Question about Sharp Office Equipment & Supplies
Using SHARP EL-500L calculator, how do I GET THE L.C.M. of a number series?
SOURCE: Need to change tax function on Sharp EL-334A
I had the same problem and finally figured it out. Here's what you do:
Press C-CE twice
Press +TAX (Rate set)
Key in your new tax rate as an integer (e.g. 5)
Press +Tax (Rate set) again
Press C-CE
Then you're ready to calculate with the new rate!
Now what's the GT button for?
Posted on Nov 27, 2007
SOURCE: FIX numbers
If you press the setup key then 1 under FSE it will say TAB (0-9)? enter the amount of decimal places you want and it will change that for you.
Posted on Apr 20, 2008
  • 359 Answers
SOURCE: Sharp EL-2630GII Error on display
Unable to locate a manual for this specific model, but if you go to, you will find one for an EL2630-P, PII, and PIII. The functions are very similar and should give you the detail that you need. Generally there will be a reset button (likely on the bottom of the machine), which often must be pushed in using a ballpoint pen or similar implement, if no other routine clear or reset procedure (such as turning off and back on) is working.
Please post back if you need more help, otherwise thank you for using and rating FixYa!
Posted on Jun 08, 2008
  • 11 Answers
SOURCE: Where do I feed my paper into the Sharp El-1801P calculator
Hello, my name is Curtis, I am a Sharp Customer Servicer Rep. Normally the calculator would have a thin slot on the back, where you would feed the paper through, then once you press the paper in till it hits an inner wall, you would press the feed key which is on the upper left side of the calculator. If there are any problems doing this please call our technical support line at 1-800-237-4277, I am very glad to hear you like the calculator though!!!
Posted on Jun 30, 2009
SOURCE: Sharp ELSIMATE EL-240SA - how do you stop this
From the manual:
Numbers of decimal digits of calculation results can be specified by pressing [C-CE] twice, then press [C-CE]and [M+] simultaneously.
The decimal digit assignment will appear as “F” (for “floating point”), “2” or “0” on the LCD. (The default is “F”.)
Press and hold [C-CE] and [M+] until the symbol changes.
Posted on Sep 29, 2009
My Sharp EL-2630P gives 2 different answers when adding same series of numbers? Why?
Can you provide images of the two tapes with the same series of numbers and two different results?
Good luck,
Jan 06, 2016 | Sharp Office Equipment & Supplies
Using a sharp el-738 calculator to find square roots
To get a square root sign on the SHARP calculator press 2nd F 3 (you will see in orange the square root above the 3) then type in the number you would like to find the square root and press equals
Mar 31, 2013 | Sharp EL-738 Scientific Calculator
Calculating square roots using a sharp el-738 calculator
On the calculator press 2nd F 3 to get the square root sign, then type in the number you would like to find the square root of and press equals.
Sample variance on Sharp EL-738
To calculate this you press ALPHA (the green key) and 5 or 6 depending on if you want sample variance (ALPHA 5) and for population variance (ALPHA 6).
Jul 17, 2012 | Sharp EL-738 Scientific Calculator
Check the Decimal / Add Selector. It shoul be set to "A" (Add mode), to permit addition and subtraction of numbers without entry of the decimal point.
You may also want to download the SHARP
EL-1801P Operation Manual
Jun 22, 2009 | Sharp EL-1801P Calculator
Where is shift log feature in sharp EL-531 W calculator
The [2ndF] key allows access to other functions. I do not have the calculator under my nose, but I suspect under the [2ndF][LOG] you access the 10 to the power x function [10^x] or [10 to the x].
Hope it helps.
Apr 08, 2009 | Sharp EL-531VB Calculator
User's manual Sharp EL-531WH
You can download the manual from the link below:
Aug 10, 2007 | Sharp EL-531VB Calculator
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
