Question about Kubota Garden
Would like to add a creeper gear to my Kubota M110 tractor. I need to achieve .8 mph at 540 pto rpm's. Can it be done.
    Top Expert:
  • Kubota Master
  • 50,572 Answers
The specifications for the tractor show a transmission int-shift 24f/24r/(32f/32r) option with creep
creep speed is ( casset e type is listed at optional(.19-.74km/h)
.74 km/h = .459 miles /hr
the specs show that the pto speed is 500 rpms /1000rpms ( interchangable rpm)
reference www.kubota .com.au or m110gx-kubota tractor coorporation
you will have to talk with the service dealer technicians as from the specifications , what you want is available as an option
if not and you are using some sort of seeding machine , it may be an option to change the gearing in that machine to achieve the same results
Posted on May 16, 2017
I have a 5900 ford tractor,it is hard to put it in gear( grinds). What needs to be done so that you can change gears without it grinding?
Usually it means you need a little more clutch adjustment and/or a lower engine rpm. Your synchronizers could be bad. The fluid level can be low, but overfilling on some series will flood the rear brakes with lube.
On some models the pto must slow down or stop spinning if an implement has momentum and you need to shift. There are free wheeling pto adapters which allow the pto to operate at a different rpm than the implement.
The high rpm on an automatic trans can result in shifting problems when changing gears.
Oct 27, 2017 | Ford Cars & Trucks
Massey Ferguson 699 PTO how to change from 540 to 1000 RPM it is in 540 at the moment
Increasing the engine speed, is the only way this can be done, with out changing the internal gearing.
May 31, 2017 | The Toys
Kubota m110 runs rough don't start
If it runs rough, it must start.
I'd be doing basic but complete maintenance.
- Oil change
- air filter service
- spark plug replace
- drain and flush carb
Jan 06, 2016 | Kubota Garden
I have a kabota tractor and the Pto will not engage on the bush hog
pto is on the tractor, not on the bush hog, if it won't engage you have pto problems on tractor, needs to be serviced
Dec 01, 2015 | Kubota T1600H Mower tractor
Is it possible to convert my 735 Moco from 1000 PTO RPM to 540 PTO RPM?
you do mean a 100 rpm pto up to a 540 rpm pto correct ?
tractors that have the wrong rpm are difficult to speed up as your going to have to give up shaft power (Horsepower) to do this so if your implement is already drawing your hP down , adding a speed increaser is going to make things worse
some out of the "normal" box things ive seen folks using the belly mower take off instead of rear pto , belly mower take off's are sometimes a higher speed but again have less power than rear pto points
Nov 03, 2015 | Garden
How many horsepower does a kubota tractor B8200 has / what year was it made
It was made between 1983 and 1990
Kubota B8200 Power:
Engine (gross): 19 hp [14.2 kW]
PTO (claimed): 16 hp [11.9 kW] (gear)
14.5 hp [10.8 kW] (hydro)
You can find more breathtaking information about this tractor at
http://www.tractordata.com/farm-tractors/001/2/7/1274-kubota-b8200.html
Apr 29, 2015 | Kubota Garden
Kubota L 3300 rear PTO will not engage when very cold weather solution please
Try using a lighter gear oil - some oils are thicker in really cold temps - like molasses while its warm drain it and use a lighter grade, - check the manual and go with a thinner type - ask local car parts store. sometimes the manual will give a type for colder weather. Good luck
Nov 30, 2014 | Kubota Garden
Kubota b7800 does reach 540 RPM at full throttle
Check the linkage loosed all the way pump or carb.
Dec 08, 2013 | Garden
Replace motion drive belt garden tractor craftman 917273080
On what make and model riding mower ..
Jan 19, 2009 | Garden
Garden Logo
27 people viewed this question
Top Kubota Garden Experts
Vernon Taylor
Mike Henne
Level 1 Expert
Are you a Kubota Garden Expert? Answer questions, earn points and help others
