Question about Electrical Supplies
Onan emerald 5000 generator starts, but stops as soon as soon as start button is released We have replaced the starter, fuel filter, fuel pump, and the oil pressure sensor guage.
3 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: onan generator emerald III genset. I push the
Here are the most common reasons for your condition.
CHECK IF ENGINE KEEPS RUNNING The most common complaint is that the engine starts but will not keep running when the START switch is released. This happens because the control board will not allow the engine to continue running if the generator is not producing voltage or if the oil pressure signal is not present. See CONDITIONS REQUIRED TO KEEP RUNNING on the Troubleshooting Chart for your model. If the engine will not keep running, do the following:
A1. Generator AC Output Check the generator AC output voltage as soon as the engine starts. Models showing "B1-B2 Volts" or "L1 AC Volts" under CONDITIONS REQUIRED TO KEEP RUNNING need this AC voltage to keep running. Read between the points shown on the Troubleshooting Chart. If the AC voltage readings are good, proceed to "B" below.
A2. Field Flash If there is no AC, check for 10-12 VDC at the FIELD FLASH pin of the control board during cranking. If the field flash voltage is not present, the control board is defective. If the field flash voltage is present, the wiring or regulator may be defective. To eliminate the wiring, check continuity between the FIELD FLASH pin of the control board and pin 7 of the regulator. If the continuity is good, either the regulator or the field circuit (rotor and brushes) may be the problem.
A3 Field Circuit Check the field circuit by unplugging the regulator and measuring the resistance between pins 9 and 10 of the regulator’s mating plug. This reading should be 22 to 28 ohms. If this reading is too high, check the brushes and/or clean the slip rings (use the Slick Stick, or a similar tool). If this reading is too low, there may be a short in the rotor. Also, check the resistance from pins 9 and 10 to ground. This reading should be very high or infinity. If not, there is likely a ground in the rotor. If these readings are all good, the regulator is likely defective.
A4 External Excitation To confirm that the regulator is defective, turn off the generator’s AC circuit breaker(s), reconnect the regulator and apply 12 volts through a diode to pin 9 of the regulator plug (see illustration) while attempting to start the engine. CAUTION: DO NOT attempt this without the diode. If you do, there will be fireworks! Remove the 12 volts within 1-2 seconds after the engine starts. If the genset now continues to run and produces normal AC voltage, the generator is OK and the regulator is defective. If the genset does not continue to run but produces about 40% of normal AC voltage, again the generator is OK and the regulator is defective. If no AC voltage is produced, the generator may have a problem that is beyond the scope of this guide. Re-check all wiring for security and signs of damage. It may be necessary to take the unit to a qualified repair shop.
B. Check the oil pressure switch as soon as the engine starts. Models showing "LOP to GND" under CONDITIONS REQUIRED TO KEEP RUNNING need the oil pressure switch to be closed to ground when running. If the voltage on the LOL/LOP SW pin of the control does not go to near zero, the switch is not closing. These switches sometimes stick open if the generator has not been used or exercised often enough. Multiple start/stop cycles and/or tapping on the oil pressure switch will sometimes fix it. It may be necessary to temporarily jumper the switch to ground to keep the engine running. This can be done at the switch or at the OIL LOL/LOP SW pin on the control board. Models showing "LOP Open" under CONDITIONS REQUIRED TO KEEP RUNNING have electronic governors and require the low oil pressure switch to be closed at starting but open during running. When the switch opens, the governor module places a ground on the oil pressure input of the control board (P1-5). It is OK to temporarily ground P1-5 on this model to keep the engine running. NOTE: See chart for oil pressure and oil level switch locations.
C. If there is AC voltage present on B1-B2 or L1 AC, as applicable, and the correct oil pressure/level signal is present at the OIL LOL/LOP SW input of the control board, and the engine will not keep running, the control board is defective.
This should help you get it going.
Kelly
Posted on Mar 09, 2010
SOURCE: RV Onan Emerald 1 Generator
Check all the ground wires and make sure their not broken or loose. If the wires are good next check the neg. Wire to the coil. Too check the swiitch make sure you have continuity too all the post when the switch in the on position, this requires removing the switch.
Posted on Mar 15, 2011
My RV has a Onan Emerald 5000 Genset Generator. I will start it and it will start after 3 times cranking it. Runs fine. Turn it off. Then try to start it again and I get nothing. No trying to crank.
associated problems here are
low oil sensor system faulty
fuel flow insufficient-- blocked fuel tap /filter in tap
problem wiring in the coil area--stop switch
problem ignition control module
take it to a generator repair shop/ mower repair shop for a proper diagnosis and quote
Sep 06, 2016 | Electrical Supplies
Onan genarator will not crank
If it wont crank, check to see if the solenoid on the starter pulls in, the starter and solenoid are one unit, it sounds like an internal starter contact, if you have 12V going to it. Assuming the battery is good. When you press and hold the stop button does the fuel pump pump prime? if so control board has power
Mar 24, 2014 | Onan Generator, 6500W, LP Vapor
I have a onan 6.5 emerald gen,when you start it it quits as soon as you let go of the start button, will run fine while holding start button on,then quits when you release,please help,maybe field not...
More likely the switch is bad, and only make run contact when in the start position.
Easy to test the switch continuity with a ohm meter when it is not running.
May 06, 2011 | Watts Onan Portable Generator - 5000 ,...
I have a 1997 onan emerald series GenSet 6500 I have been thru 4 starters it keeps breaking the drive gear assmbly WHAT CAN I DO PLEASE ITS ALREADY COST ME 400.00
Have you replaced the solinoid too? If not, maybe the solinoid is staying engaged, which keeps your starter, well starting. If the starter stays energised the flywheel WILL tear up the starter gear.
hope this helps
Nov 04, 2010 | Watts Onan Portable Generator - 5000 ,...
Aug 09, 2009 | Watts Onan Portable Generator - 4000 ,...
Onan 4kw Emerald I generator will not crank
The gen. is not the problem, the engine start circuit is not functioning. You need to look at the starter solenoid and starter.
Jul 01, 2009 | Electronics - Others
Lost electric power to fuel pump on Onan Generator
there should be a fuse at the housing by the start/stop switch. if deisel then take the 10mm screw out of the coolant cap cover and check those fuses. verify power after. good luck.
Jun 05, 2009 | Watts Onan Portable Generator - 5000 ,...
6.5KW Onan generator. wont run when the start button is released
Flight systems can test the onan circuit boards. google them they will come up. First class operation my board was was checked out and back to me in about a week, They also sell new boards and deduct the 20 dollar bench fee if yours is bad and you buy a replacement from them.
Jan 08, 2009 | Watts Onan Portable Generator - 4000 ,...
Electrical Supplies Logo
29 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
