Question about The Office Equipment & Supplies
Error codes kolin inverter E3
How to determined the defect of unit??
2 Suggested Answers
gopakumarg43
  • 75417 Answers
SOURCE: How we solve error code E3 kolin inverter
http://homenol.blogspot.com/
Visit this site to get some details.
Posted on Apr 21, 2016
How to determine if Protector O/L relay is bad and how to "reset the unit".
The relay is used to take the start capacitor and start winding out of the circuit once the compressor has come up to speed. Using an ohm meter, no power to the unit, and relay disconnected, you can determine if the relay contacts are open or closed. With no power to the unit, the contacts should be closed. If they are open, the relay is bad. However, the start capacitor could be the problem.
Oct 02, 2014 | Samsung RFG297AARS Bottom Freezer French...
Back fire
Hi Thomas, The problem could be related to burned valves, a leakage on the intake manifold, a defective airflow sensor, or a number of other problems. First disconnect the airflow sensor and start the vehicle and determine if the backfire is still there. If it behaves then that unit is defective. I suggest you have a diagnostic scan carried out to determine what is causing the problem on your BMW. Regards John
Jul 20, 2013 | BMW Cars & Trucks
The temperature display indicates "HI"
There are two possibilities for this error. Either the temperature sensor is defective or the units board is not reading it right. Here are a few suggestions to determine the cause.
1. If your system has two temperature sensors you could switch the connections and if the temperature is still off then it is the board. If the display is correct then the sensor is defective.
2. The manual may have a table of resistance versus temperature that you could use to test the sensor with an ohm meter.
3. If you call Pentair technical support at 800-693-0971 they should be able to help you determine what is wrong.
I hope this helps
Sep 11, 2011 | Pentair Minimax NT Heater
My Lexmark C543dn is printing yellow lines down every page
This issue may be caused by a defective toner or defective photodeveloper. You can try to swap the developer unit from the black one to determine if the developer is causing the problem. If so,you need to replace your developer.
I suggest you contact Lexmark Technical Support for further assistance.
Aug 23, 2011 | Lexmark C543DN Laser Printer
Gas gauge constantly on empty, check engine light not on,
Problem can be one of two things, a bad sending unit in the gas tank or a defective stepper motor in the instrument cluster. All gauges, speedo and tach are driven by stepper motor that have been known to fail. A technician using a scan tool can determine if the tank sending unit is working.
Sep 04, 2010 | 2004 Chevrolet TrailBlazer
I have a Motorola H780. There is no audio. I
I had the same problem and wound up calling Moto's tech support. They determined that the phone was defective and are sending me a replacement.
877-MOTOBLU
Jan 12, 2010 | Motorola Mobility H780 Bluetooth Headset
Power acoustiks amp wont get off protection mode? how do i reset it? please help me i tried everything.
Hello nfox1987,
First you need to determine if the amp is defective or if something else is causing it to go into protection, most often a short in the sub or amp wiring.
Disconnect the sub(s) from the speaker output terminals and the RCA inputs from the head unit, and test if the amp powers up OK. If it does, the problem is in the sub(s) wiring or voice coils, or in the RCA inputs to the amp. Reconnect each one-at-a-time to determine exactly where the short is and repair or replace the defective wiring or unit. If it doesn't power up with the inputs and sub(s) disconnected, the amp itself is most likely defective.
Hope this helps.
Jul 15, 2009 | Sony XM-475GSX Car Audio Amplifier
Xerox Phaser 6360N ghosting images on each page
Is it a ghost of the image or just a repeating defect? In the menu, there is a repeating defect information page that you can print out. Depending on the spacing of the defect, you can determine which component it is.
Mar 10, 2009 | Xerox Phaser 6360/N Printer
Scratchy Transmission
The first thing which comes to mind is a bad battery pack. You might try switching the batteries between the two units and see if the problem moves to the other unit.
Secondly, if you only have two radios, it could be the opposite radio has poor receive. You could have a damaged or defective speaker in the receiving unit.
Third, check the speaker grill and mic holes on both units to see they are clear of debris.
If all these items check out, you may need to eventually replace the defective radio. However, to determine which one is defective by trying them with a known good radio.
Jan 13, 2009 | Motorola Talkabout T6210 (14 Channels)...
Treo 650 common prublems
http://discussion.brighthand.com/palmhandhelds/showthread.php?s=3e3a9f0f6818b3260add857c81b65a99&threadid=75197
Sep 15, 2005 | Palm Treo 650 Handheld
77 people viewed this question
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
