Question about The Audio Players & Recorders
Where can I buy the DC power cables that connect the power supply to the woofer and the satellite speaker on the acs 300?
Where can I buy the DC power cables that connect the power supply to the woofer and the satellite speaker?
SOURCE: sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Posted on Oct 09, 2007
  • 181 Answers
SOURCE: Toshiba Satellite A105
The most common problem on these units is the ac connector solder joints break away from the motherboard. If you're sure the ac adapter is working, and the correct one, and it's not charging the battery (assuming the battery is good), it's most likely the problem. They don't have to appear loose to be loose.
Otherwise, it's motherboard time, or a loose screw, etc has caused a dead short on the board.
Good luck, if you have additional info, let me know.
Posted on Feb 09, 2008
  • 1512 Answers
SOURCE: I need an AC/DC 19v
Hi Curtis
This a hard to find item... if you are quick, you can get one here or here
Only other place I could find one to do the job for you... was rated at 1 amp, and cost $213.00 !!
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
Posted on May 30, 2008
  • 396 Answers
SOURCE: HUM noise at PSW3000 if i connect the Yamaha RX-V995
the conections some where are dirty you need to unplug everything clean all connections and the hum will go away
Posted on Nov 06, 2009
  • 670 Answers
SOURCE: Re the part DC-9v Adapter. Is this for use as a AC
IF it says do not do it then dont do it? Also even if you break it its a lifetime warranty so if you wanted to take your chances
Posted on Jun 15, 2011
What cable connects a Dell PC to a Harmon Kardon HK395 sub woofer?
3.5 m/m. Normally it is color coded green. The pink connects the subwoofer to the speakers. Any color will work. Just mark both ends of wire jacks.
Nov 16, 2014 | Dell Harman/kardon Hk395 Computer Speakers...
just do as I did cut the cable and attach to a store bought power adapter works good. I am only using a 12v power adapter and it seems to work fantastic
May 13, 2012 | Sony Audio Players & Recorders
I got logitech speakers X-230 M/N: S-0123A that need ac110-120v- 60 Hz from USA and by mistake plugged it into ac 220 v that is standard in new delhi. there was a spark and smoke from the woofer unit, and...
You have damaged the power supply unit and this would have caused some failures on the power supply and sometimes on the drivers.
So first of all please check the power supply unit, alternatively the DC power required can be supplied by incorporating a new power supply with the same rating but working on 220volt.
repairing the 110 volt supply is no good as you will need again a step down to work , so I suggest this change.
Feb 25, 2011 | Office Equipment & Supplies
How do you connect logitech speakers on the pc
1) plug the cable coming out of the satellite with the sub-woofer at the reat 2) plug the 3.5 cable jack coming out of the second satellite to the computer audio out ( generally green color connector ) connect the power adapter with the sub woofer
and you ready to enjoy the music. make sure yo switch on the the power adapter.
Oct 22, 2010 | Logitech R-20 Computer Speakers
AVS500 Woofer has low Freq.pulse.front and back speakers working. Need circuit diagram to trouble shoot . Henry
Is the power supply AC or DC. I had a similar problem with my boston acoustics speakers, and I was able to swap the power supply for a DC output one of the same voltage and amperage and the hum went fully away. it is an inverter circut that went bad in my woofer.
Jun 13, 2009 | Altec Lansing 621 Computer Speakers
Cant find users manual for boston micro media systems 7000596 need 2 see how it is hooked up to my computer thank u
Plug red and white cables into woofer ports that are red/white
Plug purple lead into front of woofer to input port
green goes into accessory (green) port on back of computer
elbow shaped 2 prong leads go to speakers in back
DC power goes into front of woofer marked DC input
Apr 19, 2009 | Boston Acoustics MicroMedia Computer...
Stopped working. I-trigue 3400
The stereo -jackbus is broken if your speakers won't work and your headphones are fine. The stereo jackplug holds a little switch at the back, which moves sideways if you connect headphones.
Solution is very carefully opening back end of stereo connector bus and reassembling the switch
Oct 24, 2008 | Creative Labs ITrigue 3400 2.1 Speaker...
No Power (LED off) in the Altec Lansing VS4121
There is no way to open the satellite speaker without destroying it. I tried and found that the whole thing was glued together. Mine is now destroyed
Apr 15, 2008 | Altec Lansing VS4121 Speaker
Top The Audio Players & Recorders Experts
Jose Ma DM.
Jose Ma DM.
Level 1 Expert
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
