Question about Tablets & eReaders
Kindle will not charge - Tablets & eReaders
    Loyalty:
    Visited the website for 30 consecutive days.
  • 110 Answers
Hi Paula.
Try using a known good charger. If you get the same result its possible you have a bad charging port. You can try resetting your Kindle which may help. Hold the power and home buttons at the same time until it comes on then release the buttons. Hope this helps.
Posted on May 16, 2017
My kindle won't charge. I have tried 3 different chargers.
Lillian, May have to try hard reset or possibly repair charge port to get battery to start charging. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My Kindle won charge
Kindle Wont Start or Charge How to Reset Kindle
Troubleshooting Kindle Fire That Won Charge
Kindle Fire Won Charge Fix
May 22, 2016 | Tablets & eReaders
Won't take a charge.
Armend, Could be a bad charging port. Press and hold on button for 15-20 seconds a couple times to see if it will reset and power up before trying anything else. Check the attached links, videos,instruction and guides on kindle charging problems. Good luck
12 major Kindle Fire problems and how to fix them
Reset Kindle Fire When it Won Turn on or Charge
Apr 08, 2016 | Amazon Kindle Fire HD
Kindle will not shut off-goes to shut off or cancel but wont move. doesnt charge well-doesnt always hold charge
Patricia, Using the power switch, you can forcibly reset your Kindle device. This reset will shut down the Kindle without accessing the shutdown command from within the Kindle's operating system, a particularly useful tool when dealing with a frozen Kindle. To initiate a hard shutdown, Kindle disconnect from its charger, slide and hold the power switch for about 20 seconds. This will force the Kindle to shut down, now it can be restarted normally.
Check links below for charging problems.
Kindle Fire not charging
9 common problems with the Kindle Fire HD and how to fix them
Feb 25, 2016 | Amazon Kindle Fire HD
My kindle fire loses it's entire charge overnight when turned off. It occasionally makes a beep
Amazon.com: Customer Discussions: battery life on kindle fire hd
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Nov 12, 2012 - My son bought himself a kindle fire hd over the summer and we are having some issues with ... and unused yesterday from a full charge and it was < 5% (red battery) last night. ... a paperwhite kindle as its much lighter and I'm fed up losinghours to addictive .... ETA I tried again last night to power off and charge overnight. Kindle Fire HDX 8.9 battery ...
Dec 3, 2013
Kindle Fire HD won't charge?!
Apr 10, 2013
Kindle - Losing charge when ...
Oct 9, 2012
Kindle Fire HD Battery tips
Sep 17, 2012
More results from www.amazon.com
Dec 09, 2015 | Tablets & eReaders
Why wont my kindle hd charge?
It could be the charger itself. Try taking the USB cable out of the charger and plug it into your computer, then plug in the Kindle. Your computer's USB port should be able to charge it. If it still doesn't charge, you might have a bigger issue with the tablet itself.
Jul 23, 2014 | Amazon Kindle Fire HD
My kindle wont charge while I'm using it. It only charges when the kindle is off
You didn't specify the model of your Kindle, but the user guide for my Kindle states that it must be turned off to charge.
Sep 21, 2013 | Tablets & eReaders
Battery will not charge
Follow these steps if the Kindle battery is not charging:
  1. Connect Kindle to a different outlet.
  2. Verify the charge light at the base of the Kindle is on.
  3. Restart Kindle by pressing Home > Menu > Settings > Menu and select "Restart." Is the charge light on? Contact Customer Service.
  4. Is the charge light off? AC adapter needs to be replaced.
  5. Contact customer service for in-warranty options.
Follow these steps if the Kindle Battery is not holding a charge:
  1. Turn wireless off and fully charge your Kindle.
  2. With wireless turned off, Kindle battery life should be:
    At least 7 days
  3. If battery lasts less than the time frame given above, contact customer service.
If none of this helps, or you need to contact Customer Service here are the numbers:
In the United States: 1-866-321-8851 Outside the United States: 1-206-266-0927
Thank you.
Mar 03, 2011 | Amazon Kindle Wireless Reading Device
Kindle not working. It will not turn on blank screen
Make sure that the kindle is fully charged. When charging the kindle 3 will have a yellow light indicating that it is charging. When this turns green, your kindle is fully charged. Make sure your kindle is fully charged and then try turning it back on.
Feb 21, 2011 | Amazon Kindle DX 3rd Generation
Tablets & eReaders Logo
55 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
