Question about Craftsman Garden
Craftsman push mower with briggs and straton motor with electric start, starts but won't stay running and smokes when it starts
  • Todd Thompson
    Todd Thompson Jan 04, 2018
    check oil level....may be overfilled!
    Master:
  • 469 Answers
Make sure thee air filter is clean
Posted on Jan 02, 2018
    Master:
  • Craftsman Master
  • 645 Answers
The carburetor may be clogged. This carburetor should be able to be cleaned at a minimal cost. This would also explain the smoke.
lester482529
  • 226 Answers
SOURCE: MTD lawn tractor. 16 hp twin briggs straton
THIS SOUNDS LIKE A THROTTLE CABLE LINKAGE PROBLEM.WITH THE HOOD OPEN AND MOTOR RUNNING RUN YOUR THOTTLE UP AND DOWN WHILE LOOKING @ THE LEFT SIDE OF THE MOTOR TO SEE IF THE CABLE IS FROZEN IN PLACE OR BROKE OR DISCONNECTED .HOPE THIS HELPS
Posted on Jul 16, 2009
seanpwright
  • 2030 Answers
SOURCE: Briggs and Straton 8 hp, craftsman snowblower stalls
Sounds like you coil is over heating after running a few minutes. The windings are seperating, then when it sools they make contact again. Try replacing the coil.
Posted on Feb 05, 2010
  • 5 Answers
SOURCE: Mower started smoking, then stopped working.
Try to see if there is any oil in it. Or maybe your belt is clogged. A good cleaning and maybe a change of plug may help.
Posted on Mar 02, 2010
  • 221 Answers
SOURCE: Briggs & Straton 20 HP, two cilinder engine idle speed
Surging is usually caused by a lean condition You can try to turn the mixture screw ccw about 1/4 to 1/2 turn. If this does not solve the problem your carb will have to be removed, cleaned thoroughly, and reinstalled.
Posted on May 17, 2010
SOURCE: craftsman dls 3500 briggs and straton motor.
my craftsman dsl 3500 will start but wont move forward or backwards. whells wont turn
Posted on Mar 19, 2011
I have a craftsman yt3000 21 hp briggs and straton platinum engine. Its about four years old. The tune up kits have been used at the beginning of every season. It has started emitting blue smoke from...
Blue smoke usually indicates burning oil. There may be some residual oil in the cylinder that burns off when the engine is started. Do you use much oil when the engine runs? Keep an eye on the oil; level.
May 24, 2014 | Garden
Craftsman 6.75 pull start mower, briggs and straton engine. Won't start, makes a clicking sound when cord is pulled to start. Found some oil under the engine. How do I fix my problem to get this to...
sounds like there might be an unexplainable hole in the underside of the engine, possibly from engine being blown up, maybe it has been run low of engine oil?
Jun 21, 2013 | Garden
Model 917.370410 won't start
Sounds to me like this model is a POS. I also have this same model, purchased last August have used only 5 or 6 times , has the same symptoms: hard pull, puff of smoke, won't run , etc. Even brought this to an authorized dealer to get it to run, but then it only ran a couple more times, dead again. Does anyone know of any recalls fro this lemon? I can appreciate everyone troubleshooting , but you shouldn't have to tear apart a 5 month old lawnmower which will only result in your warranty being voided.
Oct 04, 2012 | Craftsman 675 Torque 190cc 21" Briggs ...
7Hp OHV Briggs & Straton Craftsman Front Propelled Smokes
Sounds like it is the valve seats. However normally it will stop smoking after is runs for a while if that is the problem. Does it run good? Because if it isn't the valve seats then it is the rings. Or a big scratch in the cylinder wall. Then most of the time it will loose compression. If it isn't smoking real bad then you can get an additive to put with your oil that will make it stop, maybe? It is about ten dollars and you can get is at most autoparts stores. It will just take a couple ounces of it. Follow the directions for how many qts of oil you have. After you change the oil in the motor take a magnet and run it through the oil and see if there is pieces of the rings in it.
Jul 12, 2010 | Briggs & Stratton Garden
May 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a 7hp briggs and straton craftsman self propelled push mower. It's a few years old but runs great, the only thing wrong is the self propelled part won't engage. I took it apart down to the axle but...
Could be a stretched out/broken belt, a worn out transmission or the drive teeth on the inside of the wheels could be worn out. I would start by looking at that. Remove the drive wheels and check for damaged or missing teeth.
Apr 20, 2009 | Craftsman Garden
Garden Logo
46 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
