Question about Garden
Pto won't stop turning switch is working in cab
  • 29 Answers
SOURCE: when hit switch pto won,t come on
check the 2 wire conection under the frame near the pto clutch, motor off of course. Make um tight.
Posted on May 01, 2010
  • 2239 Answers
SOURCE: why won't my pto engage?
They are normally electro magnetic clutches, the click is the cluch engaging so i would guess it is working, arev you sure the belt is not broken or lose?
Posted on Feb 13, 2012
  • 6468 Answers
SOURCE: still have the same problem pto still won't work the lights don't work on dash
check the safety switches
Posted on Apr 04, 2012
  • 6468 Answers
SOURCE: PTO NOT WORKING ON JD6300 CAB TRACTOR 4WD
Posted on Apr 15, 2012
  • 6468 Answers
SOURCE: lawn tractor, blades won't engage
the circuit also goes to the trans so you can't mow in rev also on the brake/clutch pedal switch assuming you check the fuse already
Posted on May 11, 2012
Why doesn't my Toro z master PTO not engage
check to see if pto will engage if not check voltage at pto if non blown fuse if fuse not blown and power to pto bad pto jump the pto at pto with battery in mower does it start pto if does good pto have to check volts at switch check there start with that let me no what happened
Sep 04, 2014 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
Why does my John Deere 5425, Pto keeps shutting off?
Check all connectors going from switch to PTO engagement clutch. Check ground wire from PTO. This problem is either a bad connection or a faulty electromagnetic PTO.
May 12, 2014 | Garden
Working on a cub cadet zero turn electric pto to blades, pto won't engage when pulling switch, can't find out why can get it to run jumping straight to battery if I put a toggle on this set up is...
go to partstree.com and they should have wiring diagrams for your mower, should be a switch or something if the clutch works when you hook it to a battery (seat switch, pto switch, parking brake switch, even the neutral safety switches) also check your ground hook ups
Apr 27, 2013 | Garden
Cab cadet 46
run power cable from positive of battery to pto it should click and move
Aug 29, 2012 | Cub Cadet Garden
My Lt 1050 Pto just stopped running and now it won't start
test the safety switch on the brake pedal and the pto switch
Aug 20, 2012 | Cub Cadet Garden
When hit switch pto won,t come on
Apr 30, 2010 | Oregon Scientific Electric PTO Clutch for...
MY TRACTOR RUNS FINE& STOPS LIKE IT SHOULD. THE BLADES DO NOT TURN WITH THE PTO SWITCH ENGAGED
if this is a newer mower then the problem is usually a safty switch is not being completed and this is stopping the blades from turning on, most mowers have a switch under the seat that has to be shorted out in order for the pto to work, this can be checked by connecting the two wires going to the switch together, and seeing if this solves the problem. Does it sound like the pto is trying to turn on if this is the case then you might find you have a siezed up bearing that is stopping the pto from engaging but my guess is a safty switch is malfunctioning and causing the pto tp not turn on, Hope This Helps Don
Nov 10, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
