Question about The Health & Beauty
Can the seat on a m-51 pronto be lowered? - The Health & Beauty
2 Suggested Answers
wcdoc1953
  • 280 Answers
SOURCE: Where can I get a manual for the Pronto M41 Electric Power Wheelchair
You can download the M41 manual at the Invacare website:
http://www.invacare.com/doc_files/1143206.pdf
Posted on Jul 06, 2012
How do I adjust the seat height on a Pronto M51 with SPJ+ Joystick
The seat height can be adjusted by removing the seat and raising up the 4 seat pillars on the bottom frame. With the pivot seat model you can raise the center post seat pillar.
Feb 12, 2014 | Invacare Pronto M51 Power Wheelchair
Pronto m41 moves slow at all times
If you have a seat lift on your chair, you will have to lower the seat lift. This is call limp mode so the chair does not move to fast and tip over while the person is in the chair. If this is not the case, then your chair controller may be over heating and it will also cause the chair to go into limp mode. this is a better option than totally stopping. the way to correct this is to let the chair sit and "cool down" for a little while. It usually takes about 30 minutes, sometimes less in cooler environments to get the chair back to normal use. If neither are the solution, then you have a problem with the chair that causes the controller to reduce the output. You will need to get an authorized Tech to check the chair out to determine the root cause.
Oct 30, 2013 | Invacare Pronto M41 Power Wheelchair
Help I stupidly got my dog lead caught around the left drive wheel of my M61 Pronto yesterday. A kind person got it unwound but needed to tip the chair on its side to do it. Now the far left single green...
The M61 has an elevating seat. There is a speed limit switch which consists of 2 magnets that make contact under the seat on the seat post. If the 2 magnets are together then the chair thinks the seat is all the way down. If the magnets aren't touching it activates a safety feature in the controls which cuts power to the chair by 50% hence drives real slow. Try lowering the elevating seat down through the joystick controls. If that doesn't fix it then either the magnet switches on the seat post came unplugged or broke.
Sep 16, 2011 | Invacare Supply Group Pronto M61 Standard...
Lost instruction guide to costco pronto carseat.
Here is the cosco website online instruction manuals. You will need your product number and the date of manufacture. Just enter them into the spaces provided and they will provide you with the instruction manual for the car seat. The product number in there now is for a Cosco pronto car seat, I would confirm it is the same as the one you have.
http://www.coscojuvenile.com/usa/eng/Instructions?ProductNumber=BC033AOL
Hope this helps.
Aug 03, 2011 | Cosco Juvenile Pronto 22491 Booster Car...
My husband tried to put in the two new batteries today into our Pronto 51 Sure Step and he just could not seem to get to the bad ones. How does he change the batteries:
Judy He has to disconnect the joystick cable and then pull the seat off the post raising up the seat turning lever and twisting and pulling upward on the seat at the same time. It can be hard because the seats are heavy and can be rusted. Just keep pulling and turning at the same time Once he has the seat off he can remove the cover over the batteries and disconect the cables going to the batteries and the large connector going to the power pack. Reinstall the new batteries just like the old ones replace the cover. Put some axle grease or vaseline on the seat post reinstall the seat plug in the joystick cable and you should be good to go Hope this helps
Mar 27, 2011 | Invacare Pronto M51 Power Wheelchair
Seat back won't lock
JC If your chair is an Invacare locate The lever on the right side of the lower seat cushion that lets you adjust the seat back it might be stuck letting the seat back not lock. Try setting the back where you want it and pushing down on the handle to see if you can get it to lock. If you can't get it to lock you'll just hafta get another seat or find a used seat that you can take the locking lever off of. Hope this helps
Sep 15, 2010 | Electric Mobility Invacare Pronto M41...
Health & Beauty Logo
23 people viewed this question
Top The Health & Beauty Experts
Motshidisimary
Motshidisimary
Level 1 Expert
Stacy Harrison
Stacy Harrison
Level 1 Expert
Dave Jacobs
Dave Jacobs
Level 1 Expert
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
