Question about The Audio Players & Recorders
AM does not work! Cannot get any AM channels on the ONN Mini Stereo system. Please help.
    Top Expert:
  • The Master
  • 51,198 Answers
Are there any am stations in the area that you can receive
Posted on May 16, 2017
Onn mini stereo system ona12av024 manual
Try Googling (onn)(ona12av024)(manual) without parens.
Dec 17, 2017 | Mini Audio Players & Recorders
How to set clock on onn mini stereo system
There are several onn mini stereo systems. Suggest you google onn stereo mini system, as there are several user manuals available. Select the one for your model & look for clock instructions
Jan 21, 2017 | Mini Audio Players & Recorders
Cannot listen AM radio
I cannot get into my net fix account.
Feb 23, 2014 | walmartstores.com Computers & Internet
Both mini speakers are playing, but not getting any sound from the base box.... what might be happening?
The mini sub woofer's amplifier is not working but the other amps powering the left and right channels are ok.
Nov 28, 2013 | Klip Xtreme KSS-710 2.1 Stereo Speaker...
I have a yamaha speaker yst-m7 but with no hookups I need all the wire
Amplifier Output 5W/Channel x 2 Frequency Response 90 Hz - 20 kHz + or - 3dB Speaker Unit 6.5 Cone, Full Range Magnetic Shielding Yes Diminsions (wxhxd) 3-3/8"x 8-1/2" x 5-3/4" Weight R: 1lb. 9 oz.; L: 1lb. 5 oz. Included Accessories AC Adapter, stereo mini plug cable, RCA pin plug cable Colors Black, Platinum Amplifier Output 5W/Channel x 2 Frequency Response 90 Hz - 20 kHz + or - 3dB Speaker Unit 6.5 Cone, Full Range Magnetic Shielding Yes Diminsions (wxhxd) 3-3/8"x 8-1/2" x 5-3/4" Weight R: 1lb. 9 oz.; L: 1lb. 5 oz. Included Accessories AC Adapter, stereo mini plug cable, RCA pin plug cable Colors Black, Platinum Amplifier Output 5W/Channel x 2 Frequency Response 90 Hz - 20 kHz + or - 3dB Speaker Unit 6.5 Cone, Full Range Magnetic Shielding Yes Diminsions (wxhxd) 3-3/8"x 8-1/2" x 5-3/4" Weight R: 1lb. 9 oz.; L: 1lb. 5 oz. Included Accessories AC Adapter, stereo mini plug cable, RCA pin plug cable Colors Black, Platinum Amplifier Output 5W/Channel x 2 Frequency Response 90 Hz - 20 kHz + or - 3dB Speaker Unit 6.5 Cone, Full Range Magnetic Shielding Yes Diminsions (wxhxd) 3-3/8"x 8-1/2" x 5-3/4" Weight R: 1lb. 9 oz.; L: 1lb. 5 oz. Included Accessories AC Adapter, stereo mini plug cable, RCA pin plug cable Colors Black, Platinum 3.5 mm. stereo mini jack x 2.
3.5 Stereo mini plug cable.
RCA Pin plug cable.
3.5mm stereo mini jack x 2.
3.5 stereo mini plug cable
RCA Pin plug cable
You might get these on Ebay im not sure which country you are in this might guide you to one
you could get this on Ebay if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps
May 20, 2011 | Yamaha YST-M7 Computer Speakers
I can't get any sound out of my Korg Mini Kaoss pad when running it into an amplifier. It works fine if I run it into my old cassette 4-track recorder, but I get nothing other wise. I've tried bunches of...
The Mini KP generates Stereo output and you would run it to either a stereo channel on your mixer before the amp or into two channels of your mixer board and PAN them to opposite sides.
If you try to connect this to a monaural amp, like a guitar amp) your cable will ground out the output of this box. The minimum would be to builld a special resistive mixer to combine the channels before they go to your amp HOWEVER you will lose much of the effects without having a stereo system.
Jan 19, 2011 | Korg Mini Kp Kaoss Pad
Rode NT2 got Phantom!
Well... Rode NT2's are condenser mic's that require phantom power to work. So the phantom switch should be on. When you turn phantom power on you usually hear a bump sound (through the amplifier). In this case, nothing is broken.
Your picture is of a Rode Videomic (not an NT2) which is a stereo mic for video cameras. If you had some kind of stereo mini to (single) XLR adaptor, and put phantom power through it, the mic would probably be damaged. But maybe not... just try again without phantom power to see. a stereo mic won't work very well with the Mbox Mini because it only has one mic preamp.
Feb 12, 2009 | Rode (VIDEOMIC) Professional Microphone
Kenwood Receiver connected to my pc
using the Y adapter method (i am guessing you are using just a single stereo mini-jack cable with a mini-jack to RCA adapter) you are only sending a standard Stereo signal to the receiver. Setting 5.1 in windows is just simulating (if using Stereo) or actually mixing 5.1 if you are using analog 5.1 (3 stereo mini-jack cables going to 3 mini-jack to RCA adapters using a 6 channel DVD input). if you have a surround sound audio card i suggest using the Analog 6 channel input by using 3 stereo cables each with their only adapter.
or, if you have a Digital output (Coaxial or TOSlink [optical]) try using that.
good luck.
Nov 12, 2008 | Kenwood VR-406 Receiver
Sound not working
You can goto the manufacture web site for the speakers and download the latest device drivers and install them on your computer.
Oct 07, 2007 | Juster SP-692 Computer Speakers
49 people viewed this question
Top The Audio Players & Recorders Experts
bihug
bihug
Level 1 Expert
D. E. Hev
AliennoisE
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
