Question about Craftsman Garden
Craftsman lawn tractor with a platinum 22.0 hp XRD engine. If I squirt gas into the carb it starts and keeps running as long as I keep spraying gas into it. Once I stop, it stops.
    New Friend:
  • 10 Answers
If this is a case of first spring startup, i.e. it's been sitting all winter with gas in it, you've probably got a gummed up carb brought on by what passes today for gasoline. I believe that unit has a fuel shut off solenoid at the bottom of the carb bowl which is probably stuck closed. Remove the wire then unscrew the solenoid from the bowl, give it a cleaning, then reinstall. If the engine still doesn't start you'll have to remove the carb and give it a thorough cleaning.
Posted on May 16, 2017
  • Craftsman Master
  • 2,321 Answers
You have a dirt problem with the carburetor
If there is a fuel cup on the carburetor bottom take it off and clean it out and also clean the fuel jets by putting a fine wire through them and using compressed air to blow them out. That should make it run better..
    Habit-Forming:
  • 154 Answers
Your carb need to be cleaned
float or float valve sticking in seat.
Aug 23, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine will not turn over
A FUEL PROBLEM. It doesn't over or doesn't keep running when gas is gone. Doesn't turn over, remove spark plug to let fuel out.
Nov 12, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a craftsman 22 hp zero turn,it just cranksover and doesn't start. Thier is good spark at both plugs, I have zero comprssion.I guess this engine has some sort of compression release. Does this engine...
Is there a wire going to the bottom of the carb? If so this is an electronic shuttoff. cycle the key on & off and listen if you can hear it click. If it does not you will not get any gas to carb to start it. Replacement part is not cheap. Most units do pull gas into engine as it turns over.
Dec 17, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My 675 will fire up a start and will immediatly quit. i have cleaned the spark plug and put in new gas.
it's still getting bad gas. take off air filter, prime with fresh gas, use an old spray can, and keep spraying while running until all old gas is used up in the carb
Jun 26, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
Can I add an hour meter to my Crafstman 917.289340 lawn tractor with the 22 HP Kohler engine? Found a part #401763 for a different model Craftsman. Will it work?
Yes, you need to find a wire that is hot (12vdc) when the engine is running, tap into this wire and hook to the positive side of the hour meter and the other will be a ground. This will keep track of engine hours only. If you want complete total hours, any hot wire with the switch on will work.
Feb 27, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Lawn tractor only runs when i spray engine starter in carb, then it stops
Bypass the filter. If it runs with the gas tank hooked strait to the carb., you'll know you've a clogged fuel filter. If this doesn't work, try cleaning the carb. It's not that complicated and doesn't have that many parts.
Jun 23, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower wont stay running
take hose off and take to local hardware store.probly got something that would work
..freaken sears..')
Jun 02, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
29 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
