Question about Camping, Backpacking & Hiking
How to change the batteries in a peak performance flashlight model number PKCO TV
Samsung LED TV # LN52A860S2F audio NO PICTURE..has lights when I look threw the vents
Perform flashlight test to see if the problem is with the backlights inverter board.
Jun 15, 2017 | Samsung Televison & Video
Samsung LCD TV model number:LN40D550K1FXZC. No Back light problem. Audio works, Flash light test shows picture. i have changed the Back light inverter with no change.
You have to verify if there is power going in to the back light inverter. If there is power going in to it, check if there is power coming out. If no power is going in to the inverter work back to the source; most likely the main power supply area. It would be nice for you to have the shop service manual for the set if you are to spend some time on trying to fix it. You may need a scope to perform specific tests indicated in the manual.
If there is power leaving the inverter, then the problem and be the lamp assembly inside of the display. Depending on the model the display lights are not always serviceable.
Jan 25, 2017 | Samsung Televison & Video
Where can I get a Manual for jump-starter 300
Battery Jump-Starter 300TM - All Power Supply
allpowersupply.com/Productlib/manual-PKC0AO.pdf
Translate this page Conserve este Manual del Propietario para referencia futura. P/N XXXXX, 3/09. 1 . TM. Battery Jump-Starter. 300TM. Model No.: PKC0AO. Owner's Manual.
Jul 24, 2014 | Peak Compact Battery Jump Starter 300 For...
How do you replace light in Peak rechargeable spotlight
Sorry I don't know how to change the lights, but I need to know the charger volts and mA. Could you look at your charger and let me know please? ian 83877 at gmail
Jan 18, 2014 | Peak Performance Rechargeable Led Lamp...
I need a 110/120 volt ac/dc adapter power cord for recharging from standard wall socket. For a Peak 450 jump starter
After searching the internet for a ph number for Peak power I finally found the web.
http://www.peakauto.com/contact/site.
phone 800-323-5400
If the part department doesn't have the answer ask to be switched to tech support.
They were able to provide me with the part numbers I need for new wall supply cord and an DC adapter for the car.
My jump starter is no longer made...
Nov 15, 2013 | Peak Performance Peak PKC0BL 450 Amp Jump...
HP7 does not work
LIFETIME WARRANTY. SEND IT BACK. CALL COAST, ASK FOR THE REPAIRS DEPT, AND THEN SEND IT BACK. SIMPLE.
Mar 03, 2013 | Coast HP7 High Performance Focusing 251...
Camping, Backpacking & Hiking Logo
553 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
