Question about Power Computers & Internet
Have vingcard 2100 system...the power keeps going off on the handheld reader...when the power button is pressed again it comes on ,,but the date is all messed up and i have to reset the date again...
Just had the same thing- I blew out the plug port and re-plugged it in, charged for an hour, and now it turns on.
Posted on Jul 25, 2007
SOURCE: date/time imprint. Coolpix 2100
To remove date imprint. This is the solution provided by Nikon more than a year ago. Switch on> set to green>menu>scroll down to Date centre/right on multi selector>select 'off.' Job done
Posted on May 01, 2008
SOURCE: panasonic camcorder dv
This problem is in the owners manual. It says that if you press reset and the problem keeps recurring you must have it serviced. Per the panasonic website if you purchased the camcorder greater than 1 year ago the flat fee for repair is about $265. Buy a new camcorder, thats the most cost effective solution.
Posted on Nov 06, 2008
SOURCE: technics sa dv280 hard reset
Posted on Dec 13, 2008
The same happens from time to time with my panasonic NV-GS11 GC video camera and I have no idea what is causing it. But what I normally do is just turn it of wait 10 seconds and turn it on again. If it stil comes on try removing the tape and see if it is faulty.
Posted on Dec 14, 2008
Palm T3 frozen, tried restart in hole, nothing?
Doing a soft reset A soft reset tells your handheld to stop what it's doing and start over again. None of your information will be lost. After a soft reset, a screen appears that lets you reset the date and time, if needed. To do a soft reset, use the tip of an unfolded paper clip (or similar object without a sharp tip) to gently press the reset button inside the hole on the back panel of your handheld.
If a soft reset does not unfreeze your handheld, you need to do a hard reset. Doing a hard reset Only do a hard reset if a soft reset doesn't solve your problem, or if you want to clear all of your information from your handheld. [!] IMPORTANT A hard reset deletes all records and entries stored on your handheld, including the username that identifies the handheld. Before you do a hard reset, be sure to synchronize.
1spacer.gif Press and hold the power button. spacer.gif 2spacer.gif While holding the power button, use the tip of an unfolded paper clip (or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your handheld. spacer.gif 3spacer.gif Wait for the Palm Powered™ logo to appear, then release the power button. spacer.gif 4spacer.gif When you see the message that warns you about erasing all of the info on your handheld, do one of the following: blank.gifPress Up on the navigator to finish the reset and show the Digitizer screen.
blank.gifPress any other button to do a soft reset.
Jan 31, 2008 | Palm Tungsten T3 Handheld
Factory Reset for Tungsten T5 handhelds
If you've set a password on your device, any hard reset will automatically become a Factory Reset. With this method, you'll enter a password and then perform a hard reset.
1.On your handheld, launch the Prefs application. From the list that appears, under General, select Security.
2.If the Password box says "Unassigned," tap the box and create a password for your handheld.
3.Once the password has been set, hold down the Power (on/off) button on your device.
4.While holding down the Power button, turn over your device so that you can see the back of it. Still holding the Power button, use an unfolded paper clip or a similar small object to gently press the RESET hole (where?). Keep holding the Power button throughout.
5.While still holding the Power button, the screen will show the Palm logo and a progress bar will appear at the bottom. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
Keep holding the Power button during this screen. When you see this screen, you can release the Power button.
6.A message will appear warning that you are about to erase all the data stored on your handheld. Press UP.
7.You may see a screen that says "Reformatting in progress. This may take several minutes." This screen will remain for several minutes (up to 10 minutes). Don't do anything while this is happening.
8.If you performed this reset correctly, the screen of your device will go blank after several minutes, and you will not be able to turn on your handheld. The charging LED will not light up. (any other activity - such as the Palm OS logo and then the Applications launcher appearing - means the reset was performed incorrectly; try again)
9.Your device will appear "dead." To wake up your handheld, perform a soft reset.
on Mar 11, 2010 | Cell Phones
Need to reassemble at vingcard 2100 lockset
I can help you out. Please contact me from the "contact us" page on my website I need to get a little more info from you about the version and then I can provide with you some help. You can also call me Monday-Friday. Thanks, Ken Croston Jr. 407 814 8974
Nov 22, 2012 | Locks & Locksmithing
My navigon 2100 doesnt work after the update. help
I own a navigon 2100 as well. Very nice device and you can install the 5100 software and the 7100 maps and points of interest. is the best resource for 2100 help.
Try this:
Hard Reset Procedure - if the PNA is on, press the Power button until the unit goes off. Press again and hold the button down - the screen will come on and after a few seconds go off again. Press the Power button again and the screen will come back. If you get the opening "music", you know the Hard reset was successful.
If you leave the memory card out and keep the unit powered on, you will after a few 10's of seconds go into the Demo mode. When you reinsert the SD card a soft reset will occur (equivalent to pressing the recessed button on the left hand side) and the unit will initialize into whatever the SD card tells it to (see below).
Apr 13, 2011 | Navigon 2100 Portable GPS Receiver
How do I do a hard reset?
Remember that when you hard-reset, all of your personalization and information will be deleted. Here are the steps:
  1. Press the POWER button
  2. KEEP holding the Power button down, use the stylus pin to gently press and release the Reset button (on the back in the middle of the device) - don't take your finger off the Power button
  3. When the "palm powered" screen is displayed, release the Power button after 3 seconds.
  4. You'll receive a warning message that you are about to delete everything
  5. Press the Scroll button (bottom and center of the device with the triangle symbol on it.
You have now officially hard reset the system and you will need to go through the initialization process again.
Feb 08, 2011 | Sony CLIE PEG-SJ22 Handheld
Qt-2100 wopnt turn on
Try this first:
Turn power off at wall.
Hold the top right corner button on the keyboard (usually an item button. must be top right button) keep your finger on it.
Turn power on at wall and wait 5 seconds.
Let go of button.
You should see a copyright message on the screen.
Press the right hand part of the subtotal button.
Wait until it asks to flag clear and press YES button. It should arrive at the logon screen. Now log on and try it.
If anyone needs a Casio QT-2000 or QT-2100 manual, go here
Sep 29, 2010 | Casio Parts Cash Register PC Desktop
The screen is showing "reset" but the machine will not reset. When "restet" button is pressed, screen goes blank then comes back showing reset again.
1 Press and hold the power button.
2 While holding the power button, use the tip of the stylus (or a similar object
3 Wait for the Palm Powered? logo to appear, and then release the power button.
4 When you see the message that warns you about erasing all of the info on your
* Press Up on the 5-way navigator to finish the reset and show the touchscreen.
* Press any other button to do a soft reset.
May 17, 2010 | Palm Tungsten E2 Handheld
When trying to sync, error message reads (sys 0505)(0,841).What can I do? For Palm TX handheld
Try to perform a System Reset (see article linked below). If it works to break the loop, you should then be able to delete the offending "My Palm" software and perform a Hotsync to backup your data to your desktop.
If that doesn't break the loop, you'll have to perform another Hard Reset. Sometimes, a Hard Reset takes a couple of tries to get it right, since it's easier to do it wrong than to do it right.
This article discusses the various types of Reset for different Palm devices:
Until you break the TX out of its loop, you won't be able to get the data from it.
To see the Palm OS version running on your TX, enter the Menu, select Info, then Version.
To Get Out Of A Loop:
  1. Perform a SYSTEM RESET by doing the following:
a) Press the UP Button
b) And THEN press and release the RESET Button
c) When you see the second Logo (Palm Powered) release the UP Button
d) Now check if your SYSTEM RESET worked by going to Beam Receive. If it goes back to Off even after you put it to On it means you were successful
2. Now Perform A SOFT RESET by pressing and releasing the button in the back once
  1. After a soft reset, a logo screen appears, followed shortly by a Preferences screen asking you to set time and date.
  1. If a soft reset does not break it out of the loop, you may need to try one of the other resets below.
  1. Do an INCOMPLETE HARD RESET by holding down the power (on/off) button on your device.
  1. While holding down the power button, Press and release the reset button on the back of your handheld device
  1. Keep the power button pressed and release it when the “Palm Powered” logo appears.
  1. A message will now appear warning that you are about to “Erase All Data”. And this will happen if you press UP or DOWN.
  1. Instead you press left or right to begin a soft reset, leaving your data intact.
  1. Your device will then take you through a series of screens to calibrate the digitizer and verify the time and date.
Sorry this was so long, I tried to put everything down that might help you.
Aug 03, 2009 | Palm TX Handheld
Times T307S Can't get it to come on
I'm not sure if this will assist all who have this issue, but I noticed this morning when my radio would not come on (after about two hours of pressing every button on the thing), that the Off/Reset button was slightly jammed at the top of the button. I popped it out and my radio came right back on. That may explain why, each time this has happened, it finally comes on after hitting the button several times, it pops the button back out so the radio works again... Hope this helps!
Apr 24, 2008 | Timex (T307S) Clock Radio
Computers & Internet Logo
Top Power Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
