Question about Bosch Dishwashers
Repaired bosch shu66C dishwasher Can't get stainless steel panel on door back on. Help
Cerfer39
  • 709 Answers
SOURCE: Bosch Dishwasher
Hi ED, It sounds like a real problem here. If the springs are still in one piece, my best guess is to to remove the springs from the door. Then attach the springs to the dishwasher body first, then reattach the spring to the door. Not an easy job, good luck. If you have further problems check with www.repairclinic.com, as the repairguru there may be of more help.
Posted on Sep 26, 2007
IFIXALL
  • 868 Answers
SOURCE: Doo clips fell out when changing white door panel to stainless steel panel
What door clips ?????
Posted on May 21, 2008
odiebugs
  • 949 Answers
SOURCE: bad odor when open door after cycle
This is just a suggestion, run a cycle and after a few mins of it washing, open the door and add a cup of bleach and let the washer run. See if this helps.
Posted on Apr 09, 2009
SOURCE: want stainless steel front door for dishwasher
There are a couple of ways to do this. The easiest one is to check out www.applianceart.com and they have many different options for "wrapping" the front of your dishwasher. They change it often so if you don't see it, call the company becuase I know they have it.
Posted on Jul 11, 2009
  • 246 Answers
SOURCE: I want to replace the white door panel with stainless steel
Have you checked with www.applianceart.com? They have faux stainless and real stainless options. PLus a ton of other choices there.
Posted on Feb 25, 2010
Is there a stainless steel door panel replacement for bosch dishwasher shx43c02uc
If there isn't, you might try having a local metal shop cut you a piece of stainless, fold and weld the edges to make a cover for the door and adhere it either with epoxy or a small tack-weld. I wound up having to have a cover made for my Mom's stainless-steel fridge when only white and black ones were available and a metal shop doesn't charge much for it.
Alternately, if the metal panel is housed in a frame, try taking apart the frame, removing the panel and flipping it over. They usually just paint the one side, and if the other side is bare metal, such as aluminum, you can use sandpaper to give it a brushed finish and some clear-coat spray paint to give it that shiny stainless look and durability. Then just reassemble the door with the stainless-looking side facing outwards and the wrong-color side facing in. Worked for Mom's dishwasher!
Aug 31, 2012 | Bosch Dishwasher Door Panel White - 245067
Replace Bosch SHU3306UC door panel with stainless steel?
Instead of replacing the entire door.
Go to http://www.applianceart.com
These guys offer every solution imaginable for refacing your existing dishwashers. They make dishwasher covers in a variety of designs, textures, solid colors and stainless. Check out their website and if you still have questions get in touch with these guys. They are able to walk you through all the available options and keep you from having to replace the entire door.
Jan 20, 2012 | Bosch SHU3306UC Built-in Dishwasher
Can I exchange the white door panel for a stainless steel panel on Bosch Dishwasher SHU5312UC/U11?
from my research all but 3 models have that option, I didn't see yours there, But if you contact sears or www.homeeverything.com I'm sure they can assist you
May 18, 2011 | Bosch 24 in. SHU53 Built-in Dishwasher
How do I tighten the door handle on my Bosch dishwasher model SHY56A 05UC/14?
Remove front panel then you can access the handle screws. Open the door and remove the 'torx' screws surrounding the perimeter of the door.
Oct 06, 2010 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch Dishwasher model SHU66C soap door will not open
This is most likely the actuator for the soap door. Unplug and remove door covers to find it, and check it is not seized. Look at "wax motor" online to understand working, as they often use these (and may appear siezed - when actually ok)
Check cables are not broken and connectors not corroded.
Replace actuator if you are uncertain, and try again.
Further problems may be the contact to control it in the controller assembly or a broken cable between the two.
Jun 06, 2010 | Bosch 24 in. SHU6802UC / SHU6806UC...
Can I get a different front door for my dishwasher?
From what I could gather, it appears that there may be a door panel kit available for your dishwasher. The kit appears to have the panel kit and the curved handle included. Some links for visual reference:
SGZ1005UC Stainless w/tubular Towel Bar Handle
SGZ1006UC Stanless w/curved Handle
Feb 06, 2009 | Bosch Evolution 300 SHE43M05UC Stainless...
Bosch Dishwasher
Sep 25, 2007 | Bosch 24 in. SGS43C12 Classixx...
Dishwashers Logo
23 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
