Question about The Audio Players & Recorders
Deion AVR-1513 No audo output, except form AUX HDMI and AUX Portable In.
Power Supply checks good. No short on speakers. If I do input to any channel in the rear and turn up vol, the receiver will trip. But not with the front AUX. Also no tuner output. Also, when the unit is turned on there is a "pop" at the speakers.
2 Suggested Answers
  • 626 Answers
SOURCE: Can't get into AUX source
Are you sure it is an AUX input? According to the Manufacturers Specs, the AUX, is an optional accessory. There is a Pre-Amp connection, which would be an output, hence causing the problem you are having. Best of Luck.
Posted on Sep 14, 2007
I need help on how to set up my receiver AVR 1513
The owners manual can be found at many sites on the internet if you google for Denon AVR 1513. One site is
Jul 07, 2014 | Denon AVR-1513 3D A/V Receiver - 5.1...
Avr 1513 no signal to subwoofer
Check its speaker connections. Check the speaker using a dry cell. If it is found OK, check the sound settings. If you wish to get more details, check this link.
Mar 22, 2013 | Denon AVR-1513
How to connect denon AVR 1513+Bose Acoustimass 5
Plug the speaker wire from the speakers themselves directy to the receiver or you can plug them into the acoutimass module and the module into the receiver using speaker wire.12_16_2013_3_46_09_pm.gif
Feb 19, 2013 | Denon Avr-1513 5.1 Channel 3d Pass Through...
Denon avr-1513 shutting off and blinking red light
Sounds like you could have a bad speaker connection. Try disconnecting the speakers and see if it stays on. If so, connect one at at a time until it goes off to determine which one.
Jan 20, 2013 | Denon 5.1 Channel Receiver 1080p AVR-1513
Yamaha rx-v663 is there a firmware update to get hdmi 1.4a support ?
Unfortunatly there is not any firmware to upgrade your unit to a higher HDMI format. There is a firmware though that corrects the following symptoms.
1. In case of playback of some DTS-HD Master Audio stream, pop noise may be generated.
2. Test tone may not be output under specific YPAO condition.
3. When test tone is output from presence channel, surround R channel is simultaneously output when speaker settings are PRESENCE SP "EXIST" and SWFR "NONE".
4. Multi channel input setting will be reset after power off the unit, in case of setting "INPUT CH" to "8CH" and "FRONT" to "VCR" or "V-AUX".
Apr 10, 2012 | Yamaha RX-V663 Receiver
I'm trying to connect a Samsung HD LCD tv to a Denon AVR1508 receiver using HDMI cable so that the TV sound comes thru the receiver/speakers. which jack do I use (on both the tv and the receiver,
connect the hdmi to the tv (hdmi input 1) and to the receiver (hdmi output) you must make sure that the receiver input settings are assigned correctly. Then hook up all of your devices to the receiver. remember that the 1508 dosent do hdmi upconversion, so if you have any devices that are NOT hdmi, you need to run rca cables from the output of you receiver to the input of your tv. If you have any digital inputs coming out of your devices, i would recommend using them. your 1508 has two inputs that are assignable.
If all of your devices are hooked up to your receiver, and its hooked up to your tv properly, just turn down the sound on your tv, and turn up the volume on your denon!
Dec 04, 2011 | Denon AVR-1508 Receiver
Trying to connect HP M9060N and Sharp Aquos through Denon AVR 1508, only get 'no signal' response. Have HDMI 1 set to DVD, HDMI 2 to AUX, HDMI 3 to TV, which is order of HDMI outlets on receiver.
Depending on your TV inputs, you are better off to run video componenets through TV first then, connect TV to reciever via digital optical. Recievers have video pass through but, noyt the best route. You can use TV's menu to choose what you watch and, only have the one output from TV to reciever. Make sure you scan through TV and reciever menus to make sure you are selecting the right channel.
Jun 21, 2011 | Denon AVR-4306 Receiver
I just bought a Denon AVR 1611. All inputs are HDMI (Cable TV, Blu-Ray) and the monitor output to the TV is HDMI. ainly I listen to the audio out of my TV and occassional on my surround sound. I would...
avatar7.jpgcurt, I bought this Denon AVR 1611 and I have HD cable. If you have cable you can set it up two ways. First way (the way I have it) is to get a switch box with 2 HDMI
out (mine has 4 inputs and 2 outputs) and maybe 2-4 inputs. Put the cable from the wall in one of the switch box inputs. Now hears the cool thing. Put 1 of the outputs from the switch box to the Sat/Cable input on the 1611 then put the another output to your tvs HDMI input. This allows you to switch from the tv only output or the 1611 surround output without touching the switch box. The other way is to buy a converter from HDMI to VGA. The only thing here is that you would have to setup your sound through Aux in the front of the
Mar 06, 2011 | Audio Players & Recorders
When right channel is wired it shorts out the power supply. Aragon 8008 when powered up without input and output, no problem. When connected with speakers and line level feed in, the left channel works...
Fuses blow when there is an overload caused by a short circuit. If the speaker you connect up to the amp causes a short. There is either a shorted part in the speaker or the wires to it are touching at some point. Assuming you can sort out the speaker issue and connecting a good speaker with good wiring and it still causes a short and blows a fuse. Then it's likely the output device(s) in the right channel have developed a short themselves. Perhaps as a result of being connected to faulty wiring or speakers.
Jul 18, 2017 | Aragon 8008 MK II 2-Channel Amplifier
Top The Audio Players & Recorders Experts
Jose Ma DM.
Jose Ma DM.
Level 1 Expert
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
