Question about Baby Gear
Selecting my seat - Baby Gear
Just bought a used jazzy select. It is front heavy. Can I move the seat back?
That depends on what's on the underside of the seat. If there is a lever that allows the seat to slide back and forth, you can. Some seats are not equipped to do that, but seats are available that do. Check Jazzy's website.
Oct 03, 2017 | The Health & Beauty
2006 LINCOLN ZEPHYR DRIVERS ELECTRIC SEAT WILL NOT MOVE BACK WHEN KEY IS TURNED OFF
Principles of Operation
The driver seat module (DSM) is on the controller area network (CAN) communication network. To support several vehicle subsystems, the module permits intermodule and diagnostic tool communications.
The DSM controls the memory driver seat and the passenger memory power exterior mirror. This passenger memory power exterior mirror feature allows the driver to program personalized mirror positions. Once the driver stores a mirror position, the driver can recall the setting by pressing the corresponding memory switch or by using a programmed remote keyless entry (RKE) transmitter. For additional information, refer to Section 501-10 .
How to Diagnose Controller Area Network CAN
Driver Seat Module - Memory Seat
The power driver seat, power outside rear view mirrors and power adjustable pedals are controlled by the driver seat module (DSM) only when the vehicle is equipped with the programmable/recall memory option. The DSM is located on the driver seat track.
This system allows automatic positioning of the driver seat to 2 programmable positions.
  • A power driver seat position can be stored at any time. The driver must move the seat to the desired position using the driver seat switch assembly. The driver must then depress the memory SET switch which activates the memory SET switch light emitting diode (LED). Within 5 seconds (before the LED goes out), the driver must select a memory position. Memory 1 is selected by depressing memory switch 1. Memory 2 is selected by depressing memory switch 2.
  • If no memory switch input is received within the 5-second time limit, the operation is aborted and the memory seat position switch (set switch) LED is turned OFF. This also occurs if one of the following inputs is received during the 5-second programming limit:
    • Driver seat control switch
    • Memory seat position switch (set switch)
    • Power adjustable pedal switch
A programmed seat position can only be recalled when the transmission selector is in PARK or NEUTRAL with the ignition switch in the RUN position. A position may be programmed at any time.
Easy Entry/Easy Exit
The driver power seat easy entry/easy exit feature can be enabled/disabled. Refer to Section 418-01 or the owner's literature.
This may need to be done with a scan tool
Apr 24, 2017 | Lincoln Cars & Trucks
Seat selection for israel trip April 18th 2017
I always use this site when picking seats... https://www.seatguru.com/
Apr 10, 2017 | Computers & Internet
Seat selection
not a technical question or for that matter not even a question
Nov 24, 2016 | Baby Gear
Power seat wire diagram for 06 ford fusion
http://bbbind.com/free_tsb.html free wiring diagrams ! Enter your vehicle info .under system select body an accessories . Under subsystem select power seats ! Good luck !
Jul 25, 2016 | Ford Cars & Trucks
How do I attach Bassinettes for twins onto city Select pram.
Seating configurations are on the baby jogger website and yes you can use 2 both parent facing tried to upload a pic but it wouldn't let me
/uploads/images/attach-bassinettes-twins-onto-city-34935601-5-1.jpg
/uploads/images/attach-bassinettes-twins-onto-city-34935601-5-2.jpg
/uploads/images/attach-bassinettes-twins-onto-city-34935601-5-3.jpg
Jan 21, 2015 | Baby Jogger 2012 City Select Double...
I lost the instruction manual of the Multi seat adaptor for the quinny zapp Xtra, anyone have it or know where to find it?
Hi
Go to www.quinny.com select the country you're in and select the product you have. A copy of the user manual can be found here.
Sep 26, 2012 | Quinny Zapp Xtra Multi-Model Car Seat...
How do u get the fabric cover off the baby car seat to wash it?
Good Afternoon
Full instructions are in the user manual. For a copy of the user manual if yours has been lost go to www.maxi-cosi.com and select the carseat, then select "Service" and you can download a copy.
Alternatively go to our Facebook page Dorel UK Customer Services and full picture directions are in our photo album.
Aug 31, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Need instructions for adjusting straps in maxi cosi tobi car seat also on how to remove covers to wash thanks tracy
Good Afternoon
Please visit www.maxi-cosi.com and select the country you're in, then select the Tobi carseat and download a replacement user manual which will have information on how to adjust straps and remove fabric.
Jul 13, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Can you tell me if I can remove the seat cover and hood from the maxi cosi car seat to wash? If so how do I do it? many thanks
If you go to http://www.maxi-cosi.com/ot-en and select the car seat you have, ie. CabrioFix, it will show you a picture in the middle of the screen with 4 tabs across the top. Underneath the picture are 3 options, Specifications, Instructions and Instruction Movie. Select Instructions and this will take you to the Instruction Booklet you should have got with the seat (if its not alread tucked in its holder at the back of your seat). There is a section in the booklet that shows/tells you exactly how to get the covers off for washing. Good Luck
Jun 17, 2010 | Maxi-Cosi CabrioFix (Black Reflection)...
Baby Gear Logo
26 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
