Question about Tablets & eReaders
My 10 tablet won't charge it shows it is but it keeps losing it's charge
2 Suggested Answers
  • 6 Answers
SOURCE: 10 rca tablet keeps losing connection have to shut down to get it to connect
Try setting it to a static IP address.
open router settings (type your routers ip address in web browser I.e. admin name and password are normally on the router)then lan settings
set the MAC address of tablet as static noting the IP address ( for example),subnet mask (normally something like 255,255,255,0),etc.( to find your tablets MAC address settings then about)
when you have set the router up, on tablet tap the settings then wifi, modifiy settings tick use static scroll down and enter new ip address ,subnet mask default gateway(your routers in address).
its easy then it looks.
Posted on Sep 13, 2017
I have a RCa 10 inch tablet and it just went dead on me when I press the power button all it,s showing is a battery I keep it plugged in alll the time what is wrong and do I keep my tablet plugged in
Are you using the charger? Some tablets specifically mention a similar problem occurs when trying to charge via USB. The charger has a higher output voltage.
May 24, 2017 | Tablets & eReaders
Port on 10 inch tablet not working can it be fix
Linda, if it is the charge port, mini USB, yes they can be fixed or replaced by cell phone/computer repair shop.
Check the attached links videos showing port replacement. Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Android tablet charging port fix
Toshiba Tablet AT300SE AT305SE Charging Port Repair
Samsung Galaxy Tablet 10 1 Tab 3 10 1 P5200 P5210 Micro USB Port Replace HD
May 03, 2016 | Tablets & eReaders
Why is my tablet showing a 10% charge while its plugges into the wall-but as soon as i unplug it-it powers off- as if it was never charged?
Q: Cannot turn on the device
A:You cannot turn on the device when the battery is below the critical level, please charge the battery via the AC charger, then you can try to turn it on again while charging...
Tablet FAQ hkc
May 20, 2015 | HKC P776A - 7 8GB Dual Core Process
Will not turn on
If tablet keeps burning out charges it is due to the fact that an internal short in the tablet is making the charging unit exceed its parameters and allowing it to burn itself out. The issue is with the tablet, not the chargers.
Mar 13, 2017 | Ainol 10" Novo 10 Hero 16GB Dual Core IPS...
Won't turn on
try holding the power button down for 8- 10 seconds... then release. Still not on? Is the unit charged?
Jan 20, 2013 | Sharper Image Literati Reader 16375680042...
Kurio kids tablet won't start up
I fixed mine like this, unfortunately you will lose all your data on the system.
1) Whilst holding down the Power button, hold down the Volume+ button for about 10 seconds and let go.
The table should boot into a screen with an Android with a open chest and a danger sign on top.
2) Press the Volume+ button, and the recovery menu will appear.
3) Press the Volume- button, to move to "Wipe data/Factory Reset" and press the Power button to select that option.
4) Press the Volume- button to move to "yes" and press the Power button to accept.
Now the system will wipe the data and factory reset the tablet.
5) When it returns to the menu, make sure it is on "Reboot system now" and then press the Power button.
The tablet will now reboot and should load.
Aug 25, 2012 | Techno Source Kurio Kids Tablet With...
My tablet won't come on I've had it charging so the battery should be full is there something I can do?
try to hard reset or soft reset, for this procedure search on how to reset tablet, that will be helpful.
Jul 02, 2012 | Coby Kyros 716829701508 Tablet PC
My cruz tablet 103 won't keep app open, it just reverts to home page. Any suggestions?
You need to update your tablet, or update the programming on your tablet. Apparently all the android 2.2 tabs are considered "legacy" models and don't support the newest google and java script. Since this is what the net primarily uses, those of us with the Cruz are hosed.
May 13, 2012 | Velocity Micro Cruz Reader R103
AC adapter/charger is attached, but the battery will not charge. it doesnt even show that the battery is there
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 21, 2011 | Toshiba Portege M200-S838 Tablet PC
Tablets & eReaders Logo
49 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
