Question about Ovens
I have a Simpson Evolution 906 oven (Model - 63C906W). I removed its door for cleaning the oven, now I am unable to put the door back.
Do I need to do anything to hinges on the door before I put it back. I just align the hinges on the slot and try to fit the groove on the hinge in the slot, but the hinges don't go in completely, so when I try open the oven door fully to put in the locking mechanism the hinges slip out of the slot. I understand that the groove on the hinge has to lock in into the slot for it not to slip when I open it fully.
  • 1214 Answers
SOURCE: cant get the oven door back on
Use a wrench to lower the hinge arms down. There is a hole in the arm that you can put a nail into through to the frame of the oven/ This should leave the arm in an outward position. Do this on both sides of the oven, or both hinges
Pick up the door, and slide the door onto the arms until they stop.
Press down on the top end of the door lightly so that you may remove the nails inserted above.
Lift the door to close. If you didn't slide the door onto the hinge pieces far enough, then repeat the procedure.
Posted on Jan 24, 2009
SOURCE: Simpson Evolution 906 Fan forced oven
have you solved it?
Posted on Aug 29, 2009
SOURCE: How to put oven door back on after removing!
Although very tight (because the oven is only 1 yr old) i managed to get the hinges into the open position, then slide the door into position on the oven and close the door. The hinges did go back and lock as they should but I struggled for almost 30 mins before success.
Posted on Jan 09, 2010
SOURCE: Simpson Evolution 906 Oven light. how to replace it?
I have just replaced mine & had the same problem. I couldnt remove the cover. I found that I just couldnt grip the cover well enough. I got some rubber washing up gloves & used them to grip the cover. It was still tight but it un skrewd quite easy this way.
Posted on Jun 13, 2011
SOURCE: dhow do i remove stoves efa600H oven door hinges?
1. Open the oven door and remove the 2 screws at the side of the inner glass window 11cm above the hinges and lift off the door. Place it somewhere safe!
2. Remove the 4 screws that you can see nearest to the left and right edges of the oven with the door removed. These secure the oven to the kitchen unit.
3. Slide the oven forwards about 20cm out of the unit, being careful not to pull on the cable.
4. Each hinge is held in place by 2 screws at the side of the unit now exposed, about 18cm apart. Remove them and slide out the hinges. Reassembly is the reverse of the above.
5. Note that the hinges have no means of adjustment. If not working properly, renew them.
Posted on Jan 02, 2012
I have a simpson evolution 904 oven and the wiring diagram has been lost , would you have a copy
Jan 28, 2015 | Ovens
I took the door off my Simpson Evolution oven and now it won't go back on. Help
you have to push the hinge down and lock it you will need a screwdriver and turn the round disc the one will the slot in this will hold the hinge down do this both sides of the door and put the door back resting into the oven and then turn the slotted discs and that should do the job
Apr 21, 2012 | Smeg Evolution SCP171X Dual Oven
Users manual for simpson evolution 906 fan forced oven
my lovely wife just put the grill on for 5 mins with the door closed and the inside glass went bang, where can i get a manual for this oven ???
Dec 12, 2010 | Ovens
Jun 28, 2010 | Ovens
Simpson Evolution 904 Wall Oven. The grill doesn't always work
It sounds like you may have a faulty switch. Write down the appliance name and model number. Using your computer go to you will be able to search for your switch. They are very reasonable on prices and give fast delivery. Hope this helps.
Nov 08, 2017 | Ovens
Simpson oven 736 evolution turns itself on briefly then turns off
sounds like you have a control board problem
Jun 12, 2009 | Ovens
Unable to take out light bulb
I can tell you it screws out . i had to break mine to get it out ( the bulb cover that is) Still had some thread left to wind back up.
Dec 22, 2008 | Ovens
Oven keeps switching the fuse box off
you must get someone who understands electrical problems to look at it as this light is at full mains voltage, if the wires are burned then they must be replaced with ones that are silicon covered because of the heat and if a connector is used then this must be made of a ceramic material again because of the heat
Aug 03, 2008 | Ovens
Ovens Logo
43 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
