Question about Mercury Boating
What does a 1985 scorpion 31 foot cc weigh with twin two stroke mercury outboard motors
finish line
  • 207 Answers
SOURCE: 1999 Mercury Mariner 9.9hp outboard motor
should be on the side with a lever but could you give me more info please
Posted on Jun 27, 2009
  • 2418 Answers
SOURCE: impeller replacing on 1999 merc. 25hp 2 stroke
Should not be that hard. Tape up the ends so you can hold it with out getting cut, (if its ragged or sharp from damage). should be one nut holding the impeller on. If its to tight to hold try air or electric Impact wrench. If its bad you can tap with a hammer to help in removing the old one. If it turned on the shaft you will need to rent a puller. Repost if you need more help.
Posted on Jul 05, 2009
  • 14 Answers
SOURCE: Should twin outboard motors be installed evenly or
Twin outboards should be mounted at the same level. One should be standard rotation and one should be counterrotation. The propellers should be the same pitch and size but opposite rotation.
Just check which hole on the motor mount that the top mounting bolt goes through. Should be the same one on both motors.
You may want to call the manufacture of the boat and see it there was something unique about that boat that required mounting them that way. You will need the serial number from the hull of your boat when you call.
Posted on Aug 10, 2009
SOURCE: Does an 85 johnson outboard motor 15 hp have
breaker/maker. set @ 020" @ the highest point but what is you're real problem. Run only champion spark plugs. We spenta dAY @ omc'S SERVICE CENTRE BEING SHOWN WHY. tHEY KNOW BEST!!
Posted on Oct 20, 2009
SOURCE: Re-assembling lower unit of 40HP Mercury 4 stroke
I found a lower gear case assembly diagram at http://www.crowleymarine.com/mercury_parts/6995/240.cfm which helped me understand how the shift mechanism works. This clued me in to the fact that I was missing the cam follower rod which I then found I had inadvertently mopped up in a shop towel when cleaning up spilled gear oil. After that discovery, assembly and operation was quick and successful.
Posted on Nov 12, 2009
How much does a 1996 Mercury outboard motor 115 hp weigh
FourStroke 150 hp - Mercury Marine
https://www.mercurymarine.com/en/ca/engines/outboard/fourstroke/75-150-hp/Mercury FourStroke outboard motors are incredibly powerful and efficient, and they feature a wide range of applications. Crafted for less weight and high displacement, they generate abundant torque and immediate power. ... 150 115 90 75. HP / kW‎: ‎150 / 110
Engine type‎: ‎8-valve single overhead cam ...
Dry weight *Lightest model available‎: ‎455 lbs / .
Jun 13, 2018 | Mercury Boating
I have a mercury outboard with serial # 5636683. Can you give me the shaft size of the motor?
Hey Robert,
What motor do you have?.. Size, year, two stroke/four stroke..etc.. and what shaft are you talking about?
Mercury Outboard Manuals by Seloc 1965 2014
Jul 18, 2017 | Mercury Boating
What does a 1985 scorpion 31 foot cc weigh with twin two stroke mercury outboard motors 250hp
LOL.. a whole bunch... why??
a pair of Mercury Pro-XS 250's weigh 1,100 lbs with props - dry
May 16, 2017 | Mercury Boating
What year is a mercury 35hp outboard motor with serial number2491265.Is the motor 2 or 4 stroke
the serial number begins 2487558 and continues past 2491265 and as the beginning serial number denotes the year , your engine is 1969 model
it shows as a 2 stroke with auto oil injection
check the heads
if the plugs are in the flat of the head and there are no rocker covers it is 2 stroke
talk with a mercury /mariner service center
Sep 25, 2016 | Mercury Mariner Starter, Outboard, 35-40...
Are the controls for a 1998 15 HP 2 stroke Mercury outboard compatible with a 2011 30 HP 4 stroke Mercury outboard
If your old engine/control has the same 'options' as the30hp, yes everything is compatible... (Electric start or trim )
The throttle and shift cables are allways compatible...
Jun 25, 2015 | Mercury Marine 15hp & 20hp 4 Stroke...
What pins on the ignition switch are energized when when you turn the key on a 2003 mercury 15 hp 4 stroke outboard?
Red is Battery +
Red/purple is ignition
Yellow/red is startermotor
Black/yellow is motor kill
Black is ground
To have ignition, black/yellow wire must be disconnected
On is red/purple on bat+
To start Yellow/red on batt+
To kill: black/yellow on ground
Jul 29, 2017 | Boating
1987 Mercury 75 hp 2 stroke outboard motor clicks when we try to start it
Do you mean it clicks and starter not turning ? if yes then the starter solinoid wires are loose or it needs replacing ! more info needed !
Aug 16, 2014 | Clymer Mercury/mariner 75-275 Hp...
Boating Logo
26 people viewed this question
Top Mercury Boating Experts
Colin Stickland
Colin Stickland
Mike
Steve
Steve
Are you a Mercury Boating Expert? Answer questions, earn points and help others
