Question about Safari Baby Gear
How do you fold up a aria mt safari stroller - Safari Baby Gear
SOURCE: Front wheel problem with Peg Perego Aria single stroller
You need to regularly lubricate the wheels...Just get some WD-40 with the little straw attachment & spray into where the wheel meets the frame...Make sure you lubricate the wheels regularly...I had the same problem & call Peg toll free - that was the answer & it fixed my problem too!!
Posted on Jul 31, 2007
SOURCE: Graco Quattro Tour Duo Stroller won't fold up
I called customer service at Graco and explained the problem, asked for a fix. The rep said the part is not replaceable and told me to send the stroller back to them for 'evaluation and/or replacement'.  They will pay to FedEx it back to them this week. So that is where it stands.
Thank you very much for your site and offering a chance to put the problem out there.
Posted on Jun 08, 2008
SOURCE: folding graco stroller
how to fix the strooles directions
Posted on Sep 27, 2008
SOURCE: cant fold my instep safari tt stroller
One-hand fold is not as quick and easy as it's name suggests. This model requires reclining seat all the way first, then step on the safety release lever (about shin-high) located above one of the rear wheel axles. While holding down safety release lever with your foot, then squeeze the one hand fold mechanism located near the parent console and the stroller will collapse. There is a lock bar/plate to hold stroller in place. It will not stand on its own in this position, but with the foot brake activated, will lean against something and stay in place.
Posted on Oct 26, 2008
SOURCE: fold stroller
Not sure how different this one is to ours but we have an older Dreamer Design double stroller and down by the front wheel there are two black plastic clips that you pull upwards while at the same time pushing two small depressable "buttons" that are in line with the main bars coming down towards the front wheel... once that's done you lift and push backwards at the same time, the whole stroller frame will move backwards (oh brake has to be on) and then once those main bars are free you can pull the frame towards you and then double it over back on itself...the rear wheels pull out by pushing the centre button and pulling on the wheel and they you're able to put it just about anywhere...hope that helps...Rob
Posted on Sep 22, 2009
I left this stroller outside on my porch for a few days in Florida heat and humidity and it has some areas of mildew. Can the cover be removed and laundered? If so, how? If not, is there a replacement...
You may not be able to remove the entire cover, but a good 50/50 water and vinegar solution will kill the mold/mildew. You can then follow it up with a scrub spounge and soapy water. After this the smell should be gone and the mildew killed.
Otherwise if you REALLY want to remove it you can look for snaps, velcro or zippers around all of the metal tubes that may release some or all of the canvas linings.
Gimme a thumbs up or a comment if this helps!
Gtaplytmpt
Jul 18, 2011 | Peg Perego Aria Twin MT - Safari Standard...
I have a baby stroller similar like this (Peg Perego). I bought it from a yard sale. I just want to know how to "fold down" this baby stroller. I hope it is similar to this model. ...
There are little finger/thumb grips right below the handles that you push with. Not the long oval thing, that adjusts the handle height, but little grips on front and back of the handle. On both left and right handles. you put your index finger under front one and middle finger under back one, (both sides at same time, use both hands) and pull UP on them while leaning the stroller forward to fold it down, push it down until it clicks.
Note: Don't pull the release clips manually.
Good Luck!
Jan 04, 2011 | Peg Perego Aria MT - Blue Moon Stroller
Peg Perego Aria Twin--lost side clip that helps fold stroller
go on the website. you might be able to order the part you need right off there site.
Sep 13, 2009 | Peg Perego Aria Twin Stroller
Hi, I have a peg perego, single child stroller, standard, Not sure which model. It has just a bar not a tray. Anyway, I CANT figure out how to fold it. Theres a carrying handle on the side so I know it...
Hello, if this is an umbrella type stroller, you first release a catch on both handles to unlock the frame. These catches are located on the front and can be pulled up with your fingers. If you watch, they release the bottoms of each side from the front. You then pull the handle or lever located on the cross bar at the back up toward you. Thus collapses the frame as the wheels come together and the stroller then locks closed in the standing position and can be carried by the handle on the side. Greetings from Oz.
Dec 14, 2008 | Peg Perego Aria MT - Toffee Standard...
How to fold the peg perego aria twin stroller?
Locate the fold button on the side of the handle (It has a red arrow on it). Using both hands, slide both buttons up and push the handle forward. The stroller should fold up. Then push the handle down to lock everything in place.
Apr 26, 2008 | Peg Perego Aria Twin Stroller
Need length and width for folded 2007 aria twin model
Peg Perego
LINK: http://www.pegperego.com/page.php?sid=adbdaeb9e5e15cdd9498e53c732b46b7&pageid=UCGRP009&dwt=IS&dwf=05
For residents of USA and Mexico only.
3625 Independence Drive
Fort Wayne, IN 46808
Main Office: (260) 482-8191
Office Hours: Monday - Friday 7:30am to 4:30pm EST
USA Customer Service Hours:
Monday - Friday
8:00am to 8:30pm EST
USA Infant & Toddler Product Customer Service: (800) 671-1701
USA Ride-On Vehicle Customer Service: (800) 728-2108
USA Spanish-Speaking Customer Service: (800) 225-1558
USA Customer Service Fax: (260) 471-6332
USA Customer Service Email: CLICK HERE
MEXICO Servicio Al Cliente: 01-800-710-1369
Apr 25, 2008 | Peg Perego Aria Twin MT - Toffee Standard...
Feb 12, 2007 | Peg Perego Aria MT Rubino Standard...
Baby Gear Logo
Top Safari Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Safari Baby Gear Expert? Answer questions, earn points and help others
