Question about Cub Cadet Garden
Have a cub cadet ltx 1042 when you push in the gas pedal it will not go. every thing else work fine. was mowing and it just stopped
  • 21 Answers
SOURCE: after adjusting deck 1042 cub cadet still cuttinglow right side
try checking to see if perhaps the blade is bent if not blade maybe the spindle or possibly the bearings are bad on the spindles causing them to not run true, also are all tires inflated properly good luck
Posted on Sep 12, 2009
  • 4 Answers
SOURCE: I have a Cub Cadet lawn tractor that just stop
CHECK THE FUSE
Posted on Jul 02, 2010
SOURCE: can you use Fix a flat to repair a flat tire on
remove rear wheel to fix flat tire
Posted on Aug 10, 2010
  • 6468 Answers
SOURCE: my cub cadet 1042 stalls when mowing up steep incline, what's the problem?
check the float level in the carb
Posted on Apr 06, 2012
  • 6468 Answers
SOURCE: Cub cadet ltx 1045 wont start, no spark.
remove the top cover from the engine and remove the small wire from the coil if still no spark the coil is bad
Posted on Aug 15, 2012
The lever to engage the blades on my Cub Cadet rider LTX 1042 KW has no resistance the the blades do not engage. Did a part possibly break off or come loose?
The blades are engaged electrically via the PTO on the engine shaft.
Check the connector and wiring to the PTO unit, or the electrical plug on the engage switch.
Oct 09, 2016 | Cub Cadet LTX 1042 KW 42" 18HP Kawasaki...
I need a picture showing the placement of the 2 springs on the mowing deck of a 2011 Cub Cadet Ltx 1040.
Cub Cadet LTX 1040 and LTX1045 Riding Mowers - YouTube
? 2:24
www.youtube.com/watch?v=XLT1v7h4at4
Jun 10, 2013 - Uploaded by CubCadetCA Cub Cadet LTX 1040 and LTX1045 Riding Mowers. CubCadetCA ... How to Change the Deck Belt on a Cub Cadet Riding LawnMower: Using ...
Jul 25, 2015 | Cub Cadet Garden
Cub cadet lt1042 will not back up a small hill
When is the last time you changed out your drive belt?
Oct 02, 2014 | Cub Cadet LTX 1042 KW 42" 18HP Kawasaki...
Cub cadet troubleshoot
check make sure all tires have same tire inflation
Aug 24, 2014 | Cub Cadet LTX 1042 KW 42" 18HP Kawasaki...
Ltx 1042
Sounds like drive belt is broken. How old is tractor? When is last time drive belt was changed?
Jul 20, 2014 | Cub Cadet LTX 1042 KW 42" 18HP Kawasaki...
Aug 07, 2012 | Cub Cadet Garden
Can you use Fix a flat to repair a flat tire on the Cub Cadet LTX 1042
If it's a simple puncture, "Fix-a -Flat" or another product called "Slime" might work for you. I believe Walmarts sells both.
Hope this helps... Good luck!
Oct 19, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
