Question about Vacuums
What does the Belt and Road construction mean to China juice bottling filling machine manufacturer?
Wont discharge shampoo!
Make sure there is liquid in both the Tank-in-Tank and the SmartMix Bottle and check for spray through the upholstery hose. If the hose does not spray please check the following:
- Remove the belt access door and inspect the pump belt to ensure it is not broken, worn or stretched. You may also check the belt by turning on the power and watching the brush on the bottom of the machine. If the brush rotates the belt is not broken.
- Check for proper placement of the o-ring on the SmartMix Cap Insert (some o-rings are detachable and need to fit over the straw; others are molded to the cap).
- Check for liquid in the base of the machine where the SmartMix Bottle sits (SmartMix Reservoir). If there is no liquid in the reservoir, the neck on the SmartMix Bottle may be undersized, the cap will not make proper contact with the unit and the smart mix bottle will need to be replaced.
- Check for the black or red tank gasket on the SmartMix Bottle Cap and on the bottom of the Tank-in-Tank Assembly. If gasket is lodged in base of unit or has been lost, reattach gasket on auto-load or order new gasket if appropriate.
- Check the valves on the bottoms of the Tank-in-Tank and SmartMix Bottle to make sure water/solution will come through when the "x" valve is depressed. Bladder or SmartMix bottle may be empty or the valve may be blocked internally.
- Check if the small rounded window tabs on the top edge of the Floor Nozzle Window are locked in their mating slots on the base of the machine and not inadvertently lifting the tank up out of place.
Nov 23, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Tip
How To Fix Your Bissell Carpet Cleaner When Solution Doesn't Spray
If you have a Bissell Carpet Cleaner, and you're machine is not spraying water on the floor, there are several things that might be causing this. Here's a list of possible problems that might be causing the machine not to spray water:
It may be a problem with your pump belt. Bissell Carpet Cleaners use a belt that powers the pump to spray solution out. There are also a few other possible issues, but as a Bissell warranty station, the belt going bad out-numbers all other problems.
If your belt is worn out or broken, here's a direct link to that belt on our website:
Bissell Pro-Heat, Pro-Heat 2 6960W Replacement Pump & Brush Belts
Here's a great video that will show you how to check, and replace the pump belt on your ProHeat carpet cleaner:
How To Replace the Bissell ProHeat 2X Carpet Cleaner Belt Video:
http://www.bissell.com/VideoRating.aspx?id=1555
If this was not the problem, here are some other things that you may check:
  • Make sure there is liquid in both the Tank-in-Tank and the SmartMix bottle. Both tanks must contain fluid or the machine will not spray properly.
  • Check for proper placement of the o-ring on the SmartMix Cap Insert (some o-rings are detachable and need to fit over the straw; others are molded to the cap).
  • Check for liquid in the base of the machine where the SmartMix Bottle sits (SmartMix Reservoir). If there is no liquid in the reservoir, the neck on the SmartMix Bottle may be undersized and the cap will not make proper contact with the unit. If there is no liquid present, you will need a replacement SmartMix Bottle.
  • Check for the black or red tank gasket on the SmartMix Bottle Cap and on the bottom of the Tank-in-Tank Assembly. If gasket is lodged in base of unit or has been lost, reattach gasket on auto-load or order new gasket if appropriate.
  • Check the valves on the bottoms of the Tank-in-Tank and SmartMix Bottle to make sure water/solution will come through when the "x" valve is depressed. (Bladder or SmartMix bottle may be empty or the valve may be blocked internally.) Use a soft-bristled brush and hot tap water to clear any debris. Replace autoload assembly or cap/insert if necessary.
  • Check if the small rounded window tabs on the top edge of the Floor Nozzle are locked in their mating slots on the base of the machine, and not inadvertently lifting the tank up out of place.
If these suggestions have not resolved the problem you are experiencing with your machine, you might want take your machine to a local BISSELL Authorized Service Center. I really hope that this information was helpful to you. If you find what's wrong with your Bissell and have specific questions about how you can fix it, please just let me know and I'll be happy to walk you through step by step to fix any problem you may have on your Bissell.
Thanks,
Chris Jones
GoVacuum.com
on Apr 12, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
He filled the reservoir, turned on the switch and pressed the handle to get soap and water and nothing came out does not spray
Nov 23, 2010 | Bissell 1699 ProHeat Clear View Upright...
WATER WILL NOT COME OUT
Nov 22, 2010 | Bissell 7901-R Clearview Proheat Plus...
Purchased ProHeat 7920 Po-Tech recon. Unable to use main brush as no water/cleanfluid. Belt drive is ok. Grateful advise location of fluid jets as not visable behind main brush. Turbo brush works well.
Nov 16, 2010 | Vacuums
My bissell wont release water or cleaner
Nov 05, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
FHow much solution goes in first?
The tank is labeled. Take the clean/solution tank off the vacuum by lifting it straight up. Unscrew the black cap on the bottom of the tank and remove the bottle insert. Add 8 oz of the Little Green formula (this gets you up to the Formula fill line). Then add hot water to the water fill line. Replace the bottle insert and tighten the black cap. Then replace the clean/solution tank by lining the indentations up with the vertical guides on the left side of the unit and sliding it straight down. Please note that the bottles of the formula come in 32 oz or 64 oz bottles. So you can expect one of the smaller bottles to last 4 fill cycles.
I hope this helps.
Oct 07, 2010 | Bissell THE BISSELL LITTLE GREEN MACHINE...
My machine is not putting out water or sucking anything up
Please try these suggestions to get your machine working properly:
If these suggestions do not solve the problem, please have a technician at a local BISSELL Authorized Service Center inspect your machine. BISSELL supports your machine with a one-year warranty for any defective or malfunctioning part.
Sep 26, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
My bissel proheat is not releasing the soap when the trigger is pulled
Try these suggestions to get your machine working properly:
Aug 13, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
It wont spray the water on the floor.what do i do
Aug 05, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Vacuums Logo
19 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
