I Started the machine, it was all good to go and then it stop. there are no lights coming through at all now
Prime light came on.did all cleaning..air drying..etc. refilled.plugged in machine. Not ready light came on and cold water started immediately coming out and won't stop till add water light comes on
Sounds like your refill float that stops the water fill process when its full is stuck from most likely setting to dry upside down jar and jolt the machine heave up and down a few times plug it in try it do this until it stops on its own or you may have to take it apart also make sure the water line is turned back on if this is hooked up to operate on its own water supply.
Apr 23, 2015 | Coffee Makers & Espresso Machines
Singer Touch-tronic 2000 makes loud humming/buzzing noise, stitch selector lights quit working, needle bar stopped moving.
Sounds like you've got a thread jam going on in the bobbin case area. Good cleaning and a new needle will probably fix it. See:
Apr 20, 2014 | Sewing Machines
Hoover Optima WMH 147 DF water keeps on filling up
have a Hoover OPtima washing machine WMH 147 DF. It is filling up with water and not stopping, also the panel lights and wash cycle time display are not coming on. It's only 1 old
Dec 13, 2012 | Washing Machines
I started sewing and my machine just went black and stopped. It won't come back on. There is no sound, no lights, nothing. What can I do?
it's possible that either the computer motherboard went out on it.
since it's a janome computerized sewing machine I would suggest
having it serviced to see what's wrong.
Apr 17, 2012 | Janome Memory Craft 9000 Computerized...
Whirlpool washing machine AWO/D 5556 washing machine service light showing ?
The warning light comes on because the machine "thinks" that something is wrong. Since it stops on and off something is wrong.
Why not phone the Whirlpool service in your area and tell him aboout this and ask what you can do??
give it a try
Feb 22, 2012 | Whirlpool Washing Machines
Electrolux front loader wouldn't stop filling.
change water valve sounds like its stuck open ... if not only other thing it could be is your main pcb control board ££££££
Dec 30, 2009 | Electrolux EW1000i Front Load Washer
Traction control light comes on while driving in good weather
My 2002 Millenia just started doing this the other day, while on the freeway when it started doing it i would shut engine off and restart it and it would be good for a while then it would do it again, i am still looking for solution, has any one found one?
Apr 23, 2009 | 2000 Mazda Millenia
Riso GR 1700 OK light will not come back on ,nor will it release
switch on the machine and press the astrex button left of the zero button. The code that comes on the display would be helpful. or you you could shoot in the dark and reset the machine by switching off holding down the 2 top right side buttons and switching on the machine. Then release the buttons and off and on with machine.
Mar 25, 2009 | Riso RZ220 Duplicator
HP Media center 1170m
did you checked the ram just clean and fix it again. bye
Oct 01, 2007 | HP Media Center m1170n Photosmart PC...
Inlet/outlet light comes on
Machine is possibly not filling with correct amount of water if this light comes on early in the cycle
Aug 15, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
