Question about Coffee Makers & Espresso Machines
I misplaced the holder that holds the single serve that is removable.
2 Suggested Answers
  • 51484 Answers
SOURCE: my hamilton beach 12 cup flexbrew coffee maker leaks from the front of the single serving ground holder while making coffee from that side. why?
Perhaps Hamilton Beach tech support can tell you that .
Posted on Oct 25, 2015
It will not make coffee in either the Keurig pods or regular ground coffee. It says PURGE, or NEEDLE after I clean it and use paper clip to remove grounds. What else can I do?
Customer Reviews: Hamilton Beach 49995 FlexBrew Single ...
www.amazon.com/Hamilton-Beach...FlexBrew.../B00...
Amazon.com, Inc.All in all, the Hamilton Beach FlexBrew Single-Serve Coffeemaker is an ... exhibit the same exact problems using the K-Cups recommended by Hamilton Beach.
Hamilton Beach FlexBrew Troubleshooting Common ...
? 3:39
https://www.youtube.com/watch?v=yA2dlGKUBKM
Sep 7, 2015 - Uploaded by Ronald Kretz
Hamilton Beach FlexBrew Troubleshooting Common Problemmust see if you ... Hamilton Beach Single ...
Customer Reviews: Hamilton Beach FlexBrew Single-Serve ...
https://www.walmart.com/reviews/product/21130276
WalmartProblem the model I purchased was the only one they made that uses K Cup. ... MyHamilton Beach FlexBrew Single-Serve Coffeemaker was truly a wonderful ...
FlexBrew® Single-Serve Coffee Maker (49995R) - Hamilton ...
https://www.hamiltonbeach.com/all-coffee-maker...
Hamilton Beach BrandsThe FlexBrew® Single-Serve Coffeemaker allows the flexibility of brewing freshly ...Not sure how much coffee grinds to add when brewing your next cup? ... and thenrunning 2-3 cycles of cold tap water before making the next round of coffee. ... 2016Hamilton Beach Brands, Inc. Trademarks by Hamilton Beach Brands, Inc.
Hamilton Beach FlexBrew 49995 - Consumer Reports Online
Jan 05, 2016 | Hamilton Beach 49995 FlexBrew Single Serve...
The lever wont close all the way after I insert pod?
You can move the handle slowly up and down until the coffee pod drops down. Be sure the used pod holder underneath is empty.
Mar 07, 2015 | Starbucks Single Serve Brewer, Verismo 580
HOW DO I REMOVE THE SEAT AND GAS TANK FROM AN 88 VIRAGO 750?
if memory serves me right it should have two bolts holding the seat on then there should be a bolt for the tank after you remove the seat ,if not bolts on the seat there would be a key holder cheers
May 21, 2014 | 1996 Yamaha XV 535 Virago DX
Ninja 1100 single serve cup will not come off. it is stuck
I was just having the same problem and looking for a solution...then I found it myself by accident. By pulling up on the cup and then trying to turn it came off pretty easily. I was trying to push down, which seemed to make it tighter.
Jun 21, 2013 | Back to Basics 600 Smoothie Plus Work Top...
When i changed the bulbson my dimplex optimyst charlotte crt 20 br with origianal bulbs from dimplexthey dont work yet the power supply isworking
I had the same problem. It turned out to be the lamp holders themselves which were the problem. Just take out the single screw just in front of the lamp holder assembly and the lamp holder unit comes out. Remove the main lamp holder assembly and turn it over. You will see the four lamp holder wires all go to two main terminals with a positive and negative connector on each. You need to undo the nuts holding the main supply cables and lamp holder wires and remove the cables noting where they came from for easy replacement. If you cut off the wire on the defective units and unscrew the two retaining screws holding each lamp holder they can be removed. You can order on line replacement holders from Amazon and with a little bit of simple soldering and using new wire connectors for the end connectors on the new lamp holder wires can be easily fitted. I have two of these fires and both have had the same fault after about 12 months use, obviously a fault with the holders as they dont last that long and need replaced.
Apr 05, 2012 | Heating & Cooling
Coffee has no taste or smell, just hot water. Doesn't matter 1 or 2 pods, no flavor at all. I did the beginning parts to prepare the coffee system.
The only way I see that happen is when you're not using a pad holder underneath the pads?! If the coffee pad is exposed to hot water, it *will* produce coffee - unless the water manages to flow alongside the pad rather than through. I can only imagine that if there's no pad holder used . .
Oct 15, 2010 | Philips Senseo Single-Serve Coffee Machine...
Coffee Makers & Espresso Machines Logo
29 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
