Question about Lenovo Computers & Internet
Does lenovo z50-70 have a hdmi in - Lenovo Computers & Internet
  • Lenovo Master
  • 10,291 Answers
No. The HDMI port is an OUT port so you can use a TV with an HDMI input as a monitor
Posted on May 16, 2017
How to fix Lenovo laptop hdmi port
Double check your HDMI cable. Use another one to be sure. If you are positive your HDMI port is physically broken, take it to a repair shop. It is not something you can do easily.
Mar 13, 2015 | Lenovo Computers & Internet
Sharp aquos lenovo sl410 hdmi cable
I would look for a newer driver from lenovo. Has 8.1 got a fix?
Jan 19, 2014 | Lenovo ThinkPad SL Series SL410 (2842F7U)...
Does Lenovo y560 has hdmi input?
It has HDMi output, but not input. It will output to a HD tv or monitor with HDMi input, but you cannot input anything into the notebook, check the Lenovo website.
Dec 26, 2013 | Computers & Internet
Lenovo 3000 n200 built in camera not working in windows 7
Instructions
Identify why you need an HDMI connection from your computer. Because the 2764 does not have an HDMI port, you will need to obtain some sort of adapter to connect to an HDMI device. There are a number of different ways to achieve that connection.
Purchase an external USB video card with an HDMI output. These devices have a number of benefits, including the ability to display a different image on the HDMI output than that which is being displayed on the screen. One example of these devices is the Sabrent USB-2011 which can display a 1080p HD signal over its HDMI connector. Other devices will also include support for audio and send it along the HDMI wire with the video signal.
Use a DVI-to-HDMI adapter if you have a Lenovo ThinkPad USB Port Replicator with Digital Video. This device takes the computer's existing video card and displays its signal over DVI. DVI-to-HDMI adapters are both affordable and easy to obtain.
Convert the computer's VGA output directly to HDMI. Because VGA is an analog signal and HDMI digital, doing this requires a special piece of hardware such as the StarTech VGA to HDMI converter with audio. Simple VGA to HDMI cables will not work, due to the lack of digital output from the T400's VGA port.
Jan 10, 2013 | Lenovo Computers & Internet
Lenovo ThinkPad displayport to HDMI via Adapter does not work at all
Hi Gerd,
I see that you are having issue using the HDMI port on your Lenovo system. This can just be a possible driver concern on your machine.
see this link for the Drivers for your machine. still I recommend that if you have Warranty on your system that you call Lenovo for further assistance regarding this concern, and for the proper drivers to be installed on you Machine for the HDMI port to work.
I hope that the link can help, if not call call Lenovo for further assistance for the proper driver to be installed on your machine regarding your HDMI.
Thanks.
Oct 22, 2012 | IBM Lenovo ThinkPad W700 (27584SU) PC...
How to connect dish tv to my laptop? It has inbuilt tv tuner.
Your Lenovo laptop can be hooked up your TV if you have a model that is capable of TV output. Newer models with HDMI ports can easily connect to newer TVs that have HDMI input jacks. For older laptops or TVs, you will need other adapters or cables. The most common of these is an S-video jack, which has a small round connector with several pins arranged in a circle. For S-video connections, you will need to hook up the audio from your laptop to your TV separately.
Things You'll Need
HDMI cable
USB-to-HDMI adapter
OR
S-video cable
Audio cables
HDMI Connection
Turn on your Lenovo laptop and HDMI-enabled TV.
Connect one end of your HDMI cable to the HDMI port on your laptop. Lenovo's IdeaPad series has these ports. If you have a ThinkPad or other Lenovo model, connect a USB-to-HDMI adapter to your HDMI cable, then plug the USB end of the adapter into any USB port.
Press the "FN" and "F7" keys on your keyboard. This will switch the laptop's display to the TV. You can then use your TV screen as a monitor or use the laptop's DVD drive to watch movies on your TV.
S-Video Connection
Turn off your laptop and TV. Connect your S-video cable to the laptop on one end and the TV on the other.
Plug audio cables into your audio out jacks on the laptop. If you do not have stereo audio output, you can use the headphone/speaker jack. Add a splitter adapter to split the sound into stereo instead of mono (single speaker). Plug the other ends of the audio cables into your TV.
Turn on the laptop and let it boot up. Then turn on the TV. Right-click on your desktop screen, then select "Properties."
Click the "Settings" tab, the "Advanced" button, then "ATI displays" or "Display device" or the similarly worded option, depending on your system. It is not the "On screen displays" option in any version.
Click on the option that suits your system, such as "TV" or "LCD." Click "Apply," then "Yes" to confirm, if necessary. Click "OK" to exit. Your display should be visible on the TV screen. If not, try pressing "FN" and "F7" to toggle the display to the external screen.
Sep 13, 2011 | Lenovo IdeaPad Y560 Laptop
I have lenovo ideapad y510 which i wnna connect to samsung LED tv 6 series with HDMI input. So basically i want a cable which connects laptop video output to HDMI input in TV.
Hi er_gauravpra,
I see you want to use an HDMI connection for your Video from your Lenovo Y510.
I have checked information about the Y510 and it does not have the Technology of HDMI on the Y510 system of Lenovo, Y510 system only have the VGA port where in you can use a VGA cable to get video output to an External Monitor.
Regarding the issue about HDMI I have not seen any Converters yet that can be bought from anywhere to convert VGA to HDMI and I believe that will not be possible since VGA is a lower type of video output than what an HDMI can.
I do apologize but the Y510 systems does not have the HDMI technology to on it.
I hope this clarifies everything about your Query.
Have a nice day
mvincentc
Jun 12, 2011 | Lenovo IdeaPad Y510 Notebook
I conect my lenovo laptop Y 410 with Panasonic THP42C10 D for Vidio There are no sound in TV
Hi dr_piyushpat,
I see that you conencted your Lenovo Y410 to a Panasonic THP42c10 LCD TV, see details below.
*The Audio will dpened on what cable connection you have from the Laptop to the LCD TV,
*You have Y410 I do not think that HDMI will be an option.
*I believe that you are using the VGA port on the Machine for an extended Video.
*The Audio will really not be coming out of the Panasonic TV if you are using a VGA cable since that is only for Video you will need an audio cable Jack that will relay audio from the Laptops Audio Jack to the Audio Jack of your Panasonic TV thsi is the only way you can get audio out from the Laptop since you are conencted using a VGA cable.
* do not think that HDMI is present on your Lenovo Y410, but if ever you may have that connection/port the way to get Audio from an HDMI conenction is to change the audio PLayback properties and selct HDMI as the default device for the Audio to work using HDMI.
I hope that this helps.
have a nice day,
mvincentc
Feb 13, 2011 | Lenovo 3000 Y410 Laptop
Computers & Internet Logo
175 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
