Question about Sewing Machines
The take up lever is inconsistently jamming. I have to really turn ******* the hand wheel to get it to move up when it gets stuck in the down position. Thread is not the problem.
  • Sewing Machines Master
  • 9,272 Answers
What's the make & model? If it's an older mechanical machine, it very well could be seizing due to lack of oil and the old oil has turned to glue.
Wheel on right side that controls the needle up and down is very tight...
Posted on May 16, 2017
4795do i get hand wheel to turn, stuck
YOU SHOULD TAKE YOUR BOBBIN AND BOBBIN CASE OUT AND THOROUGHLY CLEAN IT. BLOW IT OUT AND THEN USE A QTIP TO MAKE A FINAL CLEAN. ADD ONE DROP OF SEWING MACHINE OIL ON THE RACE (SMALL AREA THE BOBBIN CASE SETS ON TOP OF). MAKE SURE ALL OF THE THREAD IS CLEARED OUT. DON'T THREAD MACHINE YET!
TRY TO TURN THE WHEEL TOWARDS YOU. YOU MAY WANT TO REMOVE THE TOP AND BOTTOM TO PLACE OIL ON ALL MOVING PARTS. REMEMBER THE NEEDLE ARM THAT GOES UP AND DOWN IN THE FRONT NEEDS TO BE OILED. THIS SHOULD WORK UNLESS THERE IS SOME SERIOUS PROBLEM.
Jan 23, 2015 | Sewing Machines
Hand wheel wont turn to raise needle.
If handwheel does not turn, you may have thread jammed in the hook. First try to force the handwheel BACKWARDS to try to force thread back out of hook. If handwheel turns, look around hook area and you will probably see a small piece of thread. Remove it with tweezers. To help eliminate this from happening, be sure to hold the needle thread when starting off.
Jan 18, 2015 | Brother Computerized Sewing/Quilting...
10000 janome jamming fly wheel won't turn
I would replace the needle anyway. It's hard to tell if one is bent or not.
Remove your feed dog/needle plate and the bobbin cover. Take out your bobbin and bobbin carrier.
Get out a magnifying glass and really examine. Look for thread ends in between moving parts.
Also check the thread pathways. Especially where the take up lever is hidden. I've heard of some ladies finding threads snarled up in that area which caused problems like this.
Good luck. If all else fails take it in for repair.
Nov 04, 2012 | Janome Sewing Machines
Hand wheel won't spin?
Something is binding up inside. Clean and check under the presser foot and bobbin area. Really examine under there... look for threads wrapped around and in between moving parts. Also check in the slot for the take up lever... sometimes threads get balled up inside there can cause problems.
could also be a bent upper arm inside the machine (lets hope not) Get professional help if cleaning doesn't free it up.
Aug 02, 2012 | Singer 57815 Mechanical Sewing Machine
The needle is stuck in the Shark 612C model sewing machine, any solutions?
Try http://www.fixsewingmachine. com I also suggest that you clean bobbin case. Now, when needle is "stuck", this requires patience and care in "jiggling" the hand wheel to and fro until needle point begins to clear the jammed area. Carefully snip one thread that moves up under needle and jiggle hand wheel by carefully turning hand wheel toward you to see if you can move the take-up lever all the way up to the UP position. Look at bobbin case area and remove bobbin. Cut bobbin thread and remove bobbin case. Sweep gently with brush underneath case and carefully, gently sweep over the feed dogs, poking very ends of brush bristles into "teeth" area to remove lint, fuzz ball/s, and any loose thread/s. Raise presser foot, remove (possibly bent) needle. Insert new needle of appropriate size for fabric weight. Make sure needle pushed all the way up into needle bar groove, at side to back. Keep presser foot RAISED while rethreading. This allows thread to locate tension discs, and HOLD THREAD TAUT. Replace bobbin, making sure thread is EVENLY distributed on it. Imablanced bobbins cause jams, and bobbins with burrs and scratches can real havoc as well as the hook part of the shuttle where the bobbin fits. Smooth such areas with emery cloth carefully, ever so gently. Hope my suggestions are a solution for you. Jimmy
Apr 06, 2012 | Euro-Pro Shark 60 - 384
I have a singer 603e that I just purchased from an estate sale. I got home and tried to use it, but the take up lever is stuck. How do I fix this?
try some wd 40, spray it on the area of the take up lever & let it set for at least 10 minutes then with the hand wheel on the right hand side slowly move the hand wheel toward you & if it still doesn't move re spray again & wait again then try the hand wheel again to move toward you eventually it should start to break loose if it's just stuck.
since you pruchased it at a estate sale, there not much telling when the machine was serviced last
if the spraying doesn't work, consider having it serviced
Aug 21, 2011 | Singer 3116 Simple
I have a singer cxl electronic sewing machine and i have a problem with the needle either not moving or stopping when stitching the larger motifs or the zigzag stitch, somtimes the needle jut moves too...
The needle either not moving or stopping is a sign that the machine is jamming. Here's the answer for the question "My machine is jammed" from the FAQs on Singer's web site at http://www.singerco.com/support/faqs.html
A jammed machine is caused by thread being caught in the hook. Remove the upper thread and the bobbin case, turn the hand wheel towards you (counterclockwise) by hand and remove any thread in the bobbin case area. *Always turn the hand wheel towards you. Turning the hand wheel away from you (clockwise) can cause the machines timing to become unaligned and jam your machine. Also, always make sure the presser foot is in the down position before you start sewing. Sewing with the presser foot in the up position will jam your machine in the bobbin case.
Your description of the needle hitting the plate or foot is an indication that the machine's timing has become unaligned which can be caused as indicated above by turning the hand wheel away from you - the correct way is to *Always turn the hand wheel towards you.
Mar 03, 2011 | Singer Sewing Machines
Kenmore sewing machine Model 1602: I was filling a bobbin and when I went back to sewing - the needle won't go up and down. Motor runs when I press on the footpad. It is as if the clutch is stuck as well...
Sound like you need to take it out of bobbin winder mode. Suggest looking for a way to engage the clutch. Turn the center knob on hand wheel and or move the bobbin winding post back to postion.
The center hand wheel should move about 1/3 turn towards you to look it back into place.
Feb 09, 2011 | Kenmore 15516 Mechanical Sewing Machine
The hand wheel won't move. i tried to see if the feed dog was at fault and moved the lever back and forth and now the feed dog is stuck in the down position - and the hand wheel won't move
Open the throat plate and bobbin area to see if thread has tangled there. Snip and remove thread with tweezers - do not yank or **** and tangles out of the machine.
Mar 18, 2010 | Bernina Bernette 75
Hand wheel is hard to turn
If you take out the bobbin case and slide off the needle pate, you can inspect the bottom area for a thread jam. The black post that the bobbin case slides onto is called the thread hook. It should have a loose feel to it when you gently move it around, it should not have a "solid feel".
Another area that sometimes wraps the thread is the take up lever area.
(the lever that moves really fast up and down as the machine is sewing)
If the lever has been pushed to the left, it's possible the thread has wrapped up in that area.
If those two areas are o.k. you'll need to take it in for service.
Oct 16, 2009 | Husqvarna Viking 1
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
