Question about Light Garden
Battery light stays on my John deer 737 starts good ?
  • 154 Answers
Check battery volts with engine off if battery volts on 12v battery ok... check battery running over 12v then battery is charging, stays on 12v battery is not charging ... replace alt. or gen which ever one you have... battery volts drops as running battery needs to be charged or replaced.
Posted on May 16, 2017
John Deere 737,Kawasaki motor, gets hot start's missing on one cylinder, cools off start's run fine, could it be the coil breaking down
possible so have the coil checked
could be from dirt and grass blocking the cooling fins of that cylinder causing the problem with mixture
if you spent that much with a dealer and the problem was not fixed maybe you should complain about the cost and the failure to fix the fault
May 13, 2016 | John Deere Garden
757 Ztrac. Why do I keep burning belts off?
if you dont use kevlar belts,then you are wasting money,they cost more,but,they last ten times longer,use the widest width that it can handle,dont buy from jd,it will cost you 100.00,go to ebay,etc,your tensioner should not be tight enoughto stretch the belt also,here is a jd belt,you can get cheaper just make sure it looks green or red,not rubber black, JOHN DEERE oem Mule Drive Belt TCU13195 737 757 Trak below 030000
OEM Replacement PTO Belt John Deere 737 757 Zero Turn Lawn Mower
JOHN DEERE TRAK 737 757 797 60 DECKS DRIVE BELT TCU13198 12760
Jun 24, 2015 | John Deere Garden
John deere 737 loss of power under a load but at stand still runs wide open good.
IT very well need carburetor work..These run off the idle mixture until loaded then they switch over the main mixture ports.
Mar 16, 2015 | John Deere Garden
How do you install john deere 737 pto clutch after bearings wearing out
Most has a bolt holding it on the end of crankshaft
Aug 11, 2014 | John Deere Garden
John deere 737 mower
I had this kind of problem on my cub cadet. it was a weak coil. Replaced the coil and all was good.
Oct 30, 2013 | John Deere Garden
I have an '04 john Deere 737 ztrak mower and when
check for a spindle seizing from rust and failed bearings.
Jun 15, 2013 | Garden
Discharge indicator light stays on.
I would start with a new voltage regulator which is located under the battery tray.
Jun 16, 2009 | John Deere Garden
John Deere ZTRAK 737 zero turn - runs rough - one plug
My idea would be to replace the coil to that plug
Jim Kite paris, il
Apr 18, 2009 | John Deere Garden
Garden Logo
53 people viewed this question
Top Light Garden Experts
Dennis Key
Dennis Key
Are you a Light Garden Expert? Answer questions, earn points and help others
