Question about HP Measuring Tools & Sensors
I have a bad boy 8.75 HP Briggs and Stratton engine it only gets fire to plug every once and awhile replace coil same thing
SOURCE: briggs/stratton XM 6.75 hp quantam engine cv2300-OMBC
I have a brigg & Strat, works great but the oil keeps turning black, and it leaks throught he air cleaner. It is approx 1 yr old, bought it used but it looks new
Posted on Oct 20, 2008
jj505
  • 195 Answers
SOURCE: Have a Briggs & Stratton lawn mower engine, 4.5
Is Blade new or causeing vibration .Chge blade,
Please rate Thank you jj505
Posted on Mar 30, 2009
extroitive
  • 35 Answers
SOURCE: briggs & stratton 3 hp engine will not start
likely needs a carb kit
Posted on Apr 19, 2009
  • 246 Answers
SOURCE: 1998 craftsman mower w/19.5 hp Briggs and Stratton will not fire.
Hello B-N-L:
>>I Suggest you Check the Ign Module First and then the Safety Switches if the Ign Module (Coil) is Good. Remember that the Ign Module May Check Good, but if the Safety Switches Check Good, then Most likely the Coil is in the Early Stages of Breaking Down and will Cause this Problem.
>>You can Check the Ign Module (Coil) by Using the Following Instruction File.
The Following is an Instruction File I Made for Checking and Repairing this Problem.
>>Run the Engine Until it Quits, then Remove the Spark Plug. Wrap a Wire Around the Threads and Attach the Other End of the Wire to the Engine Block Turn the Engine and See if the Plug Fires.
>>If No, then Disconnect the Shut Off Wire at the Control Bracket First, Check for Fire at the Plug. If Still No Fire at the Plug; Then Disconnect the Shut Off Wire at the Coil (usually requires removal of the blower housing) and Check for Fire at the Plug.
>>If No Fire at the Plug , then the Coil/Ign Module is Bad. The Coil/Ign Module to Flywheel Gap is .020in.
>>On Some Model JD Engines, there is a Igniter that Goes Bad and Not the Coil. The Igniter is the Same as an Ignition Module. If the Plug Fires at Anytime During these 2 Checks, then a Safety Switch or Wire May be the Problem. Yes the Engine will Turn Even with a Bad Seat Safety Safety Switch. Usually if the Engine will Not Turn with the Ign Switch; the Blade Safety or Neutral/Clutch Safety Switch is Usually the Cause of this.
>>The Starter Turns and the Engine Doesn't Fire is an Indication of a Bad Coil/Ign Module or a Faulty Blade Safety Switch.
>>The Blade and Clutch Safety Switches Prevent the Starter from Engaging so the Blades or the Mower Does Not Move when the Starter Turns the Engine.
>>The Seat Safety is Designed to Stop the Engine if the Blades are Engaged or the Clutch Safety is Not Engaged when you Leave the Seat.
>>The Following is an Instruction File for the Safety Switch System. Any Input is Appreciated.
>>The Color Code of the Wires May be Different than those I Use as a Reference in the Instruction File.
>>**PLEASE REMEMBER THAT THE INSTRUCTIONS FOR CHECKING THE SAFETY SWITCHES IS JUST THAT!!! FOR CHECKING ONLY.
>>I NEVER Suggest a Mower be Operated with a Safety Device or Switch Disconnected or Bypassed.
>>**Now. On Some Model Mowers you can Simply Unplug the Safety Switch from the Harness. On Other Models you have to Place a Jumper Wire Between the Harness Terminals (on the 4 Post Switch (Clutch/Brake) Jumper from Same Color Wire (Example: White to White) First and then Check for Fire, Now Include the Black to Black Wires if No Fire.
>>Check the Clutch/Brake and the Blade/PTO Safety Switches First.
>>Check the Seat Safety Last. Usually the Seat Safety is Not in the System for Starting the Engine. Just to Ensure Someone is in the Seat when Engaging the Transaxle and/or Blades. Use a Paper Clip or a Short Wire to Make a Jumper.**
>>Use a Volt/OHM/Continuity Meter and Check the Continuity of the Switch. The Meter should Show when the Contacts are Closed and Open. The Meter will Swing All the Way Over when the Switch Contacts are Closed and Swing Back to the Rest Point when the Switch Contacts are Open.
>>If the Safety Switches Check Good, then Check the Ign Module (Coil).
>>Thanks.
Respectfully
John
Posted on Apr 21, 2009
  • 225 Answers
SOURCE: I have a 20 Hp briggs & stratton motor it will
have you checked the oil ?some units have an oil sesor,that if oil level is to low shuts the unit down to stop damage to unit.
Posted on Jun 21, 2009
22hp.zero turn sometimes smokes then stops.
The smoke could be caused by blowby around the piston rings. Pour a small amount of transmission fluid in the spark plug hole and turn the engine over several times. Check the plug for fouling. Also check the coil wire for spark.
Apr 15, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
I have a 20 hp briggs and stratton that wont get any fire
Check the diodes in the wires to the coils. Trace the wires from the coils, and they should join together into a single wire. In the junction of the wires, there is diodes. There is a possibility the diodes burnt out which will not allow power to the coils. My experience was when one burnt out and only one cylinder would run. I replaced the wiring and both cylinders worked fine.
Jan 30, 2013 | Briggs & Stratton Briggs Stratton Intek V...
Engine wont start
sounds like you may have a bad ignition module only thing you can do is replace it
Sep 02, 2012 | Briggs & Stratton Briggs Stratton Intek V...
One cylinder not firing
First take the plug wire off the plug to the one not firing..start and then using a pair of pliers hold the plug wire away fro the plug insert a rubber handled screw driver in the plug wire and make screw driver contact with the plug end..there should be spark if the coil is good..if not that coil must be replaced...good luck
May 09, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Lawn mower won't start
to check for firing remove the spark plug insert it in the plug boot and pull the rope while watching to see if the plug sparks be carefull not to touch the plug electrode while pulling the rope or it will shock you. If you don't have a spark, try a different plug. If still no spark the coil could be bad.
Jun 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
No fire to spark plug
If you have no spark on either spark plug then more than likely the coil is defective. Check all wiring before proceeding. The coil looks like this. 28596c2.png
Apr 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
No fire to spark olugs, sat up for 6 mos, drained
Remove the wire that runs between both coils and try it again.If it starts you have a bad diode wire or a short to ground in the wire or shutdown system.
Dec 02, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs and stratton miss fires on one cylinder.22hp intek
possibly a commpression test might throw a little more light on the situation ,that will eliminate alot of speculation, and make it easier
Oct 25, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Not firing
After you check the key and key way,Check the coil wire to see if it has any breaks in it,If no breaks are present,Replace the coil.
Jun 02, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Measuring Tools & Sensors Logo
Top HP Measuring Tools & Sensors Experts
obsteiner
Richard Lindsey ...
Are you a HP Measuring Tool and Sensor Expert? Answer questions, earn points and help others
