Question about Dryers
Sentry safe S 0607need urgently a new case were you have to put in the Batteries. Pleas respond kaufmann@optusnet. com.au
Tried many places Please Help me. Help. help
SOURCE: Sentry H4100 file safe
There is a lock and there is a latch.
You can latch the safe without locking it and unlocking it does not unlatch it.
After you unlock it, then you must press up on the spring loaded latch while (this important) pressing down on the cover to releast the pressure on the latch hook, allowing it to move out of the way. After the latching hook is out of the way, you can release the pressure on the lid and it will open. You can't see the latch hook as it drops down from the lid, into the front wall of the safe where it engages a post, but perhaps you can imagine what it looks like.
Mine will not unlatch, even though it is unlocked, unless I press down on the lid to give it clearance first. There is quite a bit of spring in the plastic that this safe is constructed out of. It works against you when you try to open it and close it.
I can take digital photos of the mechanism if this description does not help.
Another Gary
Posted on Sep 10, 2008
SOURCE: know combination, but cannot open sentry safe 1250
If you know the combination:
1) Turn the dial to the left a few complete rounds, then stop on 1st number.
2) Turning the dial to the right, pass up the 2nd number once, then stop on it on the next round.
3) Turn the dial to the left directly to the 3rd number then stop.
The handle should open now.
Posted on Mar 18, 2009
SOURCE: Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Posted on Mar 23, 2009
  • 80 Answers
SOURCE: Sentry Safe A3750 won't open new batteries
http://www.sentrysafe.com
call them
mj
Posted on Sep 07, 2009
SOURCE: factory code will not open model # DA3831 safe
i am a locksmith that has worked on several of these. The safe is manufactuered with three types of lock mechanisms 1. combo dial 2. digital 3. advanced digital the advanced digital is what you have there are no green lights on it. look at the manual carefully there are 2 seperate sections on the digital key pads yours will be the second.
Posted on Dec 18, 2009
Cant open my programmable key pad safe. the code wont work
Locksmiths agree try replacing the batteries just slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Aug 12, 2010 | Sentry Fireproof Safe
When I key in the pin it says to proceed but the bolt wont open. do I have to change the batteries? If so, how do I change it? My safe is a fire safe S0607
Locksmith advice on how to install sentry safe batteries
Aug 10, 2010 | Sentry Fireproof Safe
I have a Sentry OA5835. I am unable to open with factory combo and key. help
Sounds like the batteries are dead.
How to install sentry safe batteries
Mar 11, 2010 | Sentry Fireproof Safe
The Sentry V260 safe will not open. Replace batteries?
Locksmiths agree on how to install sentry safe batteries
reconnect the connector and put back the battery holder. Slide the cover back in place. How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
Unable to open electronic safe
Locksmiths say this is how to install sentry safe batteries
Mar 06, 2010 | Sentry Fireproof Safe
Change battery of sentry safe
To install sentry fireproof safe battery
reconnect the connector and put back the sentry safe battery holder. Slide the cover back in place.
Dec 01, 2009 | Sentry Fireproof Safe
My Sentry S3807 just will not open. I have the combination right and the key, but it won't open. The batteries could be shot, I suppose, but how do I get in?
Aug 26, 2009 | Sentry Fireproof Safe
I have a sentrysafe t6 mode i cannot open as battery is dead
Locksmiths install sentry safe batteries this way
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the sentry safe battery holder Insert the 4-batteries as indicated.
Jun 07, 2009 | Sentry Fireproof Safe
Sentry S3807 safe-cannot open
locksmiths agree on how to install sentury safe batteries
to install batteries, turn the electronic lock case to the right and remove.Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Jan 26, 2009 | Sentry Fireproof Safe
Sentry safe
Sentry Home Safes battery location
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, next replace the electronic lock case and turn to the left to reassemble.
Oct 26, 2008 | Sentry Fireproof Safe
Dryers Logo
20 people viewed this question
Top Dryers Experts
