What remedies are there for a LOC error code - Washing Machines
How do I unlock a radio when it displays the word LOC on a 1997 GMC Jimmy?
It is written in your owners manual. you need a code which the original owner would have written down somewhere in the manual. If no code, no radio. Only the dealer can unlock and make new code.
Dec 09, 2014 | 1997 GMC Jimmy
LOC showing on screen
Hello Annie, thank you for allowing me to assist you!
I see you are still receiving error code "LOC" even after replacing the door lock assembly. Let's try unplugging your washer once again to determine if it is a false error code. It is important to wait roughly ten minutes and then turn your washer on. Before selecting a cycle, press OPTIONS and SELECT at the same time for 20 seconds until "LOC" is no longer displayed. If the error code does not clear, then your washer more than likely may be experiencing an issue with the control board or wiring harness. I hope this information helps to some degree.
Feb 18, 2014 | Electrolux EW1000i Front Load Washer
ERROR CODE LOC
I'm not sure what just happened here-I posted and my answer went away! Push and hold temp button for 3 seconds and LOC should clear-if you want to lock controls again repeat-cheers Denny
Oct 12, 2013 | Haier Washing Machines
Loc code on my 2000 sunfire radio(factory installed) and when i use the steps to get the first 3 digits(preset 2-3 or 1-4 for 5 to 10 sec) no code appears and the car is running.
try speakn to a dealer tech-call service dept----sometimes disconnectn batt or sweepn with a scan tool can remedy--ask for anothr code too-cud work
Sep 14, 2013 | 2000 Pontiac Sunfire
What does error code Loc mean?
Hello & Welcome to FixYa
Press & Hold the START PAD for 20 seconds to turn off LOC error. Please get back to me if you have any other questions.
Kevin
Aug 30, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
I have error code loc the machine won't
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 27, 2009 | Kenmore Elite 45986 Front Load Washer
Error code LOC
Jun 27, 2009 | Kenmore 44932 Front Load Washer
Error code LOC on kenmore front load washer
Press/hold LOCK for 5 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 08, 2009 | Kenmore Elite 45986 Front Load Washer
Error code LOC on frigidaire front load dryer
hold down "OPTION and "SELECT" button at simaltaniously until screen resets. This should work for you.
Jan 01, 2009 | Dryers
Frigidaire - GLTF2940FS0 -LOC message on display
Peace,
ngafm at your service,
With an error code or loc message the only way to find and to repair this is,
First unplug the washer and wait a ten minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
Sep 08, 2008 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
