand the SAFETY issues involved in working inside a microwave oven. A microwave oven is possibly THE MOST DANGEROUS common consumer product to service. Usually with these doors, the latching parts tend to loosen up at times, thus requiring some re-adjustment and tightening. Sometimes they get a bit warn and require to be replaced. The handle by itself about $40, apparently GE doesn't know how to make a door handle that will hold up for more than a year or so. I just bought a new door off of eBay for $20 + $20 shipping ... a deal compared to the $135 + tax and shipping that most of the web sites want! All you need is a phillips screwdriver and a 5/16" socket. To get to 3 screws that anchor the TOP hinge, simply remove the vent grill (open the door and remove the 2 white screws that hold it in place). To get to the 2 screws that anchor the BOTTOM hinge, simply remove the 6 screws that hold the grey bottom pan of the microwave in place. The pan will swivel down, remaining attached in the back panel. Once you've removed the 5 hinge screws, the door should pull pretty much straight out. Reverse the procedure with the new door, which should come with hinges attached. Could be that the place the spring sits in is a little broken, so theres no stop for the spring. open it up and see if there's anything you can do with it, try some epoxy putty maybe. Good luck
Apr 28, 2006 | GE JVM1330BW/WW Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
