Question about Xerox Office Equipment & Supplies
Xerox ColorQube 8700 error 091-720?I would like to try and fix myself, the printer is out of warranty...
5 Suggested Answers
SOURCE: xerox 7750 fan failure code
I have had this problem on several occasions and I have come up with a good solution to the problem. The only tool you will need is a hammer. You have to go around to the back left of the printer where the fuser fan is located. You can tell it by the slotted area sticking out. Now, take the hammer and hold it at a 45 degree angle to the slotted area. And applying a liberal amount of force, proceed to attemt to insert the hammer through the slotted area. If you do this right, the fan should come out of the printer...in pieces. Thus, solving the problem. If there is no fan, there is no problem, right?
Posted on Jan 31, 2009
guide2u
  • 461 Answers
SOURCE: Xerox Phaser 8200 Error Code 15004.45:18370
unless you know how to service preheater/drum heater then you have no choice but to ask the qualified person to do it for you....
YOu can read more details baout the failure at below link..
http://etech.maiila.com/xerox-phaser-8200-drivers-software-manual-and-troubleshooting
Posted on Apr 22, 2009
YIRMASTER
  • 32 Answers
SOURCE: Xerox 8550DP error message (16.4)
Even if your printer's front control panel display has not gone bad yet, it could only be a matter of time.
If your printer has never had its control panel display replaced, you can get a free replacement from Xerox, even if the printer is out of warranty. Just call 877-571-7765 with the serial number of your printer.
I think this is due to a known defect from the factory for many of these panels having a bad soder weld which eventually causes issues with the panel, even if not apparent at first. That was the case I had. Just one day out of the blue my panel went blank, some days its lit with no display others the display is upside down or reading gibberish other times it seems to work fine. I tried looking for a bad soder myself but couldn't find it then later found out there was a soder issue via another post on this site and they will replace this panel free of charge.
Posted on Jul 22, 2010
  • 129 Answers
SOURCE: What causes error code 091-720 on a xerox colorqube 8900x printer?
That error signifies a printhead tilt fault. You need to replace the process drive camshaft kit, part number 8900-Z1.
http://www.iteminconline.com/8900-z1_8900-z1-xerox-8900-process-drive-camshaft-kit.htm
Posted on Feb 29, 2016
Feb 29, 2016 | Xerox ColorQube 8900X Multifunction Color...
Printer Error: 93,984.00:34602 Xerox colorqube 8570
Check the crum for the cartridge. And does it fix proborly
Oct 22, 2015 | Xerox Office Equipment & Supplies
Printer error : 91,720.00:47879
Ink contamination, if purging Cleaning Ink Smears Multiple times doesn't work than replacement of the resevior is needed
Aug 09, 2014 | Xerox Corporation Xerox ColorQube 8570DT...
Xerox problems
Hi Anonymous,
I suspect your question has answer by now.
If not, just visit the www.xerox.com website.
Regards.
Jul 29, 2014 | Xerox STANDARD CAPACITY MAINTENANCE KIT...
What does error code 093-547 on a Xerox ColorQube 9301 mean?
Interesting. Recommend reading and trying the software from Microsoft. http://www.saetechnologies.com/colorqube-error-code-093-547/
Jul 17, 2014 | Xerox Office Equipment & Supplies
Does not detect tray
Look inside the machine, down the back of the paper tray, can you see any sensors that could detect if the tray has been installed.
Has there been any external damage to your paper tray, does the paper lift when you turn the paper lift gear by hand.
Try those points first.
Good Luck.
Jan 16, 2013 | Xerox Corporation COLORQUBE INK MAGN...
What does error code 91,721.00:1039 on Xerox ColorQube 8570 mean
The error is a printhead tilt fault. It's unable to tilt on the axis, caused by a fault camshaft and process motor. The part you need to fix it is 8570-Z1.
http://www.iteminconline.com/8570-z1_8570-z1-xerox-colorqube-8570-8580-8700-process-drive-camshaft-kit-includes-process-drive-motor-drum-maintenance-camshaft-transfix-camshaft.htm
Aug 13, 2012 | Xerox Office Equipment & Supplies
103 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
