Question about Cell Phones
Mysonicare tooth brush is beeping when it is charged
The electric toothbrush I have received seems to me is secondhand because one of the four brushes is missing and is already charged.
Batteries are always partially charged prior to shipping. The missing tooth brush would normally be replaced if you notify the seller of the shortage.
Aug 16, 2017 | Electric Health & Beauty
Why won't my iphone charge?
Check to see if the terminal is dirty. If it is use a tooth brush and carefully brush it. If that doesn't work then the charging port is bad or can be a bad battery.
Aug 15, 2014 | Apple iPhone Smartphone
What are these 2 blinking lights on my irobot roomba?
"The Charge Indicator Light is located immediately to the right of the power button on Roomba Red and Roomba (sage). On Roomba Discovery and Discovery SE, the Charge Indicator Light is incorporated into the power button. Please refer to the table below to determine what the Charge Indicator Light is telling you.
* Pulsing Amber - Charging
* Green - Fully Charged
* Amber - Partially Discharged
* Red - Almost Fully Discharged
* Flashing Red - Fully Discharged"
At the end of a cleaning mission, Roomba will tell you if it has successfully completed it's mission or not:
YELLOW = MISSION ABANDONED (Check robot's brushes, etc.)
number of beeps after ?uh-oh? :
No beeps: A wheel is stuck or is not touching the ground. Pick up the robot, place it down securely on the floor and touch the clean button to restart the cycle.
1 beep: The main brushes cannot turn. Turn over Roomba and remove the brush guard by pushing the two yellow tabs. Remove the brushes, clear any obstructions, and replace them again.
2 beeps: The side brush cannot turn. Turn over Roomba. Look to see if something is wrapped around the side brush. Remove the side brush with a screw driver and check for string or hair that may be wrapped around it.
3 beeps: The vacuum cannot run Remove and empty Roomba?s bin.
4 beeps: A wheel motor cannot run Your Roomba may be stuck or something may be wrapped around a wheel. Look for something wrapped around the wheels. Push them in and out and make sure they turn easily.
5 beeps: The cliff sensors have failed or are blocked. Turn over Roomba and clear any debris that might be caught underneath the front bumper in the cliff sensors. You can also use compressed air to clean them out.
6 beeps: Wheel obstruction or robot attempting to drive over an obstacle. Turn over Roomba and remove any obstructions that prevent the wheels from seating all the way up into Roomba?s body. Also, remove any obstacles that Roomba could drive over.
7 or 8 beeps: Not applicable Roomba?s beep codes do not include 7 or 8 beeps. If you are getting an error with 7 or 8 beeps, try counting again or contact iRobot Customer Care.
9 beeps: Sensor error Please contact iRobot Customer Care.
10 beeps: Roomba is stuck Pick up Roomba and start it again somewhere else. Use a virtual wall or other barrier to keep Roomba away from the
place it got stuck.
Your Roomba may be experiencing an issue where the battery is deeply discharged and may need to charge longer than the standard 3 hours. (or 7 hours if you have a standard charger)
Even with the charging light showing green (this indicates a fully charged battery) the robot is still charging. If your Roomba exhibits behavior where it charges for a short time then runs for a short time you will need to do the following.
1. Plug the charger into Roomba (if you have a home base be sure to plug directly into Roomba instead of using the home base, this will ensure the robot's charging cycle is not interrupted.)
2. After the Roomba's charging indicator goes to solid green please keep the Roomba on the charger for an additional 72 hours. (3 days)
3. After the 72 hours (3 days) has passed, turn your Roomba on and begin a normal cleaning cycle. If this works successfully it may take several uses for the battery to get back up to the performance it once had.
If this does not correct the problem, please call customer support at 877-855-8593
Nov 22, 2012 | Vacuums
I replaced memory and hdd yet no display and my notebook beeps
try to clean ur memory holder where u mount it...clean it wid tooth brush..or make sure u insert it rit way.....
Feb 11, 2011 | Computers & Internet
It's not working properly, i m facing charging problem. i think phone pins are damaged. please do the needful asap.
hi :) here i teach u how to solve your pro,if u check the phone charging port was dirty,u can use a tooth brush and some alcohol. brush the charging port.try it. normally sony have this kind of pro.
please voted me if my solution useful,thank..
Aug 02, 2010 | Sony Ericsson K530i Cellular Phone
When the laptop turned on, it's keep beeping all
Sounds like you have a stuck key, When the computer is off brush your arm across the keyboard a few times or try to find the stuck key and use a tooth pick to pop it up. Have you spilled anything on the keyboard?
Jun 05, 2010 | Toshiba Satellite A25-S279 Notebook
Yesterday, while I was brushing my teech I broke
go ask your dactor if he can do anthing
Jul 09, 2009 | Health & Beauty
I have dell latitude d600 with charging problem
try this take a old tooth brush,brush between the pins on the battery and the contact on the motherboard where the battery contacts are.I had this problem and it worked for me.
Good luck
Mar 09, 2009 | Dell (2336V) Motherboard
Unable to charge
i have the same problem as you and that my battery wouldn't stay charged longer than 2 days. i went to the local verizon service and i knew the tech and he took a tooth brush and gave it a good cleaning with it at the connectors at the end of the phone. he told me too do the same on my chargers especially on the 3 small prongs in the middle of the chargers. and just good measure i took the battery out and cleaned it with my tooth brush. if this doesn't solve your problem then it probably needs to be looked at. hope this helps you out. jeff
Sep 20, 2006 | Motorola Mobility E815
Cell Phones Logo
32 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
