Question about Cascade 1400 Gph Pump
How to set up a Hozelock cascade 1500 pond pump
Where does the water go into the pump and where does it come out?
  • 82 Answers
If there are no markings, check each opening for a vacuum with a small piece of paper, the one sucking in is the inlet, the other is the outlet
Posted on Jul 26, 2009
Hozelok Titan 2000 pump not pumping. Electricity is getting through, pump making a funny noise but not pumping.
You have to prime the pump first. Turn off the pump, remove the priming cap, fill with water, close, then run it. Repeat as needed to get water pumping.
Sep 11, 2013 | Hozelock Garden
I have a Hozelock super cascade 100 pump for a small pond. The water flow is very poor and I have cleaned the filter. I believe the pump is about 10 yrs old, is there anything I can do?
You need to put a vacuum gauge on it and see what the vacuum is. There are ways to increase the vacuum pull. You can shim the impeller closer to the volute casing, get it as close as possible without rubbing each other. If the parts are extremely worn, you may have to replace them. What about your pump seal? Is it leaking water? You could be sucking air in there, this would decrease your suction as well. Good luck.
Jun 18, 2011 | Garden
Need instructions on how to install hozelock cyprio filter & pump
need instructions on how to set up filter, hazelock cyprio please
May 21, 2011 | Hozelock Cyprio Prima Xl 3400 Gph Pump
My cascade pump 1500 is clogged and do not have instructions to take it apart
Hi Cheryl,
Before you take it apart try this.
With the pump off, attach the outlet to a garden hose and run water backwards through it. If it's being stubborn flip it on for a sec. every once in a while.
The process has worked well for me.
Best regards,
Aug 21, 2010 | Garden
I have a hozelock bioforce filter that i have
Sounds like the the bypass valve may have been disturbed and so water is coming out of the air bleed hole.
I suggest you turn off the pump, remove the bypass valve cover (clear part that quater turns off bayonet style), extract the red valve (careful not to lose spring), rub some pertoleum jelly (vaseline) around the seal of the red valve, replace spring, red valve, press the red valve a few times to ensure it returns, replace clear cover and turn pump back on.
This should ensure the valve is working.
May 23, 2010 | Hozelock Garden
My pond pumps faulty
sounds like the pump has shorted out internally and needs to be replaced, try on different circute first to see if breaker is not faulty
May 24, 2009 | Garden
Cascade 1400 Gph Pump Logo
370 people viewed this question
Top Cascade Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Cascade Garden Expert? Answer questions, earn points and help others
