Question about Sewing Machines
Piaffe 1040. Take up lever is jammed in lower position. Can't see any thread in bobbin casing or feed dogs. Can I put oil on any parts?
snakehead
  • 1074 Answers
SOURCE: Thread getting caught underneath
you need to replace your shukle that holds the tread bobbing below.it is either slack or broken . if it is slack then you tighten the little screw that holds a cover that gives the thread tension .if its broken then replace it.once the thread is slack below it will cause your thread to bundle up.
Posted on Mar 19, 2007
  • 255 Answers
SOURCE: Feed Dogs, Thread Tangle
Hi Jeanette! You have a Singer Featherweight--the best sewing machine ever made! (Mine dates from 1950/51 and I wouldn't trade it for the world.) These beautiful, sturdy machines were designed to be easily repairable at home, but you'll need a copy of the Service Manual (get the Instruction manual too, if you don't have one.) Go to www.singer-featherweight.com and check out what they have available.
I had a similar problem (needle thread not catching the bobbin thread) and the problem was that I hadn't put the needle in correctly (flat side to the left). Also, I will occasionally get thread wrapped around the bobbin housing--sewing along just great and then everything comes to a screeching halt. I'm not sure why that happens, but I'm getting pretty good at taking the bobbin housing apart. The manual is pretty clear on how to do it. You can contact me direct at robbie1949@comcast.net for more information.
Thanks!
Robbie
Posted on Jan 10, 2008
yeroc
  • 397 Answers
SOURCE: thread jammed around bobbin case holder....can't get loose
lol...kinda jammed together but i kinda understand, your on the right track but if you are unsure i would take it to a repair shop,
dont mess around that area because you can throw the timing off, i would need more information to where the thread is actually hung up, send pic if u can
Posted on Jan 20, 2008
  • 201 Answers
SOURCE: Free Motion Sewing - Jams
I don't have a solution, but wanted to remind users of this machine that it does not do the proper free motion action until you reach a certain speed. This information is on page 26 of my manual (older machine, so page no. might have changed with newer manuals). You can stitch at the lower speeds, but it does not "hover" and allow you to move the project swiftly and smoothly.
If you can sew regular sewing without thread/bobbin issues, then it is probably something to do with how you have set/threaded/used the free motion to cause the stoppage. Make sure you have a sharp (i.e. new) needle of the correct size for your thread, that the bobbin thread is the same weight thread as the top thread. Turn on the Needle Down button. There is a Free Motion setting in the Set menu, but I have no idea what it does. I turn it on anyway, just in case! What foot are you using? If you don't have one of the free motion feet (there are quite a few to choose from!) use the embroidery foot (small clear plastic one).
Pam
Posted on Apr 15, 2008
SOURCE: bobbin thread will not pick up nor will dog feed rise
my Brother sewing machine model VX 1120 will not pick up the Bobbin Thread. Machine is fairly new with only several hours use. I have changed needles , tried different bobbins, cleaned the machine. Any suggestions?
Posted on Jul 13, 2008
My machine is not catching the thread around the bobbin holder
It sounds like you have a thread jam. Depending on the machine there may be lever that will release the bobbin shuttle, and another 2 levers to release the cover plate. Pay attention to positioning so you can put it back together. Remove the shuttle, then the bobbin cover and see if there are any knots of thread getting in the way.
Oct 05, 2014 | Sewing Machines
E6. Motor locked up because the thread is tangled. I have re-threaded machine and bobbin; thread still tangles after 2 or 3 stitches. HELP!
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
Jan 18, 2011 | Brother CE4000 Computerized Sewing Machine
Have a brand new Singer 1507 that keeps jamming the bobbin thread. Have followed threading and winding bobbin instructions closely, but am still having problems with the bobbin thread jamming after 1-2...
I would try adjusting the tension on the machine - this sometimes causes the bobbin thread to jam while sewing. Re thread the entire machine including the top thread. Also it is recommended to use new thread as old thread can ball up after time. If no luck I would call the store you purchased the machine from.
Nov 30, 2010 | Sewing Machines
Settings for stippling freesia 425
Lower feed dogs. Turn on Needle Down. Presser foot pressure on Darning setting. Don't forget to lower the presser foot lever. That's about it! Since you are going to be the feed dogs, it doesn't really matter if you have a stitch length set or not, but do have width set for "0". The spring loaded darning/embroidery/quilting foot is the best for stippling, but try it with any open toe foot you may have. Do a few samples first using the threads you intend using on your project because the tensions might need tweaking. Try to get the result you like by adjusting only the top thread tension. If you really have to adjust the bobbin too, put a small mark on the bobbin case where the "normal" position of the screw is so you can return to that when you are done quilting.
Jan 31, 2010 | Husqvarna Freesia 425
I need help in adjusting the feed dogs, they messed up when I adjusted the timing for the needle and bobbin.
When the sewing machine is properly timed, all the parts work together in a seamless flow of coordination. The needle moves from it highest point down toward the needle plate. The feed dogs reach the farthest point toward the back of the sewing machine. The feed dogs drop under the needle plate. This is just before the needle point reaches the needle plate. The needle continues to move down dragging the upper thread under the needle plate. It proceeds toward its lowest point.
The needle begins its rise back up. A loop of thread forms along the back of the needle. A special cut out on the back of the needle to accommodate this loop is called the scarf. The sewing machine hook slides behind the needle. The point of the hook slides into the thread loop and pulls the thread around the bobbin. The bobbin thread and upper thread wrap together. The needle and hook proceed through their actions under the needle plate. The feed dogs move under the needle plate from back to front.
The needle proceeds to rise again up out of the bobbin area exiting the needle plate. At the same time the feed dogs rise up out from under the needle plate. They begin to move from front to back as the needle continues to rise.
The thread from the bobbin flows through a bobbin tensioner providing resistance to the thread as it is drawn up by the upper thread knot. The upper thread is also under tension. This comes from the upper tension, thread guides, tension spring, and sewing machine take up lever.
The thread from top and bobbin grow increasingly tighter until they form a locked stitch in the middle of the fabric. This process is repeated for every stitch.
How do you adjust sewing machine timing?
The needle, hook, and feed dogs must move in harmony. If they fail to do so, the machine will not perform as expected. When the hook is just slightly out of time with the needle, you will notice skipped stitches. This may begin on only one side of the zig zag stitch or intermittently. If the timing is just a bit more out of sync, stitch formation will become impossible.
If the feed dog timing is out of sync, the fabric will not move through the machine as expected. Threads may bunch up or the fabric may just not move.
As you can see, timing is everything.
click on this link directly
http://www.fixsewingmachines.com/How-to-Adjust-Sewing-Machine-Timing.html
This will help. Thanks please keepupdated.please do rate the solution positively .thank you for using fixya
Jan 29, 2010 | Sewing Machines
Not sewing - jamming
Could it be that the feed dogs are down? I also have the 15358 and when I opened the bobbin area to clean it, I had this problem. Apparently, when you open the clips around the outside of the casing, it pushes the lever that adjusts the feed dogs to the right (lowering them). I didn't even realize it at first. Check your manual for adjusting this lever to raise the feed dogs. That might solve your problem.
Mar 31, 2008 | Kenmore 15358
Kenmore 19153
Sounds like you need a new needle and the upper tension tightened. Try putting machine oil on the feed dogs and working it up and down until it is free again. You can take off the lower plate and clean any lint that may have collected underneath. Then make sure the thread is coming out of the bobbin correctly before it is inserted in the machine.
Zelma
Jan 18, 2008 | Kenmore 19233 Computerized Sewing Machine
Breaking thread
1. Make sure you are using the correct needle and thread for type of fabric and it is installed correctly. Make sure bobbin is threaded evenly. 2. Tread path - make sure the machine is correctly threaded. Then, with your finger, feel for burrs, nicks or roughness on any metal parts that contact the thread. Open the slide plate, remove the bobbin and inspect the bobbin case and hook. Remove the needle plate and examine the needle hole. Sand any rough areas with fine emery paper and blow away grit. If burrs or nicks remain on the needle, presser foot, needle plate or bobbin case, replace them with exact replacement parts, if they remain on the thread guides, take-up lever, bobbin hook or tension regulator, take the machine for professional service. 3. Loosen thread tension by adjusting tension dial. 4. Clean feed dog, bobbin case, and tension discs. Unplug the machine. Use a small, stiff brush to wipe dirt and lint off the machine head and the needle bar area. Raise the presser foot and the needle to the highest position, open slide plate and remove the bobbin and needle plate. brush away dirt and lint from the feed dogs and bobbin case and remove any tangled thread with your fingers. Use a soft cloth to clean between the tension disc on the tension regulator. 5. Also check tension on presser foot
Dec 31, 2007 | Consew 206RB
Feed dog is stuck
I have the same problem...this is a work around, not a fix. You need a small flat-head screwdriver. 1. Remove the clear bobbin cover. 2. Make sure the feed dog switch is in the DOWN position. 3. Slide the screwdriver under the feeddogs from inside the bobbin area & lift the feed dogs. 4. While holding the feed dogs in the up position, return the feed dog knob to the up position. You have to do this every time you put the feed dogs down...bummer, but I can find no broken part or adjustment that corrects this. If it's inside the machine body, I don't mess with it... I did take off the bottom plate in the feed dog area..one screw holds it.... there is nothing there to indicate a problem.
May 07, 2007 | Singer 2662
Singer futura ce-100 embroidery machine
Under the embroidery attachement (on the front side) is a lever to engage or disengage the "feed dog control." When embroidering, you need to move the lever to the level to disengage. The feed dog control should only be at the righe side position, or raised when you are not using the embroidery attatchment.
Jan 31, 2007 | Singer CE-100 Futura Computerized Sewing...
Sewing Machines Logo
24 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
