Question about John Deere Garden
4300 John Deere tractor PTO stuck ingaged won't start Checked linkige help
  • John Deere Master
  • 7,515 Answers
Greetings, I read your question and I think Reliable-Store can help you in this. Here's the site link.
Best Manuals
Posted on May 16, 2017
Ive got a john deere 4055. Has a new clutch and pto release bearings and piston. The pto will not ingage and there is no pto pressure.
did the mechanic that installed the new parts pre prime the hydraulic pump on install , ive had limited luck using another tractors pump on remote circuit to back feed on the return line to "externally) prime the pump , but it has worked a few times , worth a try if you have the means
Mar 28, 2015 | John Deere Garden
How can i get pto cluch to ingage?
This problem needs more information provided.
Look for safety interlocks that have not been engaged, or possibly broken. The switch under the seat will not allow the PTO to engage if it does not detect someone in the seat.
If the PTO is electric, look to see if the plug is loose at the PTO.
Check to make sure that the PTO mounting bolts are still secure.
May 20, 2014 | John Deere Garden
X595 john deere pto wont kick in
These John Deere Garden Tractors have a RIO (Reverse Implement Option) on the PTO. If your PTO is engaged and you back up, the PTO will automatically stop. To reset it, depress your PTO engagement switch to the OFF position. Take your foot off the reverse pedal. Pull up on the PTO engagement switch. The PTO should restart. To use the RIO feature, pull up on the PTO switch for a second or two just before you step on the reverse hydrostatic pedal. The yellow RIO indicator light should come on your dashboard and you can now back up with the PTO still running. Works great for snow blowing when I don't want to keep resetting my electric PTO clutch to keep restarting my snow blower.
If your PTO will not restart, you may have a PTO switch starting to fail, or a likely logic problem in your electric PTO control module, or one of your forward/reverse indicator switches, which is linked to your PTO control module along with the overtemp circuit, is stuck/faulty.
Feb 20, 2013 | John Deere 26HP Hydrostatic 54" Riding...
John Deer L130 lawn tractor: Start with jumper on solenoid.
i would check the safety switches you can jump them and find the bad one
Mar 28, 2012 | John Deere Garden
Problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Jul 25, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Problem with plowing with my john deer 4440 tractor
check you air cleaner and fuel filters if they are dirty it will rob horsepower
Mar 31, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Mar 11, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
44 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
