Question about Staples Tools & Hardware - Others
My senco PW150 fires two staples some times. What is causing this to happen?
5 Suggested Answers
efs_perpends
  • 1996 Answers
SOURCE: Senco staple fastener not firing.
Make sure you actually removed the entire broken staple and there's not a piece still wedged up in there somehow.
Try raising the air pressure up to 125 psi and plug it in and unplug it a few times. Sometimes the piston can get jammed, and a smack with the palm of your hand on the side of the cylinder will jar it loose. If that doesn't work, try pulling the trigger as you jam the nose of the gun against a soft piece of 2x4 or something, repeatedly firing and jarring the tool. If this doesn't do it, you may have to open it up to clear the jam and put it back together.
Posted on Apr 07, 2009
rowdy45176
  • 2176 Answers
SOURCE: how do I get a part of a Senco model K staple gun
go to Senco.com and you can download a schematic and also order parts direct from them
Posted on Mar 19, 2010
  • 885 Answers
SOURCE: my senco 1/4" crown air stapler would not drive a staple & now leaks air constantly
It sounds like you have broken or damaged o-rings inside the gun and the only repair is to replace them. Senco does make kits to rebuild most of their guns. Go to http://www.senco.com/ and click on 'Parts Charts' at the top of the page then find your model. The PARTS GUIDE will list a rebuild kit if one is available. The part number will start with YK followed by four numbers. If there isn't a rebuild kit available for your gun, you'll have to order each o-ring seperately. All o-ring part numbers start with LB.
Posted on Feb 20, 2012
  • 885 Answers
SOURCE: my senco sps fires one staple, then hammer gets stuck forward.
If you've had and used the gun since 1998 and never rebuilt it, it's done you well indeed. If the driver is not retracting you most likely have broken or worn o-rings inside the cylinder. Senco makes a rebuild kit, part number YK0376. that contains all o-rings and wear items inside the gun. The kits run about $60 but your gun will be like new again. It's a relatively easy rebuild, just use lots of the Senco grease on the o-rings as you reassemble it.
Posted on Jun 07, 2012
What is wrong with my Senco pneumatic upholstery stapler?
only a guess but is the anvil sticking out the bottom where the staples come out . if so push it up a little with a flat blade screw driver .
Feb 23, 2015 | Senco Tools & Hardware - Others
My senco sps fires one staple, then hammer gets stuck forward.
Jun 05, 2012 | Senco Tools & Hardware - Others
Air tends to leak near trigger of my senco sls15 1/4" crown stapler . how can i stop it?
You have worn or broken o-rings/seals inside the gun. You need a Senco repair kit YK0393. Senco doesn't make them any more but there are still a few to be found on the internet. If you can't find one, go to the Senco webpage, find the parts breakdown for your gun and order all of the o-rings, seals and gaskets and rebuild your gun.
Feb 09, 2011 | Senco Finishpro 15 Finish Nailer & Sls15...
Sns45xp senco dosent shoot anl leak air for the cap
You have worn or broken o-rings in your upper firing and trigger system. You need a Senco repair kit #YK0230 to fix your problem. Fairly easy to do, replace one o-ring at a time to make sure you get them back in place properly and use the grease in the kit liberally. Since you'll have it apart I also recommend you get Senco repair kit #YK0231 which is the lower seals and piston stop. If the upper rings are going bad the lower rings won't be far behind.
Feb 03, 2011 | Senco SNS45XP 16Gauge Construction Stapler
Do i need to buy piston driver assembly or can i by just the driver blade
These new Senco FinishPro tools are chinese made and unlike the old US made tools, you need to buy what's termed a 'piston driver unit'. It should be fairly cheap though, compared to old Senco parts.
Jan 17, 2011 | Senco Finishpro 15 Finish Nailer & Sls15...
I have an older model senco finish nailer that continuously blows air out the exhaust what is the problem?
probably a split or stuck o ring. You can go to Senco.com and download a breakdown and purchase a rebuild kit for this tool.
Mar 27, 2010 | Senco Finishpro 15 Finish Nailer & Sls15...
How do I get a part of a Senco model K staple gun
Mar 19, 2010 | Senco Tools & Hardware - Others
Senco narrow crown Stapler Piston will not go back
There is a spring and piston in the back cap of the nailer, this must be free moving and not sticking. If it is sticking it will cause the problem you discribed. If that looks ok you probably should install an o-ring kit and that should solve the problem. A Senco service center will carry the proper parts.
Apr 09, 2009 | Tools & Hardware - Others
Mar 28, 2009 | Senco Fastening Systems 760102N Pro 25 Xp...
Tools & Hardware - Others Logo
57 people viewed this question
Top Staples Tools & Hardware - Others Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jo Ann
Level 1 Expert
magna buff
Are you a Staples Tool and Hardware - Other Expert? Answer questions, earn points and help others
